Yes. Yes, it would. :)crazywednesday wrote: ↑Sat Apr 27, 2019 2:03 pmLike many of you, I love k390. It would be great to have a k390 fixed blade the size of the waterway or or sprig!
K390 IS "The M4 Killer"
Re: K390 IS "The M4 Killer"
- JonLeBlanc
Hi Brown Bear, I'm very much interested in K390 because I'm a huge fan of tool steels and non-stainless steels in general. I notice your comment that K390 shares some characteristics with D2/CruWear, and while I defer to your knowledge which is doubtless greater than mine, I also note that it's composition has some differences, especially in the carbon-chromium-vanadium levels. Could you elaborate on your view that K390 is similar to D2/CruWear? Do you think it's a heat treat thing more than actual composition etc? I'm genuinely interested thanks !Deadboxhero wrote: ↑Fri Apr 26, 2019 12:04 pmChris they are not really comparable. I'd say that's a closer match between PSF27, CPM D2 and CPM Cruwearanagarika wrote: ↑Fri Apr 26, 2019 11:34 amShawn,
You did have experience with CS BS in XHP and if I recall correctly, you had quite good impression of high sharpness edge holding it has. I found it to my liking also, opposite to S110V. How different is this P4 in K390 or how much similarities with XHP?
All these talks about it making me wanting one. Alas, currently no budget to get one. A full Seki run is going to be very tempting.
The K390 has a higher obtainable hardness thanks to the drop in Cr and not being stainless. K390 has a huge volume of very fine Vanadium Carbides which are the hardest next to Niobium and K390 will be more durable at the edge than XHP yet still cut longer. I haven't found a production folder that holds the front end sharpeness as long with this much aggression.
Custom world is a different story.
I'm talking about what you can buy sub $300 production.
- Deadboxhero
No, Chris was asking if it K390 was similar to XHP. I was telling him that XHP is closer to CPM D2 but stainless.JonLeBlanc wrote: ↑Sat Apr 27, 2019 4:43 pmHi Brown Bear, I'm very much interested in K390 because I'm a huge fan of tool steels and non-stainless steels in general. I notice your comment that K390 shares some characteristics with D2/CruWear, and while I defer to your knowledge which is doubtless greater than mine, I also note that it's composition has some differences, especially in the carbon-chromium-vanadium levels. Could you elaborate on your view that K390 is similar to D2/CruWear? Do you think it's a heat treat thing more than actual composition etc? I'm genuinely interested thanks !Deadboxhero wrote: ↑Fri Apr 26, 2019 12:04 pmChris they are not really comparable. I'd say that's a closer match between PSF27, CPM D2 and CPM Cruwearanagarika wrote: ↑Fri Apr 26, 2019 11:34 amShawn,
K390 is Like 10v.
The direct analog to 10v from Bohler is k294.
There are a lot of these A11 type steels from different steel companies.
They cut longer than s90v but are tougher and stronger but are not stainless.
They are surprisingly durable at the edge as well.
In situations where M4 rolls, A11 type steels will not and are more wear resistant and can operate at higher hardness and still be stable.
They're just not the most shock resistant. I find it difficult to swing a small knife like an axe for that to play a pivotal role and strength is very important for an edge to hold shape. That's not to say M4 is a great shock resistant steel either. Trade offs trade offs trade offs
Hey Shawn, I've been having a little difficulty in getting my P4 as sharp as I wanted it to be. This thread inspired me to sit down and give it another go.
It's not perfect but it's better than I've ever gotten it so far. Thanks.
I should use this knife more.
- Connor
- Deadboxhero
Nice looking edge brother.The Meat man wrote: ↑Sat Apr 27, 2019 6:32 pmHey Shawn, I've been having a little difficulty in getting my P4 as sharp as I wanted it to be. This thread inspired me to sit down and give it another go.
Love how the patina is developing naturally man.
Thanks! It can just so whittle free hanging hair. I've gotten it close to that level before but always with a microbevel, and I like to avoid using microbevels if at all possible.Deadboxhero wrote: ↑Sat Apr 27, 2019 6:42 pmNice looking edge brother.The Meat man wrote: ↑Sat Apr 27, 2019 6:32 pmHey Shawn, I've been having a little difficulty in getting my P4 as sharp as I wanted it to be. This thread inspired me to sit down and give it another go.
Yeah I like that faint golden sheen. I think that came mostly from slicing tomatoes.
- Connor
- JonLeBlanc
Oh I see, I must've misread, but thanks for the info, that clears some things up.Deadboxhero wrote: ↑Sat Apr 27, 2019 6:14 pmNo, Chris was asking if it K390 was similar to XHP. I was telling him that XHP is closer to CPM D2 but stainless.JonLeBlanc wrote: ↑Sat Apr 27, 2019 4:43 pmHi Brown Bear, I'm very much interested in K390 because I'm a huge fan of tool steels and non-stainless steels in general. I notice your comment that K390 shares some characteristics with D2/CruWear, and while I defer to your knowledge which is doubtless greater than mine, I also note that it's composition has some differences, especially in the carbon-chromium-vanadium levels. Could you elaborate on your view that K390 is similar to D2/CruWear? Do you think it's a heat treat thing more than actual composition etc? I'm genuinely interested thanks !Deadboxhero wrote: ↑Fri Apr 26, 2019 12:04 pmChris they are not really comparable. I'd say that's a closer match between PSF27, CPM D2 and CPM Cruwearanagarika wrote: ↑Fri Apr 26, 2019 11:34 amShawn,
K390 is Like 10v.
Yeah, why is the mule not sold out? Come on Spyderco forum, we're better than that
This thread has given me the itch to play with some A11 class steels. Just ordered a Mule team 26 :)
- Tucson Tom
I did my part and bought several.
I presume you are talking about the PM A11 blades. Great stuff. Almost K390, same as 10V as near as I can tell. Holds an edge pretty much forever.
I don't know what is up with all the slackers on the forum. I guess they got burned out on the mule project, which is too bad.
Shawn,
My only experience with D2 was a BM HK which lost the high sharpness quickly to working edge and Luong’s K110 which is better (but I haven’t compared it to the CS XHP). The XHP however, holds the high sharpness better than BM HK and easily brought back. It also doesn’t suffer from losing the edge while being carried unused like VG10. This is from sharpening myself, and use case is shaving.
Sorry for the OT, just wanted to clarify what intrigues me when you said K390 has so much potential for high sharpness edge holding. Again, thanks for explaining.
Chris :spyder:
Me too. Hard to believe that of all Mules, A11 and PD#1 (basically = CPM Cruwear) are still available. My two favorites right there.Tucson Tom wrote: ↑Sat Apr 27, 2019 10:03 pm
- steelcity16
I would be all for a folding mule platform and would buy every one. Just use something existing like the Para 3 LW (I would say Manix LW is a good option as well if they CQI it to screw construction) and use white FRN as the scale to differentiate it as a "mule". I think a lot of people just don't have the opportunity to carry and use a fixed blade that often. A small folder is much easier to have on you at all times.
Drooling on spyderco website now...ferider wrote: ↑Sun Apr 28, 2019 9:20 amMe too. Hard to believe that of all Mules, A11 and PD#1 (basically = CPM Cruwear) are still available. My two favorites right there.Tucson Tom wrote: ↑Sat Apr 27, 2019 10:03 pm
I agree.steelcity16 wrote: ↑Sun Apr 28, 2019 10:18 amI would be all for a folding mule platform and would buy every one. Just use something existing like the Para 3 LW (I would say Manix LW is a good option as well if they CQI it to screw construction) and use white FRN as the scale to differentiate it as a "mule". I think a lot of people just don't have the opportunity to carry and use a fixed blade that often. A small folder is much easier to have on you at all times.
But I think that the UKPK would be a better platform, because it would give members in more restrictive jurisdictions a better chance to play too. Tons of people in europe can't carry a Para 3 (or fixed blade) and would be interested in a UKPK style "mule" project.
- Brock O Lee
+1 for UKPK, +100 for the new G10 version!
I agree with UKPK or Urban as a folding mule.TomAiello wrote: ↑Sun Apr 28, 2019 7:54 pmI agree.steelcity16 wrote: ↑Sun Apr 28, 2019 10:18 amI would be all for a folding mule platform and would buy every one. Just use something existing like the Para 3 LW (I would say Manix LW is a good option as well if they CQI it to screw construction) and use white FRN as the scale to differentiate it as a "mule". I think a lot of people just don't have the opportunity to carry and use a fixed blade that often. A small folder is much easier to have on you at all times.
If it had to be locking, I think a LW backlock would appeal to a broader audience than other style locks.
I would say that K390 is a good friend of M4 and they have a good time competing with each other. :p
-Brian
A distinguished lurker.
My P4 showed up today and is just laser sharp! Really looking forward to trying the K390. Thanks to Shawn for pushing this topic and talking me into this.
marty_bill_ wrote: ↑Mon Apr 29, 2019 6:10 pmMy P4 showed up today and is just laser sharp! Really looking forward to trying the K390. Thanks to Shawn for pushing this topic and talking me into this.
I wonder how many Police 4 knives have been sold so far by Deadboxhero and Vivi... :D
- Connor
