What is meant by "distal taper"?
JonLeBlanc
Post by JonLeBlanc »
In the spirit of the question asked recently about "detail work," I'd like to ask if I may, what is meant by the descriptive phrase "distal taper" (when referring to blade geometry)? I understand the concept of "distal" in general re "distal vs proximal" but I see the phrase "distal taper" used to describe many knife blades, and to be honest I've seen it misspelled quite a few times, which makes me wonder if not everyone entirely understands the idea that is trying to be conveyed. I certainly do not understand, but I'm a shoeless peasant so... Can anyone help me out?
Re: What is meant by "distal taper"?
When the blade is ground thinner from the pivot going towards the tip of the blade. This is a common feature on most Spyderco knives if you look at the blade thickness from the spine. On some blade shapes like a leaf shape or wharnie the blade is going to get thinner towards the tip regardless because the point of the blade is lower and down where the blade is ground down to an edge but that is not distal taper. An example of this is the Sliverax or most any saber or hollow ground blade.
araneae
Post by araneae »
Distal taper on left
-Nick
Last in: N5 Magnacut
koenigsegg
Post by koenigsegg »
araneae wrote:
Sat Oct 05, 2019 11:55 am
Maybe just me but the image isn't showing
Xplorer
Post by Xplorer »
Here's a Waterway next to a custom version, both with distal taper. The spine is thickest at the handle and tapers toward the tip.
@ckc_knifemaker on Instagram.
dj moonbat
Post by dj moonbat »
Distal taper is when the blade stock gets thinner as it gets farther (more distant) from the grip. Proximal taper would be when the stock thins as it gets closer to the grip. Because a lot of people don't know what "distal" actually means, you'll sometimes hear ANY taper in stock thickness along the length of the blade referred to as a distal taper.
JonLeBlanc
Ok thanks y'all, that's quite clear now.
