Salt vs Salt 2
Pelagic
Re: Salt vs Salt 2
Post by Pelagic »
Jazz wrote:
Thu Jul 18, 2019 7:52 am
Pelagic wrote:
Thu Jul 18, 2019 7:45 am
How does something sharp snag on something cuttable?
That makes no sense. Cardboard sucks with serrations in a lot of cuts. A lot of things get hung up - just not as smooth as PE. They can be great, if very sharp and used right. Nothing flies through a heavy nylon belt like SE, when pulled through, not sawed. Anyway, not wanting to start an argument here. I love sharp serrations.
Those pics aren’t accurate of the two Salts. My Salt 1 has very aggressive and pointy serrations - the 2 doesn’t.
Obviously there will be things SE/PE blades excell at, but making serrations less pointy won't make the SE blade some great cardboard cutter, just like even a hair whittling 400 grit plain edge will never cut rope like a hair whittling serrated edge. But also, an extremely sharp SE blade will pushcut cardboard clean.
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
anagarika
Re: Salt vs Salt 2
Post by anagarika »
Surfingringo wrote:
Thu Jul 18, 2019 4:20 am
bbturbodad wrote:
Wed Jul 17, 2019 11:31 pm
Thanks guys!
I'm torn because I have a fairly "meaty" hand (thick fingers) so I wouldn't mind the longer handle of the Salt 2 but I find most knives with rounded (I call it pointy because starts jabbing into me by the end of the day) handles uncomfortable to carry IWB which is how I carry.
Oh and yes, the Salt 1 is still around and the sale price of $70 is what caught my attention ;)
I carry a Salt 2 IWB (at 1:00) on a regular basis, often for extended hours sitting in a kayak, and it has been completely comfortable for me.
I’m guessing OP carries his perfectly vertical not slanted, and probably at 3 or 4 o’clock. In that format, the flat butt of Salt1 handle is more comfortable.
Chris :spyder:
bbturbodad
Re: Salt vs Salt 2
Post by bbturbodad »
anagarika wrote:
Thu Jul 18, 2019 8:10 am
Yes, I carry vertical at 3 o'clock. Never thought about carrying slanted. Didn't know that was possible but I just tried it and WOW this could be a game changer for me!
-Turbo
James Y
Re: Salt vs Salt 2
Post by James Y »
Personally, I prefer less aggressive serrations. Besides less snagging, I've also found that less aggressive serrations are also more stable and roll over less. To each their own.
araneae
Re: Salt vs Salt 2
Post by araneae »
Surfingringo wrote:
Thu Jul 18, 2019 4:19 am
Jazz wrote:
Thu Jul 18, 2019 3:34 am
Salt 1 has more aggressive serrations too. I love them both.
Jazz, I know you’re an old hand with the Salts, but are you certain that’s true? I’ve owned a LOT of serrated Salts and I have found they ALL have different levels of serration depth and “aggression”. I could be wrong but I believe this is due to the fact that the wheel used grind the serrations wears down over time and knives ground on a new wheel will have a different serration depth (and angle) than knives ground on an older wheel.
I find they differ, but certain models seem to have more consistent grind angles than others. Some of the older byrds actually performed better than some Spyderco models IMO. Geometry counts.
-Nick
Last in: N5 Magnacut
Surfingringo
Re: Salt vs Salt 2
Post by Surfingringo »
bbturbodad wrote:
Thu Jul 18, 2019 8:42 am
Hey Turbo, try carrying at 1:00 with the butt angled in towards the groin area. The knife basically lies on the line separating the belly from the leg. That’s the carry method I adapted for my kayak fishing. I can jump in and out and even pedal in a seated position and don’t even notice it’s there.
cabfrank
Re: Salt vs Salt 2
Post by cabfrank »
I say get the Salt, because you will love it. You will have plenty of time to get a Salt 2 for your second one.
bbturbodad
Re: Salt vs Salt 2
Surfingringo wrote:
Thu Jul 18, 2019 12:11 pm
Thanks for the tip. I carried 2 knives this afternoon 1 appendix, 1 @ 3 o'clock both canted and I can't believe it never occurred to me to do this before. I didn't drive today but I think that's where appendix will really shine because the bolsters of the seats in my car are what makes the 'jabbing' really noticeable/uncomfortable.
Who'd a thought asking Salt vs. Salt 2 would've been so productive? :D
-Turbo
Jazz
Re: Salt vs Salt 2
Post by Jazz »
Well, bro, who knows? You have a good point, but every pic I’ve seen of the 1 looks like mine. Here’s a couple pics of my 1 and one of my 2’s. My Salt 1 has been sharpened a fair bit, but it was pointy and very aggressive when new.
- best wishes, Jazz.
Jazz
Re: Salt vs Salt 2
Post by Jazz »
bbturbodad wrote:
Wed Jul 17, 2019 9:15 pm
Spyderco C88SYL Salt $70
Spyderco C88SYL2 Salt 2 $85
If you look close, the pics are of the same blade here. Look at the scratch/grind pattern on the ricasso.
Pelagic
Re: Salt vs Salt 2
Post by Pelagic »
Those scratches are similar but not identical. Also, look at the H in H1 on the blade. Different color.
Surfingringo
Re: Salt vs Salt 2
#32
Jazz wrote:
Thu Jul 18, 2019 6:10 pm
Interesting. I have no idea, they may have changed something with the new salt 2. I do know for a fact though that all of the Pacific salts vary to some degree. Personally I kind of prefer the less aggressive serrations for my work. What is more important to me is that they are sharpened at a low enough angle that they are easy to microbevel.
And yes, I would agree that those are the exact same blades in those two photos.
Pelagic
Re: Salt vs Salt 2
#33
Post by Pelagic »
I would prefer the more aggressive serrations. The more aggressive they are, the more likely I am to buy a sharpmaker to make sharpening much simpler. If the serrations are not aggressive, I feel the need to do what I do currently (sharpen each serration individually), which is a tedious process. Since the sharpmaker naturally reduces the pointy-ness of the serrations, I'd like for them to start out deeper and pointier. I feel like more aggressive serrations are more effective at slicing a large rope in a single fast draw cut in an emergency situation. I also like the more robust tip of the black salt knife. You can tell it has plenty of piercing power while having a stronger tip. Also, you will lose slightly less blade length with each sharpening (whenever I get a knife I initially plan on keeping it a very long time).
Re: Salt vs Salt 2
#34
Wasn't it confirmed at some point that the wheels that grind serrations wear over time and this changes the pattern over time? I just had a second Caribbean for a couple days and the pattern on it was very different from my other one.
anagarika
Re: Salt vs Salt 2
#35
Post by anagarika »
When i carry IWB at 3-4 o’clock, I like them tip down. It’s lower and easier to grab & pull out, pinching with just thumb and index finger. Just to offer another variable.
Chris :spyder:
tonijedi
Re: Salt vs Salt 2
#36
Post by tonijedi »
Tried the Salt (1) in a brick and mortar store and I didn't like the handle as much as I liked on my Delicas, so I went with the Salt 2. Now, the handle on the Salt 2 is a bit different from the Delica's but on normal use you can't even notice.
Pelagic
Re: Salt vs Salt 2
#37
Post by Pelagic »
I've been looking at the Atlantic Salt and the Pacific Salt. I really prefer a sheepsfoot blade (safer on the water), as the knife would be a rope cutter. But I also need a 4" blade for ropes 5" in diameter. Unfortunately I think this leaves me with 2 choices. Continue to use my byrd rescue 2's (I'd prefer H1 steel), or find a Jumpmaster 1 (extremely hard to find). Even if I could find an original jumpmaster I'd prefer a folder so it doesn't snag on things as easily. Basically an atlantic salt XL would be perfect for my needs. Are there any other options I'm overlooking?
I guess a sheepsfoot Caribbean is an idea, but I'm itching to try H1 and the Salt's are much less pricey. I was also looking to get a PE Caribbean in the future so that deters me from getting a SE model.
Edit: you know... The Pac Salt's tip isn't THAT pointy I guess. And I could always modify it easily if I ever cared to. That may be the answer.
wrdwrght
Re: Salt vs Salt 2
#38
Post by wrdwrght »
Pelagic wrote:
Sat Jul 20, 2019 8:02 am
https://www.countryknives.com/shop-by-d ... pyderedge/
Pelagic
Re: Salt vs Salt 2
#39
Post by Pelagic »
wrdwrght wrote:
Sat Jul 20, 2019 9:09 am
Thanks! That is pricey though, haha.
wrdwrght
Re: Salt vs Salt 2
#40
Post by wrdwrght »
Pricey, yes. Seems perfect for your kind of work, though. You probably wouldn’t need another before you retire...
