POLL: Who´d like to see a knife along the lines of the Caribbean, but with a BACKLOCK?
Caribbean(-like) BACKLOCK knife (edge all the way back to the handle, wide and neutral handle..)?
- No, I am not interested in such a (backlock-) model
34
32%
- Yes, I´d like to see such a model in linered G10
14
13%
- yes, I´d like to see such a model in linerless G10
20
19%
- Yes, I´d like to see such a model in linered FRN
12
11%
- Yes, I´d like to see such a model in linerless FRN
22
21%
- Yes, I´d like to see such a model in another handle configuration (specify, if you like)
3
3%
Total votes: 105
The Caribbean has at least two features, that I find very attracting and that are hard to find in any other Spydie of that size- and price category:
1.) No choil, no Ricasso, edge going all the way back to the handle (great closed-length-to-edge-ratio plus good for very precise work close to the hand in a regular, handfilling grip on the handle)
2.) Very neutral, wide, comfortable and handfilling handle
Plus: Blade shape and size that I personally like the most in my main EDC folders.
As far as I am aware of, there is no model like this coming with a backlock, which I prefer by a lot over the comp. lock (even more so in bigger work knives, meant to be used in harder outdoor tasks, especially with gloves).
I´ll leave it open, which steel such a model would come in, but let´s say LC 200N would be one option for sure.
So: Who´d like to see a knife like the Caribbean, but featuring a backlock? [YOU MAY CHOOSE MORE THAN ONE OPTION]
Re: POLL: Who´d like to see a knife along the lines of the Caribbean, but with a BACKLOCK?
Having never owned or even handled the Caribbean due to the size and compression lock, I'd be interested in the XL version with a backlock and linerless frn. (Though, I don't have a strong opinion either way on liners.)
I would like to see a larger knife without the 50/50 choil. It just doesn't seem necessary...
curlyhairedboy
Post by curlyhairedboy »
The caribbean's use case seems to leverage the flow-thru abilities of the compression lock. Plenty of salt models have had a chance to leverage the backlock without issues, but the caribbean might be a different approach for a reason. Still, something like a native chief salt might be what you're looking for?
Caribbean with the same overall shape but with a linerless FRN handle with the bidirectional texture instead of the pattern the G10 uses, plus a back lock, and I'm in.
steelcity16
Post by steelcity16 »
1.000,000% YES!! Any of the configurations I would buy, but my preference is a Toxic Green linerless FRN/FRCP Carribean Salt in FFG PE and SE LC200N! These would easily be my most carried/used knives. I love my Tenacious, but I prefer LW backlock Salt knives, so this would be a dream configuration. There needs to be some choil-less LW FRN models in the lineup. I've said many times that a Tenacious LW made in Golden or Seki with a steel like Cruwear or a Salt version would be an amazing knife.
I’m probably the only one, but if the only difference from the Caribbean it’s going to offer is a backlock, it seems like a redundant addition to the current catalog.
With that said though, I could imagine what Evil D described fitting into the catalog pretty seamlessly. Especially after seeing how good the Police 4 in bidirectional FRN looks.
Is there enough room in the Carribean handle for a backlock to fit though? Part of the advantage of the compression lock is how easily it can be implimented into certain designs.
The caribbean has a brilliant handle, useful blade shape, I love the choil free design, and it uses one of my favorite steels.
If there was a backlock variant, I'd own multiples. The lock is the only thing keeping me from owning them.
Mushroom wrote:
Wed Aug 14, 2019 10:31 am
I'm no engineer but I think there is. The cutout on the tang for the compression lock notch takes up about the same amount of space, it would just be rotated around about 90 degrees so the notch is on top instead of in the back.
I'm really not a big fan of back locks, my interest is more in the FRN grip and simplicity of it and possibly lower cost. I already have two Caribbeans but I'd need a third if this happens. Honestly the biggest issue I can see is possibly making the Pacific obsolete, but I may just be biased there.
curlyhairedboy wrote:
Wed Aug 14, 2019 10:03 am
The caribbean's use case seems to leverage the flow-thru abilities of the compression lock. Plenty of salt models have had a chance to leverage the backlock without issues.
I don't see a benefit in a Salt model personally. If my Pacific Salt gets dirty or has gritty action, I can submerge it in water or blast it out with a pressure washer on low. Or throw it in a dishwasher. If it comes down to it, pop out two screws and you've taken down the knife.
The Pacific would still have its place. Anyone that thinks LC200N is better than H1 across the board is sorely misinformed.
bearfacedkiller
Post by bearfacedkiller »
There is a reason that Backlocks don’t usually have sharpened edge all the way to the handle. They usually use a kick on the ricasso to stop the blade from closing too far. The Centofante is an exception and if you squeeze the blade closed all the way it hits the backspacer which is tolerable because the backspacer is frn. That was a collaboration and I believe Centofante wanted it that way. I don’t think that we will see an in-house design without a kick.
The Caribbean, Polestar and Alcyone are all new models meant to address folks’ desire for more sharpened edge on their blade and they are liner/comp locks and probably for a reason.
bearfacedkiller wrote:
Wed Aug 14, 2019 10:42 am
This is a good point, but it's a point made 100% moot by the fact that Spyderco and other companies have engineered lockbacks with internal stop pins. There is no need for a kick with one.
bearfacedkiller
Very true, the internal stop pin would solve that issue.
If cost and engineering weren't an issue I'd love to see the cutting edge on choil less backlocks extended, and switch them over to internal stop pins. The Pacific Salt would be even better with another 1/2" of cutting edge. I know one user in particular that could get on board with this idea :D
....Still, something like a native chief salt might be what you're looking for?
Thanks for your reply, but... no ;)
I really like the design of the Chief (had no chance to actually handle one though), but as said in my op: What I'd want to see transferred to a backlock knife from the Caribbean is specifically the edge going all the way to the handle plus the wide, neutrally shaped handle...
Vivi wrote:
Wed Aug 14, 2019 11:35 am
Really? Who on earth could that possibly be?? :D :D
Vivi wrote:
Wed Aug 14, 2019 10:51 am
Vivi, that's not YOUR Chap??!! :eek:
steelcity16
I agree, and I know you like H1 and i do too, but I would love a Pacific Salt with FFG LC200N with a full length cutting edge. I'd get both SE and PE versions.
wrdwrght
Post by wrdwrght »
Just as I think not every Spydie model should become a Salt, I don’t think every one should feature a lockback, much as I like that lock.
I’m quite content to let Sal and Eric call the shots. I could say more, but won’t...
steelcity16 wrote:
Wed Aug 14, 2019 11:45 am
That would be great!! In my case not so much for the LC200N (VG10 would be fine with me), but for ffg and full length edge in essentially an Endura! I still don't have a Pac. Salt, but I figure the handle is at least as good as the Endura 4 handle.
wrdwrght wrote:
Wed Aug 14, 2019 11:46 am
Not EVERY Spydie model needs a lockback, but at least ONE SINGLE backlock knife in the Endura / Caribbean size class and in a decent steel, but still affordable, should have an edge going all the way back to the handle (and no choil or Ricasso)...
