Idea: Lanyard Tube Removal Tool
ZrowsN1s
Re: Idea: Lanyard Tube Removal Tool
Postby ZrowsN1s » Sat Aug 24, 2019 9:29 pm
Bloke wrote:
Sat Aug 24, 2019 6:09 pm
Hey Matt, I’ve never popped a lanyard tube but a purpose made punch like you and Pat describe, a piece of wood with a hole in it and hammer will do the trick every time. Perhaps if you had a few to do a simple press, maybe something like this (not to scale, crumby) sketch should work and maybe even be used to flare tubes as well with a conical Pin and ‘Anvil’ made to fit the hole in the Block.
It’d be an easy enough project for any of the closet engineers here with access to a small lathe and mill I’d reckon.
The Block could be machined from mild steel 50mm x 50mm x 25mm.
The Screw could be turned from say, a 12mm fine thread automotive bolt, drilled Ø3mm x 2 places to except the Pin and Ø3mm Rod.
The Pin could be brass and turned with square shoulders like Pat’s punch and three diameters, (a) To fit screw with clearance. (b) Smaller than the lanyard hole diameter in the G10 Scale. (c) Smaller than the bore diameter of the lanyard tube. :rolleyes:
Nice design Alex!
I ❤ The POLICE :spyder:
ZrowsN1s
Postby ZrowsN1s » Sat Aug 24, 2019 9:40 pm
I suppose in the grand scheme of things, it is possible to remove a lanyard tube, and reflare it if need be if you have the right tools. This was my first try at it, and I'm sure I'll get better with practice. Maybe there is also the factor of most people not taking apart their knives to consider..... Still I'm left with the feeling that there has to be a better way to hold a handle together than a flared tube you cant easily remove or put back. A purpose built tool is a good solution to the problem, but it would be better to eliminate the problem. I don't take my knives apart often, but when I do, I would like it to be a little less of an ordeal. (Maybe this post would be better in the taking knives apart thread :o )
Bloke
Postby Bloke » Sat Aug 24, 2019 10:51 pm
Nice design Alex!
Ah, hahaha, Thanks Matt! :o
I have a lathe but no mill, otherwise I’d happily make one with a conical Pin and Anvil too so you could flare new tubes as well and send it to you. :)
Postby Sharp Guy » Sat Aug 24, 2019 10:56 pm
I've already figured I could reduce the length of the punch I drew and use it as a mandrel with my arbor press. Drill an oversized hole in a block of wood to rest the scale on and push the tube into. I've done things like this plenty of times back when I worked in manufacturing. I have no doubt it would work just fine. No need to over complicate it.
Bloke
Postby Bloke » Sat Aug 24, 2019 11:11 pm
Certainly agree Pat. We were always make little jigs and simple little tools for all sorts of reasons when I worked in my trade.
If I was into changing out scales regularly I’d make something like what I sketched because it wouldn’t take long and I could use it to pop lanyard tubes in a controlled manner and flare new tubes as well. :)
jacala
Postby jacala » Sun Aug 25, 2019 4:01 am
What about using a Drill Press.
Put a 6 inch piece of s/steel tube(correct dia.) in the chuck and press out the lanyard tube.
Use a hollowed out piece of wood underneath.
The reverse could work also(to reinstall the lanyard tube)
PS , I don't think this has been suggested before ??? Excuse me if it has.
PStone
Postby PStone » Sun Aug 25, 2019 8:22 am
^^This!^^^ It is exactly what I had pictured in my head when I suggested a beefed up link pin removal tools. Nice sketch! I would def buy one.
Postby Sharp Guy » Sun Aug 25, 2019 11:58 am
What I show in the drawing could be easily chucked in the drill press and used to press out the tube. The end of the tool fits inside the tube. So it's basically self centering.
ZrowsN1s
Postby ZrowsN1s » Sun Aug 25, 2019 12:32 pm
That self centering part is important. I think thats part of the reason the wooden dowel and the metal bit I used marked the tube up so much. It was hard to keep it centered.
Bloke
Postby Bloke » Mon Aug 26, 2019 12:59 am
Hi McGit, Pat’s simple punch would be all you really need to pop lanyard tubes. I think the main advantage of a simple little screw press similar to what I envision would allow for controlled flaring of new tube too. :)
standy99
Postby standy99 » Mon Aug 26, 2019 7:02 am
Mare uses a wooden spoon handle. Works a treat... jams it in and twists
PStone
Postby PStone » Mon Aug 26, 2019 8:16 am
I agree, but that’s why I think your design is so good, and I like it so much. It would allow for controlled removal of the tube, controlled reinstalling, and controlled flaring. All from that one tool. I can even imagine using it to flare tubes that were never flared and rattle(Advocate, Spydiechef, etc).
I’m always apprehensive about tapping them. I messed up a g10 military scale around the tube doing that. Probably operator error, but would be nice to lower that risk.
fanucman
Postby fanucman » Mon Aug 26, 2019 9:54 am
One of the punches in a transfer punch set could be the right size but I haven’t checked.
Woodpuppy
Postby Woodpuppy » Mon Aug 26, 2019 3:29 pm
A set of dies designed to be used in a single stage or turret press would be perfect. The Lee universal expanding die would work to reflare a lanyard tube quite well.
:spyder: My other blade is a Kelly Perfect :spyder:
Crux
Postby Crux » Mon Aug 26, 2019 11:05 pm
What I do is to use a rounded and tapered metal dowel slightly larger than the tube inner diameter and then tap that gently (somewhat) on whatever side of the tube I want to separate from the handle. What this does is retract the outer bevel of the tube just enough to allow the handle to be separated from the tube with some effort. The key is that the tube is still in good enough shape to lock back in after you are done. If not then use a metal dowel the size of the bevel to tap it down.
ChrisinHove
Postby ChrisinHove » Wed Aug 28, 2019 7:13 am
I’ve pulled wheel bearings just using a simple nut and bolt, and a selection of (and occasionally trimmed down) washers. I would try a machine screw and wingnut version for a lanyard tube.
I’m lucky enough to have a nut and bolt shop nearby with an incredible amount of stock for the construction, automotive and restoration trades.
ZrowsN1s
Postby ZrowsN1s » Thu Aug 29, 2019 12:13 pm
Someone showed me a youtube video of RCbladeworks using a screwdriver to remove the tube. He inserted the shaft of screwdriver into the lanyard tube and used the leverage to wiggle both sides of the tube free. Seemed to work pretty well. Don't know how much it would mark the tube up. You could always wrap it in painters tape.
Postby Sharp Guy » Fri Oct 18, 2019 9:05 pm
jacala
Postby jacala » Fri Oct 18, 2019 10:34 pm
Just bought one.
I'm not into changing my Spydies much, but.....
Better to have the right tools just in case !
ZrowsN1s
Postby ZrowsN1s » Sat Oct 19, 2019 1:42 am
Mine arrived the other day. I'll be prepared next time I take apart a para.
Users browsing this forum: Bing [Bot], bobnikon, foofie, FullScaler, Mike Blue, ryxlyx, sal, slick228, Spydergirl88 and 46 guests
