Sage 5 or Para3 LW?
kvdo
Re: Sage 5 or Para3 LW?
Postby kvdo » Mon Jan 28, 2019 11:11 pm
Crux wrote:
Mon Jan 28, 2019 11:06 pm
Well my friend, lift from the blade pivot point and rotate the liner lock. *Edited - Unnecessary and disrespectful*- TazKristi
That's basically removing it
Crux
Postby Crux » Mon Jan 28, 2019 11:20 pm
No as it is still attached to the lanyard tube. You can pivot it away with no problem. Also, WTF does someone do that they need to completely disassemble a knife to clean it on a regular basis? *Edited - Unnecessary and disrespectful* - TazKristi
kvdo
Postby kvdo » Mon Jan 28, 2019 11:26 pm
The scale has to be pushed out of its original fit with the lanyard tube, which is a pressed-fit part. By using force to move a part out of its original fit in a manner that would render it no longer functional in that condition, is at the very least partial removal. It is still physically connected to the lanyard tube, but the application of force still supports the point of the Sage5 simply having a lanyard tube that drops in and out.
If you drop your knife in a body of water, or happen to get caught in rain and it's in your pocket, it would generally be a good idea to dry it off, and make sure there is no moisture sitting in any hard-to-reach places (like between a liner and a scale).
This thread is titled "Sage 5 or Para3 LW?", and my point of the lanyard tube is that of the Para3's lanyard tube compared to the Sage5.
Crux
Postby Crux » Mon Jan 28, 2019 11:35 pm
JacksonKnives
Location: Formerly Alberta, now Orange County, California
Postby JacksonKnives » Tue Jan 29, 2019 12:21 am
Easy, fellas. TIme to walk away.
Cscottsss
Postby Cscottsss » Tue Jan 29, 2019 8:44 am
Para 3 LW
BLUETYPEII
Postby BLUETYPEII » Fri Feb 15, 2019 1:54 pm
I don’t own a Para 3 but I do own a Sage 5 and it’s an absolute gem.
I’ve heard a few people complain about the action on the Sage 5 but mine is buttery smooth and falls shut. It’s as it was from the factory no tightening loosening or adjustments of any kind. Just a week or so of flipping to break it in. It’s also small enough to be good around Sheeple.
Also the ergonomics of this knife are just phenomenaly good.
Get one you won’t be disappointed.
:spyder: 21 Spyderco knives in 8 different steels, 1 Byrd and 30 “others” :spyder:
Larry_Mott
Postby Larry_Mott » Fri Feb 15, 2019 2:30 pm
Again with the "you have to disassemble for maintenance".. Not going down that road (and no, i don't disassemble my motorcycle for maintenance either)
I choose Sage 5, simply because i like it better. :)
//Eva Mott R.I.P.
youmakemehole
Postby youmakemehole » Sat Feb 16, 2019 8:52 am
Well my friend, lift from the blade pivot point and rotate the liner lock. *Edited - Unnecessary and disrespectful* - TazKristi
I definitely tried that before and that doesnt remove the liner entirely... so if you have say dirty oil or liquid that has seeped in between the liner and scale towards the bottom of the handle, near the landyard tube, well, youre gonna need a pressure washer or something to get down there to clean it out.
"Sometimes I think that we're all little kids trying to act like grown ups, in our parents clothes. ;) "
-sal
Users browsing this forum: abbazaba, Airlsee, attila, dan31, Enactive, Flizwit, Lumpy620, Majestic-12 [Bot], negative d, wolfstyle, WRB and 49 guests
