Replaceable blade folding mule
"So when you suggest a model for a folding Mule Team, are you thinking a new complete knife for each steel or a knife that you would change the blade?
sal"
Sal mentioned this and I thought this is an idea worth discussing further. If we had a folding knife handle that we could simply change the blades on rather easily, this would reduce cost significantly, as all we would need to do is purchase another blade. If someone wanted two knives to test side by side, they could buy two handles, as they would normally have had to buy two knives otherwise, anyway. There is another big plus, here. It is a lot easier to sell it to the wife when you tell her you have to buy a replacement blade rather than tell her you want a new knife. Haha! :D
So, what do you all think of this idea?
sal"
Re: Replaceable blade folding mule
Voted yes.Doc Dan wrote: ↑Wed May 08, 2019 11:52 pm"So when you suggest a model for a folding Mule Team, are you thinking a new complete knife for each steel or a knife that you would change the blade?
sal"
To be clear: I am not enough into steels and know way too little about this topic to be really DEEPLY interested in the Mule program, but IF such a program, the replacable blade idea is a good one.
But: Only under the premise that a) the blade swap can be done really easy and fast and b) the knife / lock up is still solid and strong
I think if we must have a Folding Mule this seems like a logical option but as with all the other polls of late the $64,000 question is; what platform?
I haven’t responded to any of the polls for a few reasons. For one, I’d prefer a fixed blade along the lines of a Sprig or Waterway and have no interest in short, squat, door stop blades.
As far a Backlocks and Slipjoints go I’m inclined to think tolerances need to be extremely tight in order to make them interchangeable and would ultimately lead to all sorts of *****ing about vertical play, lockbars sitting high, sitting low, etc. etc.
Linerlocks would likely be more forgiving but you can bet there’d be *****ing about lock up percentage, lock stick ... And it goes on.
Perhaps a Friction Folder would work, but who knows?
Personally, I think as simple as the idea of making interchangeable blades sounds, Spyderco stand to make a rod for their own back.
I vote: Indifferent.
Just my $AU0.02c worth. :)
- rabbitanarchy14
I voted yes but I would have to be open to color option handles for it too. As I would like a 3" platform like a para 3 or domino or sage. With different steel blades, and different color handles with liners no more Sprint's. Just several blade options and scale options. Build it how you want it.
192.168.0.1 -Para 3 G10 M390 Red, Dice XHP, Lil Native Rex 45 comp, Manix 2 M390 G10 BR, PM2 M390 DLC BL, PM2 k390 RGreen, Cat BD1N, Dragonfly 2 k390
Saving for - Lil Native K390, D'allara 3, UTX-70
Instruments- Kimber EVO, SA Hellcat, SW Shield Plus 9
Don't locks and blades have to mated? Even with slip joints? I'm still not clear how this would work.
- steelcity16
This is a concern of mine as well. And id rather pay a little more for complete knives. I dont want to be switching blades around all the time. Voted no.
Not my thing. I'd end up with a bunch of blades without handles or end up buying extra handles to go with them, in which case I'd just assume buy complete knives.
I'm missing the whole appeal of a folding mule. The idea is to make inexpensive knives for testing, and a fixed blade is absolutely hands down better for testing and it's the cheapest way to sell them. Then if the mule gets enough traction and positive feedback we always see those steels in popular folders so those who want a folding mule basically get one in the end, every Military made with a steel after S30V was the standard steel can be seen as a folding mule.
I do not know how it would work, either. Sal brought it up so I thought it worth talking about. He is the knife engineer so he would have to sort all of this out, if this became a reality.
From the Mule Team thread. This is the only thing I can think of to make sure the blades/locks work together, without play.Albatross wrote: ↑Tue May 07, 2019 3:08 pmNow that's a good idea. It should be even cheaper(per blade) than the fixed blade Mules were. Initial cost would be higher, but collectors and testers would save money in the long run.ferider wrote: ↑Tue May 07, 2019 2:46 pmAs I'm not really interested in the UKPK (too small), let me post here.
From Sal's comment above, it doesn't feel like a Mule folder would make business sense.
Now:
1) I have a couple (non-Spyderco) folders that can easily be field-assembled/disassembled. These are Ti frame-locks, typically.
2) One can safely assume that people buying a Mule would feel somehow comfortable doing 1)
3) Of all the Spydercos that I've maintained, the Military is my favorite, and the Ti Military probably the easiest Spyderco to assemble.
So how about Spyderco releases a Ti Military that can be assembled in the field (just needs different screws), and follows up with Military Mule blades (only) ? So you enter the program by buying the knife, and then, every so often, change the blade ?
Just a thought,
Roland.
There is one issue I foresee with this though; fitment. Sometimes a blade swap means blade play, since there will always be slight variances in the tolerances. This is probably enough to keep people from accepting the idea.
If it could be done in a way that guarantees no blade play, I would be in for every release. Possibly multiples of some too. I think the only model that would work, without blade play, is a Manix, with it's cbbl. If they used bearings, instead of washers, the recessed areas in the blade, could mean the bearings are held on the blade(somewhat), making swaps a matter of removing the pivot and changing out the blade. The metal assembly that houses the ball lock would probably need to be loosened, but not removed, to insert the blade/bearings/pivot. Hold the lock back, slide the blade/bearings in, add pivot. More complicated, but no blade play. If a lock position could be added, that held it open during swaps, this would make the Manix an unbeatable platform for a folding Mule.
This would be a lot of changes though. Re-tooling would be expensive, BUT this could end up it's own model, with some slight visual changes, and a new name. This would separate it from the standard Manix sold through dealers and make it easier for Spyderco to sell directly to it's customers.
- PeaceInOurTime
I mentioned this in the other folding mule thread, but I think a friction folder makes sense in that one could easily swap blades by just by removing the pivot. You don't really have to worry about tolerances. They could even provide different blade lengths and handle options, like Spyderco's version of Legos. Not to mention more people would be able to carry it around the world in jurisdictions with strict knife laws.
There could be so many options for blade steel (obviously), handle size, handle material, handle ergonomics, etc. from the factory or after market.
Two thoughts on swappable blades.
Imagine users who botch their knives when trying to center the blade or reduce its play. Some of them will be attracted to swappability for the novelty and become a W&R concern AND expense.
I like shooting .357 Magnums and have a few, including a vintage Dan Wesson 15.2 with three interchangeable barrel-lengths. After playing a little with my 2.5, 4 and 6 inch barrel, the novelty of swappability has faded and I have a 4-inch DW 15.2, even though the other barrels (and grips) are easy enough to swap in.
Still, curiosity can get the better of me, so I voted “Maybe”.
Friction folders are not for me. I have had a couple and never cared for them. However, I know some people swear by them.PeaceInOurTime wrote: ↑Thu May 09, 2019 9:46 amI mentioned this in the other folding mule thread, but I think a friction folder makes sense in that one could easily swap blades by just by removing the pivot. You don't really have to worry about tolerances. They could even provide different blade lengths and handle options, like Spyderco's version of Legos. Not to mention more people would be able to carry it around the world in jurisdictions with strict knife laws.
For me the appeal is that more people will get to carry the steel into the real world for EDC testing. I don't own any Mules because it is not practical to carry a Fixed blade where I live for legal and other reasons. For people in the UK this is double.Evil D wrote: ↑Thu May 09, 2019 6:31 am.....
By the time I got Handles on a regular mule I'd have spent over $100 dollars on a knife I couldn't carry outside of my house. That's a lot for just cutting up cardboard and other chores around the house. If I'm going to test a steel I need to be able to carry it.
And not every Mule steel makes it into the folders, and I at least would like to be able to try things and give feed back before the steel makes it into the regular line up or into sprints.
I voted "maybe" because if its a replacable blade on a not-so-sturdy handle, it would make for a terrible experience. But if its a well put together handle construction, then it would make for a great concept and better new chapter in the mule system
Every Steel Has Its Appeal :cool:
A.S.O.K.A Edge on Youtube
It could also be something along the lines of the Havalon knives, where the pivot is permanently part of the knife and only the cutting edge gets replaced.
This avoids all the issues with the end user taking apart the knife to swap blades, trying to get the blade centered, etc. But it would only support testing the edge for cutting; it's not a design that would support batoning or similar stresses.
ZrowsN1s wrote: ↑Thu May 09, 2019 11:19 amFor me the appeal is that more people will get to carry the steel into the real world for EDC testing. I don't own any Mules because it is not practical to carry a Fixed blade where I live for legal and other reasons. For people in the UK this is double.Evil D wrote: ↑Thu May 09, 2019 6:31 am.....
By the time you buy a blade and handle for this idea it'll be at least $100, I just don't see it being any more economical. The law issue is a bummer but that's just how it is. I'll support every request for putting out UKPK sprints so those folks can enjoy those steels but I can't see the rest of this working. I mean, unless everyone is ok with spending production knife money on a mule...if that's the case then yeah it'll work. I still think in the end this is just a complicated sprint situation.
I agree the changeable blade thing doesn't seem like a winning idea, I'd need more info from Sal before I rule it out completely, Im open to the idea. But yes a $70 Urban or UKPK seems a better solution. What could make it different than a sprint is the direct through Spyderco sales and even more limited than sprint production.Evil D wrote: ↑Thu May 09, 2019 11:56 am.......
As I said in another thread though, Spyderco has now made sprints of K390 Urbans, and is going to make an AEB-L Urban sprint. If those keep selling out, and we keep getting interesting sprint runs of the Urban... I'm ok with that, problem solved I guess.
This probably won't be a popular opinion but I think the most viable option would be a slip joint. If they built a handle with full liners and a solid back spacer running the fill length of the handle, then used the biggest pivot bushing they have, there wouldn't be any issues with lock faces not mating up or poor lock engagement. It could be built sturdy enough to baton the crap out of... you know...for science...and it would be legal practically anywhere since it doesn't lock. Then the only real testing you wouldn't be able to do is stabbing something. This would also reduce the amount of internal parts needed which will help to keep cost down. The scales don't even need to be nested...heck they really don't even need to be there at all, if people saw the things I've done with a Svord Peasant they'd be shocked and that knife couldn't be made any cheaper.
good points.
im ready for Sal to get back into the discussion and tell us what he thinks.
Broader market segment. More people can carry a sub 3" folder, so there could be more sales, which means less problems with small runs and flippers grabbing a bunch for eBay resales. Plus, more people get to play, since people could EDC the mules--even people in more restrictive jurisdictions.
