Shaman clip brittle?
Pelagic
Postby Pelagic » Thu Oct 10, 2019 5:35 pm
So I caught my Shaman's pocket clip on something today at work and it got bent outward. I just now tried to bend it back to its original position, and it broke at the screwholes before I had fixed the bend. I have never had any spyderco clip do this. I have always bent them and fixed them with ease. It seems like the Shaman clip is higher hardness than most clips and has far less malleable/ductile. I had no idea they were this fragile. It wasn't even bent that badly.
I've never wanted or needed an aftermarket clip, but now I do. There's no way I want another clip this brittle. What options do I have? The Shaman has a unique clip so I know there can't be many. I hope the issue I have with the Shaman's clip is a unique thing. Spyderco's best clip IMO was the pre-CQI military. Post CQI, the clip got thinner and poked out more to be more easily snagged on things. To me even byrds have better clips than this.
The bonus is, the Shaman's ergos go through the roof with no clip.
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
zippifish
Re: Shaman clip brittle?
Postby zippifish » Thu Oct 10, 2019 5:39 pm
Checkout MXG, if I were to buy a Shaman I would automatically replace the clip with a MXG deep carry clip.
Pelagic
Postby Pelagic » Thu Oct 10, 2019 5:43 pm
Thanks, I will!
jpm2
Postby jpm2 » Thu Oct 10, 2019 5:49 pm
They must have made that clip out of s110v.
Pelagic
Postby Pelagic » Thu Oct 10, 2019 6:01 pm
Seriously! Quite corrosion resistant as well. Haha!
SpyderPhreak
Postby SpyderPhreak » Thu Oct 10, 2019 6:06 pm
Odd. Strangely enough, while my M4 Shaman has seen a good bit of pocket time since I got it, it is one of the few pocket knives I've had that I haven't caught the clip on something and bent it.
"Engineers don't idle well."
Thank you to our Veterans!
Postby TkoK83Spy » Thu Oct 10, 2019 6:40 pm
Go figure, and it's such a unique clip instead of the standard clips so it's not easy to just swap with another. A couple of you already experiencing problems worries me with my 4V I just got last month.
23 :spyder:'s in 14 different steels
2 - Bradford Guardian 3's (Wharnie Vanadis 4E and 3V/Drop Point)
1- Zero Tolerance 0470
1 - Microtech Ultratech DE OTF
1 - Benchmade 940 (BHQ Exclusive/M4)
1 - WE Knives Gentry
Pelagic
Postby Pelagic » Fri Oct 11, 2019 3:06 am
Yeah. Quite a few times, it ALMOST got snagged and the clip "won the battle" so to speak. This was the very first time the clip ever got bent outward. Just be careful fixing yours if it ever happens. If you're bending it and it feels like it's about to snap, it is.
zhyla
Postby zhyla » Fri Oct 11, 2019 4:36 am
There isn’t a lot of steel there around those screw holes. If you clamp the mounting section in a vise and bend clip section I suspect it would have bent fine.
Larry_Mott
Postby Larry_Mott » Fri Oct 11, 2019 4:41 am
Order a new clip from SFO. I bet it was a fluke.
//Eva Mott R.I.P.
curlyhairedboy
Postby curlyhairedboy » Fri Oct 11, 2019 6:25 am
I've done a lot of clip swaps on shamans and have bent them for better retention on slicker material - there might have been a defect at the screwholes already. I hope SFO will hook you up!
EDC Rotation: PITS, Shaman, CF S90v Shaman, Ikuchi, Amalgam, CruCarta Shaman, DLC Lil Native, Sage 5 LW, 4V Shaman, Watu, Rex 45 Shaman, Rex 45 Lil Native, Serrated Caribbean Sheepsfoot CQI, Tanto PM2, Serrated Shaman, XHP Shaman
Always in Pocket: Hawkbill Dragonfly 2 H1
Fixed Blades: Proficient, Junction, Waterway
Special and Sentimental: Southard, Squarehead LW, Ouroboros, Calendar Para 3 LW, 40th Anniversary Native, Calendar Watu
Would like to own again: CQI Caribbean Sheepsfoot
Wishlist: Smallfly 2, Shaman Sprints!
araneae
Postby araneae » Sat Oct 12, 2019 8:13 am
Ditto
-Nick
Just got: Zcarta Shaman
Monty
Postby Monty » Sat Oct 12, 2019 9:42 pm
Sounds like a good opportunity to test out the MXG deep carry clip for us. I tried one on a delica and the retention was horrible, like it would fall out of my pocket sitting down on the couch bad. Maybe it's better on the Shaman.
Users browsing this forum: Bing [Bot], Google [Bot], sgtcole69 and 40 guests
