Which Spyderco for prying with tip?
cycleguy
Postby cycleguy » Thu Oct 17, 2019 7:22 pm
Which Spyderco do you like best for prying with the tip???
This is not something I normally do, but I may give it a try soon.
Are the stainless out and is this best left to carbon/tool steels? Which blade grind? etc etc
CG
AccountDeletedUserRequest
Re: Which Spyderco for prying with tip?
Postby AccountDeletedUserRequest » Thu Oct 17, 2019 7:26 pm
Folder: PE Pacific Salt. Pacific Salts have stout tips, and the PE is thicker at the tip than the SE version. H1 is one of the tougher steels Spyderco offers.
Fixed: Aqua Salt
The Meat man
Postby The Meat man » Thu Oct 17, 2019 7:49 pm
^I agree with Vivi.
H-1 will bend but it will not break. And you can always bend it back. It's extraordinarily resilient.
- Connor
"You live and learn. At any rate, you live."
The Mastiff
Postby The Mastiff » Thu Oct 17, 2019 8:06 pm
Whichever one you want to break.
yowzer
Postby yowzer » Thu Oct 17, 2019 8:22 pm
The screwdriver on the ClipiTool Rescue.
Sumdumguy
Postby Sumdumguy » Thu Oct 17, 2019 8:35 pm
Blunt nosed Caspian.
Ez556
Postby Ez556 » Thu Oct 17, 2019 8:43 pm
Civilian. Just kidding... No experience with it, but I’d say maybe the Lum Tanto?
Likes FRN
sal wrote:
Sun Aug 04, 2019 7:28 am
But in reality, there is nothing quite like a gun. And it has been said, "The only way to stop a bad guy with a gun is a good guy with a gun".
Sumdumguy wrote:
Tue Oct 08, 2019 4:35 am
Does that complexity decrease the simplicity? Not at all.
A.S.O.K.A
Postby A.S.O.K.A » Thu Oct 17, 2019 9:03 pm
Thats almost a no brainer, shaman. Just to be clear, I do not own the tuff model but handled it and that would be a solid candidate too if you can get one
Every Steel Has Its Appeal :cool:
A.S.O.K.A Edge on Youtube
standy99
Postby standy99 » Thu Oct 17, 2019 9:08 pm
Lynch prybar
Postby JD Spydo » Thu Oct 17, 2019 9:09 pm
I wouldn't recommend using a top quality knife of any kind for prying. However if it was an emergency I would use the one I'm carrying right now. And that's my C-46 Lum Tanto folder. The spine on this folder is so thick that I think it would take an awesome force to do any damage to that blade.
Dodge
Postby Dodge » Thu Oct 17, 2019 9:22 pm
I was gonna say lum tanto too! But I think close second would be Assist followed by Atlantic salt.
Sprint request: Flat Iron Salt (CE w/ yellow FRN)
New knife request: Police 4 LW Salt!!!
"If you won't stand for something, you'll fall for anything"
VooDooChild
Postby VooDooChild » Thu Oct 17, 2019 11:49 pm
To speak generally... while a knife is the wrong tool for the job if its going to happen theres a few common factors.
A fixed blade will probably be better than a folder. Not always but alot of times yes.
Thick blade stock is always going to help.
What blade material matters as well. Will it bend or break?
Then comes blade geometry. You need a robust tip, sabre grind or frankly alot of the others are probably going to be better than flat grind with a distal taper.
Then comes the rest of the construction of the knife and whether it will handle it.
Seems like the more you try and turn a pocket knife into a pry bar the worse it becomes at being a knife. Its a hard balance to strike in knife design. I guess Im saying when I see it done right I appreciate the design.
If your asking which spyderco folders are better at it then im going to say Shaman, sabre ground endura 4, and whatever h1 salt series knives have the thickest blade stock. So atlantic and pacific salt, which are also sabre ground. Assuming the linerless frn on those salts is actually as tough as everyone says it is.
Postby Wartstein » Fri Oct 18, 2019 12:03 am
Endura sg, Pac Salt
I think the sabre grind tips are noticeable stronger than even the Shaman tip (though the Shamen technically is a sabre grind too I guess)
VooDooChild
Postby VooDooChild » Fri Oct 18, 2019 12:09 am
I got so caught up in the prying part of the question that I wasnt drawing the distinction of the with the tip part.
As there can be a big difference between prying with the tip and prying with the entire blade and leveraging all that force through the handle.
When I think prying with the tip my mind goes right to paint can lids. I thing thats a pretty good bar to set. Some tips can handle that and some cant.
With that in mind, after the correct answer of a flathead screwdriver, Im still going to say Shaman, sabre ground endura, and whatever h1 salt you like to beat on.
Larry_Mott
Postby Larry_Mott » Fri Oct 18, 2019 12:57 am
Can't believe that's a serious question so my answer will be accordingly:
The Des Horn or Civilian
//Eva Mott R.I.P.
JacksonKnives
Location: Formerly Alberta, now Orange County, California
Postby JacksonKnives » Fri Oct 18, 2019 1:44 am
Rock Lobster would be OK for some light prying without snapping the tip, but if the internet finds out they'll hunt you down...
archangel
Postby archangel » Fri Oct 18, 2019 2:43 am
Darn Dao
Michael
The count is 33 / 32
Pelagic
Postby Pelagic » Fri Oct 18, 2019 5:08 am
Byrd Rescue 2. Pry open a paint can (or d*** near anything) without worry. What a work knife. Stout sheepsfoot sabre grind. Strong design, cheap, reliable, great performer (spyderedge).
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
Woodpuppy
Postby Woodpuppy » Fri Oct 18, 2019 5:17 am
I was going to say get a Byrd so you can replace it for less than the cost of a Lynch pocket clip.
:spyder: My other blade is a Kelly Perfect :spyder:
Ez556
Postby Ez556 » Fri Oct 18, 2019 8:21 am
Techno tip is pretty beefy too.
Likes FRN
Users browsing this forum: Albatross, Bing [Bot], Catamount123, Dazen, DTPrime, Evil D, GrandallK, Johncjeff, Majestic-12 [Bot], MSN [Bot], PeaceInOurTime and 42 guests
