For reference. How do you guys like this steel?
Any corrosion issues? Edge performance? Stories?
The Chap LW at $88 MAP, Chap CF at $128, and the new McBee at $130 indicate to me that it's cost effective. The fact the Spyderco added a new model, the McBee, with XHP blade indicates to me that at least Spyderco can obtain it without too much hassle.
I picked up both a Dice and Domino this year, which both have it. I think it sharpens pretty easily and easily takes a very fine edge on a strop. I've not had any corrosion issues, but I do use my Spydiechef any time I anticipate more averse conditions than normal. XHP has been a pleasant surprise for me. I like it quite a bit.
Sal,sal wrote: ↑Sun Dec 09, 2018 5:01 pmHi Pelagic,
XHP is essentially a successful attempt to make stainless D2. Carpenter was developing it when we were helping them develop a line of blade steels and we did initial testing for them. I think the sourcing issues are; it's expensive and minimum quantities have recently been raised to a very high amount. We use quite a bit so, while inventory is still a hassle, the steel is good enough to keep working with it.
Sal, if you're able to tell us, how does XHP compare in price to S30V, or even 20CV and 204P? Has Carpenter raised minimum quantities on all steels, or just XHP? As much as I like XHP on my Domino and Dice, I'd have to do an Ankerson or Cedric & Ada style test to really differentiate it from the similarly ground S30V blade on my Sage 2. But I also understand that many afi's are bored with S30V being so common now. It sounds like you and Eric have quite a lot to think about when deciding on blade steels outside of the Salt series.sal wrote: ↑Sun Dec 09, 2018 5:01 pmHi Pelagic,
How do you find the edge holding of XHP compares to S30V and S110V?TomAiello wrote: ↑Sun Dec 09, 2018 5:19 pmI really only started using XHP because it was in the Chaparral (which I love, and which is not available in any other steel). It's impressed me enough that I now really do prefer it to s30v and s35vn, and actually did some personal (totally subjective) comparison tests by carrying the XHP manix back to back to back with the s30v and s110v versions.
Sounds great Sal! I'm very glad you still work with it. I think interest will only grow for this steel as more and more people use it/find out how good it is.sal wrote: ↑Sun Dec 09, 2018 5:01 pmHi Pelagic,
It seems to hold a high sharpness longer than s30v, be slightly easier to sharpen, and have better apex stability IMO, perhaps with better corrosion resistance. But s110v is in another league.Vivi wrote: ↑Sun Dec 09, 2018 5:38 pmHow do you find the edge holding of XHP compares to S30V and S110V?TomAiello wrote: ↑Sun Dec 09, 2018 5:19 pmI really only started using XHP because it was in the Chaparral (which I love, and which is not available in any other steel). It's impressed me enough that I now really do prefer it to s30v and s35vn, and actually did some personal (totally subjective) comparison tests by carrying the XHP manix back to back to back with the s30v and s110v versions.
Agree with both statements above.Pelagic wrote: ↑Sun Dec 09, 2018 6:39 pmIt seems to hold a high sharpness longer than s30v, be slightly easier to sharpen, and have better apex stability IMO, perhaps with better corrosion resistance. But s110v is in another league.Vivi wrote: ↑Sun Dec 09, 2018 5:38 pmHow do you find the edge holding of XHP compares to S30V and S110V?TomAiello wrote: ↑Sun Dec 09, 2018 5:19 pmI really only started using XHP because it was in the Chaparral (which I love, and which is not available in any other steel). It's impressed me enough that I now really do prefer it to s30v and s35vn, and actually did some personal (totally subjective) comparison tests by carrying the XHP manix back to back to back with the s30v and s110v versions.
Users browsing this forum: abbazaba, aicolainen, austrian_spyder_fan, Bing [Bot], Bolster, eonbluemantra, Henri, Joshcrutchley1, Mushroom, negative d, poolhustler, skeeg11, Supacede and 59 guests
