Just jumped on the PM2 bandwagon!
soc_monki
Re: Just jumped on the PM2 bandwagon!
Post by soc_monki »
I love this knife! Been playing with it and that's basically all lol! Cut up some cardboard and opened some envelopes, then shredded them! Still need to run it on the sharpmaker and get it screaming sharp, but for a knife that was bought a year or two ago and never used it was still shaving!
Spyderco, you constantly amaze me!
rabbitanarchy14
Post by rabbitanarchy14 »
i just got a second hand pm2 sprint s35vn. i think i like it. a little bigger para 3 basically. love my para 3. just a quick Q, what is the factory angle on the edge.
192.168.0.1 -Para 3 G10 M390 Red, Dice XHP, Lil Native Rex 45 comp, Manix 2 M390 G10 BR, PM2 M390 DLC BL, PM2 k390 RGreen, Cat BD1N, Dragonfly 2 k390
Saving for - Lil Native K390, D'allara 3, UTX-70
Instruments- Kimber EVO, SA Hellcat, SW Shield Plus 9
rbb2
Post by rbb2 »
rabbitanarchy14 wrote:
Fri Jun 07, 2019 11:23 am
I'm pretty sure all spydercos are 30° (give or take a degree or two due to small variances).
soc_monki
Post by soc_monki »
I think I read or heard Sal say they aim for 30 degrees. Which is why the sharpmaker has the 30 degree slots.
I haven't had to thin my golden spydies yet. I do need to work on my persistence though. I tried to hit it on the 40 degree slots and touch her up, but one stone was only hitting the shoulder! Time to reprofile!!
JonLeBlanc
Post by JonLeBlanc »
That's interesting; I've always wanted to know the factory angles lol
soc_monki
Post by soc_monki »
I pretty much reprofile all my knives to 30 degrees or close to it. Seems to work well for me, and makes using my sharpmaker a breeze. I really need to upgrade from my lansky though. It's a good system and does its job, just a hassle with the clamp and everything.
I really just need to get good at freehand haha!
GiftedMisfit
Post by GiftedMisfit »
Why does the sharpmaker have a 40° slot labeled "edge" and a 30° one labeled back bevel?
:cussing
GiftedMisfit wrote:
Sat Jun 08, 2019 9:25 am
I don´t know exactly what "back bevel" means, but as far as I know one of the ideas with the 30 degree slots is: If you sharpen your knife very often on the 40 degree setting (or in fact on any setting of course) it will become thicker and thicker behind the edge over time obviously. Using the 30 degree setting from time to time, you can take away a bit of that "shoulders" (not sure that´s the correct term) and thin the knife out behind the edge once more (can´t explain this better in English..)
GiftedMisfit
Does that mean the edge is 40°?
:cussing
GiftedMisfit
I understood what you were saying I think the factory edges are closer to 40?
Edit - nevermind I answered my own question lol
:cussing
soc_monki
Post by soc_monki »
The main edge bevel is 30 degrees. The microbevel is 40 degrees. It creates a stronger edge that will last longer, but still cut much like a 30 degree edge. Also quicker to touch up. After touching up 10 or so times it will get wider behind the edge, so you use the 30 degree slots to thin it out again, and use the 40 degrees to again maintain the microbevel.
Sal explains all this in the sharpmaker DVD. You can also find the videos on YouTube.
GiftedMisfit
#32
soc_monki wrote:
Sat Jun 08, 2019 10:45 am
Seems like you just did? So edge means microbevel. Makes sense.
:cussing
rbb2
#33
Post by rbb2 »
This is what happens after you sharpen/microbevel at 40° several times:
So you need to do this:
GiftedMisfit
#34
Thanks. I know. I like having the diagram pic. Honestly, thanks.
I do still think the factory edge is closer to 40° inclusive, so 20° per side?? Mind you, I did no research.
:cussing
