Jade FRN?
embry386
Jade FRN?
Post by embry386 »
Has there ever been an FRN knife with the jade handle / DLC M4 blade combo? I really like that combination of color but I prefer lightweight knives over the G10 models.
ZrowsN1s
Re: Jade FRN?
Post by ZrowsN1s »
I dont know if the color (or technically lack of color) would work in frn. In case you didn't know, the 'Jade' is just undyed g-10. Problem 1, frn isnt translucent. I suppose they could find something close to it in color. Might look alright.
jabba359
Re: Jade FRN?
Post by jabba359 »
Jade FRCP is likely a possibility, however.
-Kyle
:bug-red
http://www.spydiewiki.com
Re: Jade FRN?
Natural FRCP would be clear. Still hopeful for the clear or 'smoke" Manix2 LW :)
Pelagic
Re: Jade FRN?
Post by Pelagic »
Glass is as clear as it gets. Fiberglass is glass and resin. Resin can be clear upon desire. Nylon can be any color. This is beyond possible.
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
steelcity16
Re: Jade FRN?
Post by steelcity16 »
embry386 wrote:
Fri Feb 01, 2019 1:40 pm
No, but Ive said before many times that BHQ needs to do this with the Native LW and Manix LW. And now the Para 3 LW is surely a good candidate for this treatment!
embry386
Re: Jade FRN?
Post by embry386 »
Yeah, I wasn't thinking so much of a clear FRN knife but rather something that's about the same shade of grayish light green as the G-10 jade knives. But clear would be pretty epic -- unlimited dyeing potential, or just leave it clear to have a super cool clear knife that lets you see all the inner workings and such :) And yeah, the para 3 LW would be awesome to see in this combo!
Thanks for the answers everyone!
zhyla
Re: Jade FRN?
Post by zhyla »
I’m not sure I’ve ever seen translucent nylon in any application. I think it’s naturally an opaque off white right?
Re: Jade FRN?
Post by Doc Dan »
This would be possible. It could still be translucent and dyed any color desired.
I have long hoped for a translucent orange of some tint. Emerald green might be okay, as well.
Re: Jade FRN?
Post by The Deacon »
zhyla wrote:
Fri Feb 01, 2019 9:25 pm
I'm not sure. A lot of toothbrush handles and other brush handles are nylon. I've seen brushes with clear and transparent colored handles, just don't know whether or not the plastic they were made from was nylon. Definitely can't recall ever seeing a clear or transparent colored FRN knife handle.
Closest thing to Jade FRN might be that glow in the dark stuff Spyderco used for the Plastic Delica Kit.
zhyla
Re: Jade FRN?
Post by zhyla »
Did a little searching for nylon (polyamide) blocks and what not. I don’t know what those old toothbrushes were made of but I’m guessing not nylon. The raw PA blocks look like bone — off white and opaque.
If nylon could be translucent we’d probably have translucent glock frames by now.
Pelagic
Re: Jade FRN?
Post by Pelagic »
Bdubs808
Re: Jade FRN?
Post by Bdubs808 »
The classical guitar uses nylon strings; if unwound the string is transparent.
I would buy a Jade LW.
atv223
Re: Jade FRN?
Post by atv223 »
Pelagic wrote:
Fri Feb 01, 2019 7:15 pm
Not really. Look at glass on edge and it'll have a green tint to it. Plexiglass (aka: Acrylic, PMMA, Poly(methyl methacrylate)) more "clear" then glass. They actually add green dye to Plexiglass to make it look like real glass.
atv223
Re: Jade FRN?
Post by atv223 »
Bdubs808 wrote:
Sat Feb 02, 2019 7:41 pm
Whether some plastics are clear or not has to do with the crystallinity. In general, the more amorphous (opposite of crystalline) a plastic is, the clearer it is. Crystals, tend to refract light so it appears opaque. Glass is amorphous. PMMA (acrylic) is very amorphous so it's clear. Nylon is a highly crystalline polymer, so consequently it's opaque
Monofilament fishing line is made of nylon and it's clear. But that's a special case where the preferential stretching to align the polymer molecules. So while technically it's not amorphous, it's not really crystalline either. If you were to heat up nylon fishing line, the molecules would form crystals and it would go opaque.
Pelagic
Re: Jade FRN?
Post by Pelagic »
atv223 wrote:
Sat Feb 02, 2019 8:23 pm
When it's extremely thin (as it is in fiberglass), you'll have a lot of trouble convincing someone that it's green. Very transparent.
Re: Jade FRN?
Pelagic wrote:
Sun Feb 03, 2019 5:40 am
When it's extremely thin (as in fiberglass), you'll have a lot of trouble convincing someone that it's green. Very transparent.
And yet, I can't recall ever seeing transparent fiberglass fibers. I've seen white, which I've always assumed to be its natural color, pink, blue, green, and a number of other colors, which I've always assumed were tinted, but never clear.
Pelagic
Re: Jade FRN?
Post by Pelagic »
The Deacon wrote:
Sun Feb 03, 2019 5:49 am
Meant to say, when it's thin as IT IS in fiberglass. Just woke up before posting. You don't see the green tint in extremely thin glass. Fiberglass is white because you're looking at the sides of rough fibers from different perspectives. When looking through a window you're only looking from one perspective relative to the glass itself. Some fiberglass DOES become translucent however after resin is applied. Ever reinforced anything wooden? Once resin is applied, you can hardly see the fiberglass until you get close. It just looks like wet, shiny wood.
Re: Jade FRN?
Pelagic wrote:
Sun Feb 03, 2019 6:03 am
Yes, I've reinforced things with fiberglass and epoxy resin, mostly when I was building R/C airplanes and boats. Granted, the resin by itself was clear, but adding the chopped fiberglass flock made it look milky. When I used fiberglass cloth, the white fiberglass was visible through the resin, just like the black carbon fiber rods were visible when I used them for reinforcement. It almost sounds like you're confusing the glass fibers with the polymer/epoxy resin in a fiberglass composite like G-10.
Pelagic
Re: Jade FRN?
Post by Pelagic »
The Deacon wrote:
Sun Feb 03, 2019 9:30 am
So FRN truly isn't FRN? I figured they called it what it was. It's actually not (fiber)glass? Within nylon of course.
I've helped with boat building myself, and even a wooden supercar called the splinter. Some fiberglass can look milky after resin is applied, some is virtually clear. The resin has a clearing effect similar to clear coat when you restore headlights: the 5000grit wet/dry sandpaper leaves a foggy looking finish, and the clear coat makes the headlight look brand new by filling in the contour of the scratch pattern fully so that all the various nooks, crannies, and angles no longer reflect light. Just as there's no such thing as a clear powder (because you're viewing reflecting light from countless perspectives), there's no such thing as clear fiberglass. Until you add resin.
