Post up your Rit dye projects..
Re: Post up your Rit dye projects..
Postby ladybug93 » Mon May 27, 2019 8:05 pm
i like that green!
gibs0n
Postby gibs0n » Wed May 29, 2019 11:07 am
FRN UKPK. Previously modded with smooth natural g10 “jade” scales from Cuscadi. Dyed today in RIT DyeMore Peacock Green for 10 minutes. I may do another round and go slightly darker.
Ruudr
Postby Ruudr » Tue Jun 04, 2019 11:38 am
Spyderco Alcyone with a modded blade and black handle scales
DukeNiemand
Postby DukeNiemand » Mon Jun 10, 2019 4:33 pm
Fresh Maxamet PM2 grey G10 after about a minute in teal RIT dye.
bearrowland
Postby bearrowland » Tue Jun 11, 2019 9:37 am
Very nice 👍👍
Barry
:spyder: :spyder: :spyder:
racuda00
Postby racuda00 » Thu Jun 13, 2019 4:54 pm
Here's my orange Dragonfly.The florescent orange was peeking out of my pocket like a shining beacon so I did a Dark Brown, Cherry Red fade. The photo looks like three distinct sections but it is a smooth transition in real life.
Crux
Postby Crux » Mon Jun 17, 2019 12:43 pm
Very sweet!
40mm
Postby 40mm » Fri Jun 21, 2019 10:53 pm
What color Rit dye did you use for this?? Also how long was it in the dye? Looks awesome.
T-1000 wrote:
Mon Apr 22, 2019 6:46 pm
Was going for a bright orange, turned out kinda pumpkin spice. My 6 year old said it looked like rust, and I love the irony in that.
DukeBrnz
Postby DukeBrnz » Tue Jul 09, 2019 8:31 pm
This is totally awesome. I’m looking at dying my Tasman with Tangerine Orange and Cherry Red RIT. I’d love to achieve a similarly smooth faded transition on mine. Any tips?
JuPaul
Postby JuPaul » Wed Jul 10, 2019 6:23 am
My first RIT attempts: the Byrd with "evening blue", the salt Dragonfly with "violet" which turned an awesome garnet red. Wish I'd left more yellow at the top of that fade, but oh well. And to answer a previous question, I didn't bother removing the scales on the salt. But make sure to clean the insides of the scales well if you do that. I left some spots of lube on the inside around the pivot and the dye didn't take there.
- Julia
Sober_Survival
Postby Sober_Survival » Wed Jul 10, 2019 7:52 am
Great job!
There is no greater love than to lay down one’s life for one’s friends. John 15.13
racuda00
Postby racuda00 » Wed Jul 10, 2019 1:19 pm
Keep it moving and let your eyes be your guide. My colors were cherry red and dark brown.
T-1000
Postby T-1000 » Sun Jul 14, 2019 12:00 pm
Thanks, I used tangerine orange and it sat in there a good hour or so. The longer it sat, the more “rusty” it looked.
Ngati Pom
Postby Ngati Pom » Sat Jul 20, 2019 11:04 pm
Testing, testing. First upload.
'The future is already here;it's just not evenly distributed'
William Gibson
Doeswhateveraspidercan
Postby Doeswhateveraspidercan » Wed Dec 18, 2019 12:35 pm
I figured with the holidays coming off and some time off this excellent trhead deserves a bump. I had failed to subscribe to it in the past and currently have need of this information for a project involving changing the Jade Scales on a Blade H.Q. Dodo I recently purchased.
This is one of the best resources I have ever seen so here you go hop this helps someone with a holiday project. Perhaps this thread should be made Sticky?
Monty
Postby Monty » Wed Dec 18, 2019 3:39 pm
Mine have all been simple single color jobs. The more I do, the less I overthink it. I used to submerge in boiling water but then I'd worry about the knife hitting the bottom, found I get results just as thorough dumping boiling water into a cheap plastic coffee mug from a gas station and soaking. Every couple minutes I'll swap the blade from open to closed so there's no missed areas around the pivot. A leatherman/pliers are handy to move the knife in and out of the mug. Here's a simple black dragonfly that I wanted in a more subdued color for use in public. Black is the easiest choice- no need to worry about soaking too long, just drop it in and come back in an hour.
Postby Doeswhateveraspidercan » Wed Dec 18, 2019 3:42 pm
Thanks that is a very nice consistent re-color.
DTPrime
Postby DTPrime » Wed Dec 18, 2019 5:27 pm
The salts have definitely come out best in my limited experience. Of the three I've done all came out the exact color of the box used, whereas the gray delica went maroon in the same red bath as the native and the Ivory stretch was done in teal but came out forest green. The gray frn chap took navy blue surprisingly well.
Next attempt might be a GITD delica to see if it still takes a shine through the dye job- anybody have experience with that before?
Postby Doeswhateveraspidercan » Tue Dec 31, 2019 12:14 pm
That is darn strange how real came out Forrest green on the Ivory SSS. Did you trey a different soak time? Do you think longer would provide the correct color?
JuPaul
Postby JuPaul » Tue Dec 31, 2019 12:54 pm
I tried to do a dark purple on the chap lw I had, but I couldn't get it darker than a lavender color, soaked maybe an hour. I think i just used the liquid RIT, boiling water and vinegar...did you add anything else to the mix on that one? Longer soak time?
- Julia
Users browsing this forum: Bdubs808, Google [Bot], Rab, skeeg11, Stuart Ackerman, tonijedi and 32 guests
