My first impressions with a Spyderco
You guys may have seen my earlier post asking why you all liked Spyderco knives. Well, I got a lot of great responses and several points were brought up by almost everyone that responded. That, plus some independent reading I did about the company convinced me to give one a try. My Native 5 (in G10) was delivered while I was at work today, so I was anxiously awaiting quitting time so I could rush home and check it out.
Before I even pulled it out of the plastic, I could tell this was a SOLID knife. It's not heavy, but it feels really well built even compared to my current EDC which is a Benchmade Mini Griptilian. In addition to my first Spyderco, this is also my first knife with G10, and let me just say: Wow. I LOVE the feel of the G10 on this thing. It's grippy without being coarse. The pocket clip seems like it has a good amount of tension without being too tight. I haven't actually put it in my pocket yet but at first glance the clip will be fine.
THEN, I opened the blade. It *snapped* into place with authority. There is absolutely no doubt that this is a solid lock up. I've read and heard quite a bit about how smooth Spydercos are, and it could be the fact that this one sat out in the cold all day, or it may need loosened up just a tiny bit, because it seems a little rough to me. I'm sure I'll spend the next few days playing with it, and it might get better.
The ergonomics are great. It fits in my relatively small hands comfortably and naturally. The jimping on the spine and choil are well executed and feel good, the clip doesn't pinch when I'm gripping the knife and it's just plain fun to hold. If you hold the blade in one hand in what seems like a rather natural way to try to close it, when the blade falls the finger on front is lined up with the choil, so you don't get cut. I don't know if that's by design or a happy accident, but either way it's appreciated since if that wasn't the case, I'd be wearing a band aid for a few days.
The blade is extremely sharp. It's easily the sharpest knife I've ever owned out of the box. It glides through paper (it's first task was opening a bill, being an adult sucks, huh?) like it's not even there.
So far my only complaint is with the locking mechanism. It's not that there's anything wrong with it, I've just been spoiled by the Axis lock and liner locks, this one is a bit more difficult to close one handed without using my hip or something to get the blade lowered enough to grab the spidey hole and close it the rest of the way. (Speaking of the spidey hole: I used to think it was dumb, but now I totally get it, it's awesome).
It's early to tell, but... I don't think the Native 5 will become my new go to EDC knife. However! I think my biggest complaints about it would be addressed by getting something with a different locking mechanism sooooo, I think I'll be getting a Para 3 in the very near future!
Thank all of you, and thanks Sal for making an awesome knife. I may not be a total convert yet, but I get why all of you are so loyal to the brand.
Re: My first impressions with a Spyderco
Oh your poor wallet. We have all been there man. You are going to like the compression lock. The beauty of the back lock will probably come back to you. It has some real advantages. The closing bias is one. Glad you like the native. It’s a sloppy slope from here. Welcome and good luck.
Enjoy! Now what’s next? :D
Could be their best back lock yet (the standard Native I mean). The 5 is great too
Compression lock is great! Also consider a Manix2, if you like the axis lock and can deal with a stiffer pull you’ll love a Manix2! Action just as smooth but without the blade play. Much more solid feel too.
I think the Manix2 may be a bit on the big side for me. The Native 5 is pretty much the perfect size as far as I'm concerned, and I think the Para 3 is the closest to it size wise that has something other than the lock back, no?
I second the manix 2! I love mine (G10 with s30v). The ball bearing lock is superb. You can flick the blade with your thumb (I can't seem to do the middle finger flick, yet!), pull the bearing lock and flick your wrist... And it's solid! The lightweight is a great knife too, but very weird to me (at first). Carry it, use it, and you come to appreciate its lightness, and learn the balance. The lightweight manix is weighted more towards the blade, and the normal is towards the handle... Just takes getting used to.
Can't wait for my para 3 lightweight!
Spyderco : Resilience, Tenacious, Persistence, Manix 2 G10, Para 3 G10, Para 3 LW, Paramilitary 2,
Spyderco lockbacks get considerably smoother with time. Cycle the action at red lights for the next month and you'll notice a massive difference. Putting a drop of mineral oil in the pivot if its dry there will help too.
As for closing one handed, it is very, very easy to close using the first method I show in this video:
https://streamable.com/gfhxo
If your blade doesn't fall shut like that one, just give it a little downwards shake.
I always use the second method shown in the video, using my index finger to swing the blade shut. Keeping my index finger there removes any chance of the blade swinging into my other fingers before I can adjust my grip. With practice this is, IMO, the quickest way to close a Spyderco lockback. I use that method every day.
Thanks Vivi, mine definitely does not drop like that. It is getting better, so I'm sure by the time I play with it for awhile and maybe put some mineral oil on like you said it will help. It is definitely dry, I hadn't noticed it, but I was playing with it while the wife and I were watching TV and she said "Why does it squeak when you close it?" Once she pointed it out, I could hear it.
It may need some oil and more openings but you can also give it a bit of a wrist flick to get the blade closed. Many Spydercos need some use before they get buttery smooth.jaypuck wrote: ↑Fri Feb 22, 2019 10:13 pmThanks Vivi, mine definitely does not drop like that. It is getting better, so I'm sure by the time I play with it for awhile and maybe put some mineral oil on like you said it will help. It is definitely dry, I hadn't noticed it, but I was playing with it while the wife and I were watching TV and she said "Why does it squeak when you close it?" Once she pointed it out, I could hear it.
Sometimes I close the knife with my index finger in the Spyderhole and thumb on the lock bar. This also is fun to do one-handed besides the flick.
Check out the video here, a few closing tricks are shown including the index finger one at 30 seconds
https://youtu.be/LbmLhzeIwiI
Try this: Press the lock with your thumb, while having your index finger in the hole a little. Glide the blade down with that finger or shift over and let the thumb either guide it down with thumb in the hole, or placed on the spine and snapping it closed. It is very fast and easy to do on a Spyderco back lock.jaypuck wrote: ↑Fri Feb 22, 2019 7:32 pmYou guys may have seen my earlier post asking why you all liked Spyderco knives. Well, I got a lot of great responses and several points were brought up by almost everyone that responded. That, plus some independent reading I did about the company convinced me to give one a try. My Native 5 (in G10) was delivered while I was at work today, so I was anxiously awaiting quitting time so I could rush home and check it out.
BTW, a back lock is not going to fall free and feel that smooth compared to an axis lock or a compression lock. It is stronger, however. If it feels gritty, it may simply need cleaning and oiling.
Welcome, and enjoy your knife/knives. I just got the G10 Native and love it. Of course, I love back locks.
- best wishes, Jazz.
- araneae
You might want to loosen the pivot just the slightest bit. Sometimes it just needs the tiniest adjustment to get it perfect.
-Nick
Last in: N5 Magnacut
-Nick
Welcome, enjoy, and definitely get the Para3!
Dragonfly G-10, Blurple PM2, Para3, Jani-Song, Dragonfly2 ZDP-189, Lil' Native, Chaparral LW, Delica WC HAP40, Para3 M4, HH UKPK S30V, Para3 LW, Para3 LW M390, Meerkat V-TOKU2, M4 Sage 5 LW, Urban Ivory Damasteel, Leaf Storm
-Derek
-Derek
If your knife has G10 than it should have phosphor bronze washers. They'll self polish as time goes by.
You may want to get some thin lube into the pivot.
I don't know how stiff a native is out of the box but i learned after the chaparral the risk of a dry pivot
If you are going to put tools to your new knife, read up before you do. Have to get good bits and put some heat to it. Would hate for you to strip the screws on something brand new. Don’t think you need to, it should break in. A little mineral oil would help too.
I've never used heat on any screw on any knife in my life.
Same. I'm permanent thread locker's worst nightmare.
- jabba359
If you want a Native with a different lock, I'd say the Sage 5 is pretty close.
