Wire clip thru lanyards hole -- para3?
lonerider1013
Post by lonerider1013 »
Hey looking at my para three and thinking ...they shoulda used a wire clip. Well, I wonder... the wire clips attach via a single screw. Could you just get a longer screw and mount a wire clip thru the lanyard hole? Anyone ever tried this?
lonerider
Last edited by lonerider1013 on Tue May 21, 2019 4:01 pm, edited 2 times in total.
"A fool's blade may be sharper than his brain"
“Learn to ride a bicycle. You will not regret it if you live." - Mark Twain
Re: Wire clip thru lanyards hole -- para3?
Yes you can
Spydergirl88
3 Nats, 1 Chap, 1 Sham, 1 Urb
DukeNiemand
Post by DukeNiemand »
That's a great idea! I'd love to see pics if anyone has done this.
lonerider1013
Just a demo I rigged up while watching old xfiles episodes... the screw is aluminum and can't go that tight but it still holds for now... Ideally I would cut recesses for the wire clip in the g10 but am afraid to do so. When i get a better screw will instead try to file the recesses in the underside of the screw head...
lonerider
Woodpuppy
Post by Woodpuppy »
Bottle cage bolt?
Post by JD Spydo »
Not sure this falls in line but I've thought about the pocket clips also having lanyard attachments on them for a long time now. There are Spyderco models like the C-44 Dyad which is one model that doesn't have a conventional lanyard hole like most other Spyderco models do. So I've been thinking that many models like the C-44 Dyad and others I'm thinking of should consider adapting a lanyard hole in the pocketclip itself.
Especially when you have models that you use and work close to lakes, streams, rivers, oceans ect... because I can't tell you how heart wrenching it is to have a really good Spyderco model fall overboard or in a deep water hole of some sort. To me lanyards might just be the best insurance policy you can get for your favorite Spyder ( folder or fixed blade). So wouldn't it make sense to insure you don't lose it???
lonerider1013
Woodpuppy wrote:
Tue May 21, 2019 5:39 pm
Bottle cage bolt?
No although that'd be an option, it's just an aluminum bolt I had lying around.
lonerider1013
Yes... which is why this idea isn't ideal in that it covers up the hole. I do use lanyards on some knives (though not all).
Officers Match has been doing something similar to the Military using a CRK clip. Not sure if this is helpful...
https://www.bladeforums.com/threads/mil ... t-18377524
Cscottsss
Post by Cscottsss »
Cool idea
Crux
Post by Crux »
I'm not sure I trust wire clips. I think they are shifty and will tell you lies.
Crux wrote:
Wed May 22, 2019 6:54 pm
They only shift when you bump them into a doorway :p
Spydergirl88
zhyla
Post by zhyla »
Interesting. Isn’t it clunkier than the stock clip?
I think I could come up with something a little more ideal and CNC it or 3d print it. A bushing with a tapped hole that sits in the lanyard tube with a little lip on the other end to hold it in place. But without milling out the scale and lanyard tube for clip clearance I don’t think it’s going to work great. The clip will always want to rotate.
Milling the clip recesses isn’t a big deal but you really need a mill to make it look right.
Crux
Post by Crux »
Look, pony up and get the titanium MXG clip and all is well. No need to get all wired up and then strung out. MXG makes a color for many of the 25 incredible and amazingly astounding Para 3s.
I have many wire clip knives but lately I've overheard some trash talk from them, and frankly I really don't expect this. I'm as inclusive as you can get but I'm not gonna stand for this wired revolution when the entire world is moving toward wireless.
lonerider1013
I put the stock clip back because with out the recesses in the handle scale it wasn't secure, but as a demonstration... let's just say I like those wire clips. May get a deep clip not sure.
Bill1170
Post by Bill1170 »
It seems one could make a jig to guide a small ball nose bit in a Dremel to mill the slots for the wire clip. A milling machine is going to be a lot easier, but fewer people own them.
zhyla
Post by zhyla »
Bill1170 wrote:
Tue May 28, 2019 11:52 am
I think there are dremel bits with bearings so you could follow a template as if it were a really tiny router. No idea how well that works. It would be easy to 3d print a template though.
