You can run any model you want in LC200N. Which do you choose?
Re: You can run any model you want in LC200N. Which do you choose?
Post by JD Spydo »
elena86 wrote:
Sat Jul 06, 2019 7:21 am
Millie
I could go for that if they would also make a Spyderedged version too.
I do believe we'll see a Millie in a Nitrogen based blade steel within the next year or two.
ferider
Post by ferider »
A fluted Ti Military, so I don't have to worry about liners or lock corroding.
Then again, already have one in S110V, that's darn close wrt corrosion-resistance, and harder and more wear resistant. Maybe I don't need the LC200N Military after all :)
Another vote for the PM2, hopefully FRN LW with wire clip.
A yellow Manix2 LW seems inevitable (and awesome) :)
The Mastiff
Post by The Mastiff »
A model that already has FRN as an option. I prefer a backlock as well. An Endura or Stretch for me.
tonijedi
Post by tonijedi »
Salt 2
Ankerson
Post by Ankerson »
Vivi wrote:
Sat Jul 06, 2019 1:47 am
If you could pick any model to sprint run in LC200N, which would you choose?
I'd go with the Native Chief. With the linerless construction I think it would be easy to turn it into a full fledged Salt. I'm planning to pick one up in S30V but LC200N would make it even more special.
Secone choice would be a Police 4 Lightweight.
Which model would you like to see in LC200N?
Military Salt. :cool:
SpyderEdgeForever
Post by SpyderEdgeForever »
Paramilitary and Military Tanto
Endura
Pacific Salt
Caly 3.5
Native Salt with original Swedge False Edge
Aqua Salt
Caspian Salt Pointed
All of the above in Lc200N.
Pickmansmodel82
Post by Pickmansmodel82 »
IF I had my druthers I’d like to see an endura sized blade warnie with red frn. Maybe if I Reallllly shot for the moon, blade shaped like Yojimbo 2, as opposed to hump backed warnie.
ZrowsN1s
Post by ZrowsN1s »
PE Hawkbill Dragonfly, Dragonfly, wharncliffe Dragonfly..... and the Chief.
knivesandbooks
Post by knivesandbooks »
Slysz Bowie Salt.
Pelagic
Post by Pelagic »
knivesandbooks wrote:
Sat Jul 06, 2019 12:23 pm
Slysz Bowie Salt.
Wow... K2 salt?
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
knivesandbooks
#32
Pelagic wrote:
Sat Jul 06, 2019 1:05 pm
Slysz Bowie Salt.
Wow... K2 salt?
I would do that too.
We need more than one higher end titanium salt option
vaisforlovers
#33
Post by vaisforlovers »
Dyad Salt, FRN, light weight. The ultimate tackle box knife.
I’ve been lobbying for a Dyad Salt for a decade. I’d settle LC 200N over H1 :)
#34
I don't need the corrosion resistant properties of LC200N, but if I was to choose in which knives to try it, than I'd opt for 3 of my 4 my most carried and used models: Endura 4, Stretch 1, lately Endela SE.
Concerning the Chap FRN (number 4 of my most carried): The HXP steel is so perfect for me, would not like to see it in another ever.
ejcr98
#35
Post by ejcr98 »
G-10 Para 3 with bright red scales but fully salted a la Caribbean.
Nate
#36
Post by Nate »
I'd like to see the LC200N UKPK that's been talked about happen. Might pick up a Native Salt soon.
:spyder:
steelcity16
#37
Post by steelcity16 »
Chap LW Salt with DLC LC200N blade/hardware and neon day glow glow in the dark yellow FRN scales
zippifish
#38
Post by zippifish »
Chap LW to throw in the board shorts pocket when at the beach or on the boat, DF2 PE would be a close 2nd and the Native Chief just because.
#39
Chris_P_Bacon wrote:
Sat Jul 06, 2019 6:47 am
The four that still sit on my want list are;
PM2
Swick 5
Catcherman PE
Catcherman SE
Swick 5 is in the works (LC200N), last time Sal mentioned it he said they were shooting for a 2019 release.
:unicorn
xceptnl
#40
Post by xceptnl »
My choices would be:
Military
Caly Jr.
Spyderhawk (PE & FFG)
*Landon*
