Corrosion Testing of 9 Stainless Knife Steels
The Mastiff
Re: Corrosion Testing of 9 Stainless Knife Steels
Post by The Mastiff »
Just excellent Larrin! Thank you for putting the time and work into this as usual.
Larrin
Post by Larrin »
The Mastiff wrote:
Mon Oct 14, 2019 1:01 pm
Thanks!
Pelagic
Post by Pelagic »
zuludelta wrote:
Mon Oct 14, 2019 10:11 am
Pelagic wrote:
Mon Oct 14, 2019 9:54 am
Interesting conclusion for XHP. It's been quite corrosion resistant in my experience.
I think as far as conventional knife usage goes, XHP is "stainless enough" for 95% of the knife community and perhaps to less of an extent, the same can be said for ZDP-189 and CruWear (I carried a Dragonfly in ZDP-189 as my EDC for years & rusting/staining was never a problem with regular common sense maintenance).
That said, I have seen an XHP knife develop a notable layer of surface rust with some staining during constant exposure to seawater over a six-hour period, where a VG10 blade only developed minimal surface rust that was easily wiped away. I suppose in many of these steels, the corrosion resistance rating differences really only become practically apparent in more extreme conditions.
I don't know why, but my cold steel recon 1 and broken skull do very well with my highly corrosive sweat while working on the water and occasional exposure to sea water. Cruwear, in my experience, is an absolute rust bucket compared to XHP.
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
Larrin
Post by Larrin »
Pelagic wrote:
Mon Oct 14, 2019 1:11 pm
I don't know why, but my cold steel recon 1 and broken skull do very well with my highly corrosive sweat while working on the water and occasional exposure to sea salt. Cruwear, in my experience, is an absolute rust bucket compared to XHP.
Remember that high temperature tempering is common with CruWear which reduces its corrosion resistance.
Edit: And looking at my ratings table again there is a significant difference between the two steels.
Pelagic
Post by Pelagic »
Larrin wrote:
Mon Oct 14, 2019 1:13 pm
I know heat treat has a lot to do with corrosion resistance. I have no long term experience with any XHP aside from that of cold steel (one particular heat treat). But I subject my knives to a highly corrosive environment and i can say they do quite well. Absolutely better than spyderco's s30v. More similar to s110v really (but not quite as good as s110v).
Bloke
Post by Bloke »
Thanks yet again for an informative read Larrin. :)
yoteslayer
Post by yoteslayer »
Nice job. Very good info. Thanks!
Really cool stuff, thank you for sharing. This is a lot more interesting to me than how many feet of cardboard X steel cuts. There's never a time I need to cut 5,000 boxes in a single go but there's countless days during the year where my knife sits in a sweaty pocket all shift.
Surprised at how bad XHP did. I've never used it but people always reported it being pretty corrosion resistant.
:unicorn
JacksonKnives
Post by JacksonKnives »
The Meat man wrote:
Mon Oct 14, 2019 9:14 am
Here's what it looked like.
[images on page 1]
I could not clean it off. It gradually wore off after a few weeks of use.
Very interesting. There was a highly-publicized case a few years back of a China-made s35vn blade with a similar patina in nearly identical conditions (cutting meat) that many armchair experts assumed must have been "fake" steel. I think eventually they got that one tested to prove it was real. A surface finish like this (I'm assuming belt finished and then buffed?) seems to facilitate strange interactions with meat juice.
Larrin
Post by Larrin »
Just goes to show the importance of doing experiments on separate specimens made the same way rather than relying on anecdotes with knives of different heat treatments and finishes. Such anecdotes may sometimes be useful when it comes to comparing knives, but may not be reliable in terms of understanding how steels compare.
Pelagic
Post by Pelagic »
Larrin, what if XHP contained 2% vanadium? Would it likely be much more corrosion resistant? Since vanadium forms carbides more readily, would this result in fewer chromium carbides and this more free chromium in the matrix?
I feel 16% is a lot of chromium, however with 1.6% carbon and no other carbide formers, the amount of free chromium takes a big hit.
The Meat man
#32
Post by The Meat man »
JacksonKnives wrote:
Mon Oct 14, 2019 9:49 pm
[images on page 1]
Yeah it seems that under certain conditions, meat juice will react with even "stainless" steel. I recall fellow member TkoK83Spy experiencing similar discoloration on M390, from the same cause.
- Connor
Ankerson
#33
Post by Ankerson »
The Meat man wrote:
Tue Oct 15, 2019 8:38 am
[images on page 1]
In the end we have to remember it's stain----less..... Not stainless...
All steels will and can rust, stain etc, with the only real exception being H1 and that's not steel per say.
#34
Post by JD Spydo »
Another super thread Larrin :) Now this brings up a subject I've been meaning to talk to you about for some time now. There was a machine tool shop I worked at some time back where we did all kinds of testing. We had every type of hardness tester along with toughness testing equipment. But we had a chemical compound that some of the guys that worked there did corrosion testing with. The chemical compound was called "Aqua Regia" and they used it solely for testing corrosion on metals and coatings.
I'm just wondering if that "Aqua Regia" played a role in your testing?
#35
Post by JD Spydo »
The Meat man wrote:
Mon Oct 14, 2019 8:39 am
Excellent article Larrin. Very interesting to see CTS BD1N way up there. I've not had any rust with it, but I have had it patina after cutting some pork chops.
Thanks as always for your contributions!
That's interesting Meat Man because over the years I've found that food acids and fats and other compounds from meat, poultry and fish all seem to have their own strange effects on various blade steels and other metals.
ZDP-189 being one of the very worst I've encountered as of yet.
Larrin
#36
Post by Larrin »
JD Spydo wrote:
Tue Oct 15, 2019 9:07 am
Aqua regia is one of the acids that Crucible has used in their corrosion testing. I used their data including the aqua regia tests in my previous corrosion article. In my testing I did not use it.
Larrin
#37
Post by Larrin »
Ankerson wrote:
Tue Oct 15, 2019 8:42 am
Why isn't H1 steel?
JonLeBlanc
#38
Post by JonLeBlanc »
Really interesting article, and one that has a definite bearing on practical concerns!
Ankerson
#39
Post by Ankerson »
Larrin wrote:
Tue Oct 15, 2019 10:39 am
Why isn't H1 steel?
It's an alloy, we all had this discussion a very long time ago, like 15 years ago or so.
That's why I said per say...
I don't remember all of it, Sal can likely ring in with more info I think.
Larrin
#40
Post by Larrin »
Ankerson wrote:
Tue Oct 15, 2019 11:27 am
Most any steel can be called an "alloy steel." H1 is a steel.
