REX45 vs. CPM 4V
Pelagic
Re: REX45 vs. CPM 4V
Postby Pelagic » Tue Nov 06, 2018 4:24 am
tps3443 wrote:
Mon Nov 05, 2018 5:47 pm
I like S110V a lot. I really do, but it does chip about once a week I guess. If you avoid touching metal all together it won’t chip, but accidents happen and that’s just how S110V is.
Absolutely. Given i keep my s110v at about 12dps and no microbevel currently (i plan on using a micro in the next few sharpenings), chips often appear and I have absolutely no idea what caused them.
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
tps3443
Postby tps3443 » Tue Nov 06, 2018 6:58 am
Wow! Maxamet is amazing. That video was incredible.
“My daily razor blade”
Spyderco PM2 DLC/BLK S30V
Microtech Dirac Delta CTS-204P
^Wicked Edge guided system^
TomAiello
Postby TomAiello » Tue Nov 06, 2018 9:05 am
Start using it. It's even more impressive in person. We've used Maxamet (Manix 2 LW) to cut through a braided steel cable, and it was still shaving sharp afterward.
The Meat man
Postby The Meat man » Tue Nov 06, 2018 9:12 am
Wait, what?!! Tell me you took a video!
What kind of cable was it?
- Connor
Jesus said, "I am the way, the truth, and the life: no man cometh unto the Father, but by me." (John 14:6)
TomAiello
Postby TomAiello » Tue Nov 06, 2018 9:29 am
Nope. It was an actual use, not a test. We had a jammed sliding power door on a mini van (2004 Toyota Sienna) at work, and one of my guys came over to me asking if I had something to cut the cable with (to unjam the door, although it also disabled the power opening function of the door). I gave him the knife out of my pocket, he cut the cable, and we kept on working.
I don't have a photo, but the cut off half of the cable is still on the vehicle, so I can measure it when I'm at the office later today.
tps3443
Postby tps3443 » Tue Nov 06, 2018 12:26 pm
I cut on a constant basis at work. My knife is just about in my hand all day folded ready for more use. One day I was popping through plastic straps on pallets, and the last pallet strap was steel. My S110V cut through it pretty good with a little effort. But, it took the entire edge with it too lol 😂. I didn’t know it was steel until it was practically cut in half.
Anyways, I could see Maxamet being useful to me as a second knife in my pocket. As long as edge retention is there too.
I can push S110V for about 1-2 days with extreme sharpness. But it occasionally chips while cutting tougher things. A harder metal would save me some trouble for sure
tps3443
Postby tps3443 » Tue Nov 06, 2018 12:28 pm
Also the Manix 2 Maxamet is a great deal at about $155. But I don’t think I want a Manix. FRN, or G10 doesn’t matter to me.
What do you guys think about this? I found one for $165.00. Will a Delica hold up to abuse like a PM2 will? 3” blade seems ok to me. Hap40 is similar to REX45 I suppose
Spyderco Delica 4 HAP40/G10 Red
The Meat man
Postby The Meat man » Tue Nov 06, 2018 12:29 pm
Where can you get the Manix Maxamet for $155?
- Connor
p_atrick
Postby p_atrick » Tue Nov 06, 2018 12:43 pm
If you really want to use Hap40, go get the Cutlery Shoppe Endura exclusive. You get a bigger blade of Hap40 (but no coating) for about $60 less.
https://cutleryshoppe.com/spyderco-c10z ... exclusive/
Rutger
Postby Rutger » Tue Nov 06, 2018 2:40 pm
REX 45 was ran at a much higher hardness than HAP40 is. And if you want a HAP40 delica i'd go for this one:
TomAiello
Postby TomAiello » Tue Nov 06, 2018 4:47 pm
Maxamet has better edge retention than s110v. It's the most wear resistant steel I've ever used by a good margin (still waiting to try Rex121 though).
It's super wear resistant and above average on toughness. It's stainlessness that it doesn't have.
Woodpuppy
Postby Woodpuppy » Tue Nov 06, 2018 4:48 pm
^^ that Delica wharnie is awesome, I’d second that recommendation. It is easy to get real sharp, but I don’t think it’s as tough as rex45. I see hap40 being compared more with M4, not rex45. I wonder how tough maxamet is to sharpen
:spyder: My other blade is a Kelly Perfect :spyder:
The Meat man
Postby The Meat man » Tue Nov 06, 2018 5:23 pm
FWIW I have not found Maxamet particularly difficult to sharpen. It takes a bit longer for me than other steels. For context, I sharpened it freehand on SiC Japanese water stones.
- Connor
Woodpuppy
Postby Woodpuppy » Tue Nov 06, 2018 5:50 pm
I’m a pretty dedicated sharpmaker user. Ive never used a water stone.
EngDevGr3
Postby EngDevGr3 » Tue Nov 06, 2018 5:53 pm
A bit of random info. In Michael Christy's rex 45 video, someone commented that they rockwell tested their Para 2 rex 45 and got 66.5 hrc. This matches the number Sal mentioned a while back.
tps3443
Postby tps3443 » Tue Nov 06, 2018 6:21 pm
Wow that is crazy! What is Spyderco S110V hardness typically ran at?
So, Could we say that REX45 is kinda like a stainless Maxamet or close to it?
tps3443
Postby tps3443 » Tue Nov 06, 2018 6:23 pm
I’m sharpening with diamonds on a Wicked Edge, I really like a challenge. I really don’t mind how hard anything is to sharpen. Maybe if I was free handing I suppose. If I could ^ lol
The Meat man
Postby The Meat man » Tue Nov 06, 2018 6:29 pm
I've never tried out REX 45 but it isn't stainless. From what I've heard it sounds like it's about as corrosion resistant as M4 or Maxamet.
- Connor
tps3443
Postby tps3443 » Tue Nov 06, 2018 7:31 pm
Ok I dunno why I thought it was stainless for some reason.
ZrowsN1s
Postby ZrowsN1s » Wed Nov 07, 2018 4:27 pm
Cutlery Shop
Carrying 3 knives is perfectly normal :D
-Matt
Users browsing this forum: bbturbodad, Bill1170, Bloke, Carlito86, DutchBlades, Google [Bot], Haunted House, JacksonKnives, pushcut and 24 guests
