JD Spydos Ballistol Spa
Spreading the gospel Of Joe. :)
Dream as if you'll live forever. Live as if you'll die today.
James Dean
James Dean
Re: JD Spydos Ballistol Spa
Good as New.
James Dean
James Dean
All I can say is that I've been in love with the stuff for a few years now. I had two older Spyders ( RENEGADE & BLACKHAWK) that I got in a trade>> they were used and extremely faded and just out of curiosity I tried the BALLISTOL and at the time I had 3 other products I was going to try as well. The BALLISTOL made both G-10 handles on those older models look virtually new. It also seemed to actually heal up scratches and dings on the material as well.
I most generally use a toothbrush ( preferrably soft bristle but not totally necessary) and gently rub it in with several strokes. I just tried some two days ago on an old wood handle and it seemed to help it a lot as well. I truly think that product is overlooked and under-appreciated for all it is capable of. I'm really glad our Brother here is also having great results with it as well.
I've used It on wood and leather. Cleans up and smoothes out minor scratches on leather to.
James Dean
James Dean
Another option that is probably a bit less messy is Mr Clean Magic Eraser. I just cleaned up 5 of my knives G10 scales last weekend and was quite impressed. Just another way to go about it. Those scales look great though!
15 's in 10 different steels
I love ballistol, the smell not so much.
Adam
Adam
I need to get some ballistol for my REX 45 Military.
- Connor
Hopefully it can help restore a bit of color to your scales. Still surprised that had happened when you boiled them. Post up some before and after pics if you give the Ballistol a try.
I'll do that. Yes, the faded color bothers me more than I thought it would. :rolleyes:
- Connor
I like Ballistol. I use to clean the barrel of my M1A.
But, man does it have a PUNGENT odor lol. Whew.....
I kind of see what you're saying "Spy" but how on earth can a Mr. Clean Magic Eraser treat the G-10 material and restore it's original color and luster :confused: ? If it's just mere cleaning you're talking about I can sort of see it but I'm mainly talking about treating, preserving and restoring G-10 and other various materials with BALLISTOL. Oh Ballistol does also clean for sure but that's only one of several things it's good for.
Now I will look into using the Magic Eraser with Ballistol to clean with>> I can maybe see how that might work. But all the Magic Eraser products I've ever used simply seem to only work as a scrubbing device. I'll do some thinking on that one but I still don't see how this would be advantageous :confused: Maybe you can clear up my confusion because I just don't get the main thrust of what you're talking about.
Yeah you've got a point there for sure. However I've found that after storing a knife with a G-10 handle after doing a treatment with BALLISTOL that over time the odor doe dissipate to a large degree. The trade off is more that worth it to me because of the great effect it has on G-10 material especially.
Also BaLLISTOL doesn't solidify or varnish up like WD-40 does over time. Ballistol has a lot of great properties and is ideal for dozens of uses.
Hey Joe,
There's a few videos out there on YouTube of people using the Magic Eraser to clean dirt and grime off of G10 scales. Not necessarily restoring, just simply cleaning.
A little warm water to the eraser, scrub the scales and then wipe the scales off...as the eraser can leave some small white particles of the eraser behind. I waited until the scales dried up, hit them with some compressed air and wiped them a bit with a cotton tee shirt, good as new!
Yeah the G-10 handles on my C-36 Military models are all great grades of G-10 and they have all responded well to BALLISTOL treatments. The sooner you treat G-10 handles with BALLISTOL the better IMO.
I do think that for the most part the G-10 they use on the GOLDEN, CO USA Earth models seems to be a really high grade of G-10. Albeit the G-10 handle they used on the C-60 Ayoob Sprint Run of 2011 was also a really good grade.
What the one Brother said about using BALLISTOL on wood has been a good tip as well. I have some lawn/landscaping tools a friend gave me with really weathered wooden handles and it's worked a miracle on one of them already. In the past I've loved "raw" linseed oil on wooden tool handles but the results I've seen already of what BALLISTOL also does on wood is very encouraging to say the least.
I'm open to any suggestions to what this great product might be used for.
Oh I'm not in the least debating that at all. I have had some really good results using Magic Erasers along with "Bar Keeper's Friend" cleanser restoring corroded blades and old Revere Ware cookware I've bought cheap at thrift stores with amazing results.TkoK83Spy wrote: ↑Sat Mar 09, 2019 5:00 pmHey Joe,
I've never disputed the Magic Eraser as a "cleaning tool" at all. But the main topic on the use of BALLISTOL that I'm driving at is it's great restoring properties by using it on G-10 and several other materials. I mainly just use a soft bristle toothbrush working BALLISTOL into the material. It does have somewhat of a cleaning effect as well but mainly it's properties for restoration of weathered, faded polymer material like G-10 are remarkable.
But I do see the point you're trying to make as far as Magic Erasers being a great cleaning aid on certain types of cleaning jobs and they are a great cleaning product on certain jobs for sure.
I started using Ballistol after chatting with a Shimano fishing reels service technician. I’ve used it since an all my reels and I’m very happy with the results. :)
It obviously works well at cleaning and restoring G10 though I’m a little sceptical on using in on leather and wonder about the long term effect.
Just curious jd, what after the brush. Does it evaporate? Hit it with a paper towel? Soap and water after?JD Spydo wrote: ↑Sat Mar 09, 2019 5:09 pmOh I'm not in the least debating that at all. I have had some really good results using Magic Erasers along with "Bar Keeper's Friend" cleanser restoring corroded blades and old Revere Ware cookware I've bought cheap at thrift stores with amazing results.TkoK83Spy wrote: ↑Sat Mar 09, 2019 5:00 pmHey Joe,
I just then blot off the excess with a paper towel. Or if it's a major restoration job I'll wrap it in a soft cloth for a day or so to absorb all the excess liquid. But most of the time when I treat G-10 or even an old Micarta handle most of it gets absorbed into the material.SF Native wrote: ↑Sat Mar 09, 2019 5:27 pmJust curious jd, what after the brush. Does it evaporate? Hit it with a paper towel? Soap and water after?JD Spydo wrote: ↑Sat Mar 09, 2019 5:09 pmOh I'm not in the least debating that at all. I have had some really good results using Magic Erasers along with "Bar Keeper's Friend" cleanser restoring corroded blades and old Revere Ware cookware I've bought cheap at thrift stores with amazing results.TkoK83Spy wrote: ↑Sat Mar 09, 2019 5:00 pmHey Joe,
Also another good aspect of BALLISTOL is that it has some waterproofing properties to it.
Yeah my jury is still out on leather treatment with Ballistol myself. There are so many great leather products out there as it is that I just don't even see myself using it for that type of job. For leather I've just had the very best results using the "Propert" line of products. The "Propert" saddle soap is by far the best saddle soap I've ever used on leather. There's not even a close second on that type of job. Propert's Saddle Soap not only does an excellent job of cleaning but it really keeps leather soft and pliable for a long time and in almost factory new condition.Bloke wrote: ↑Sat Mar 09, 2019 5:23 pmI started using Ballistol after chatting with a Shimano fishing reels service technician. I’ve used it since an all my reels and I’m very happy with the results. :)
But I am already liking the results of using BALLISTOL on old wood tool handles. I think I'm going to do a side by side comparison using BALLISTOL and "raw linseed oil" that I've been using for years with great results to see what if any improvement it might have.
I Will continue to use It on leather, Will report back when/if the longterm damage appears :)
James Dean
James Dean
