Sal, have you ever tried making a lock back with an internal stop pin?
Postby vivi » Tue Oct 30, 2018 7:11 pm
One idea I've had over the years is a lockback with an internal stop pin, the way a lot of framelocks have used them. I thought this would let you design a knife where the cutting edge goes all the way to the handle since the kick would now be optional.
Is this something Spyderco has tried?
Current favorites:
Military DLC | Police 4 K390 / Pakkawood | Manix XL M4 DLC / Micarta
ugaarguy
Re: Sal, have you ever tried making a lock back with an internal stop pin?
Postby ugaarguy » Tue Oct 30, 2018 8:14 pm
Vivi, Andrew Demko beat you to the punch with his Tri-Ad Lock. One of Spyderco's competitors mass produces many of his designs. Several of those designs have the edge coming all the way to the handle, or very nearly so, as you describe.
kvdo
Postby kvdo » Tue Oct 30, 2018 8:15 pm
The Chaparral?
Though granted, the edge doesn't go all the way down the blade.
Postby vivi » Tue Oct 30, 2018 8:57 pm
Looks like I have my answer, thanks.
Current favorites:
awa54
Postby awa54 » Tue Oct 30, 2018 11:19 pm
And Sage 4 IIRC?
-David
anagarika
Postby anagarika » Wed Oct 31, 2018 2:46 am
Vivi,
Check Nick Shabbazz Broken Skull disassembly video.
If Spyderco does that it’s going to enhance the current line big time.
ETA: I just remembered you have Voyager. I think it also has one.
Chris :spyder:
Postby Evil D » Wed Oct 31, 2018 4:51 am
I'm not sure if the pin in the Chaparral acts as a blade stop when closed, which I think is the point Vivi is getting at here. Most back locks need the kick to stop the blade edge from hitting the lock bar/back spacer when closed, and the kick takes up edge length. If the internal stop pin also stopped the blade when closed you could do away with the kick and have more edge length. In the Chaparral there's a choil anyway, but for larger folders you could pack more edge into the handle this way.
Rutger
Postby Rutger » Wed Oct 31, 2018 6:33 am
It acts both as a blade stop when open (almost a tri-ad lock) and closed. It's a much nicer construction then a normal back lock like a Delica. Can't say enough good things about my Chappy. :)
So yeah if you made a knife without a finger choil like this you could have a full knife edge.
The picture above is the old S30V Chaparral construction. In the later versions the liners and pin placement is slightly different.
Postby Sharp Guy » Wed Oct 31, 2018 6:57 am
For clarification, the first pic above is also the current XHP/CF construction. The pic you posted (my pic) is exclusive to the new FRN/"LW" version. As you said, the pin placement is different but both are doing the same thing.
ugaarguy
Postby ugaarguy » Wed Oct 31, 2018 7:33 am
Vivi,
I think that would infringe on Andrew Demko's patent. Sal and Eric won't even use an Axis type lock, even though that patent has expired. I think we're more likely to see further development of the Powerlock rather than something that mimics the Tri-Ad lock.
anagarika
Postby anagarika » Wed Oct 31, 2018 8:01 am
Vivi,
Agree.
I mean not a direct copy but enhance it with a stop pin for closed position. ;)
Chris :spyder:
kvdo
Postby kvdo » Wed Oct 31, 2018 8:29 am
Vivi,
The Triad lock works by having a stop pin set in the liners/handle of the knife, and acts as a point where the forces trying to close the blade are directed from the blade tang, to the lock bar "hook", to the stop pin, and from there the handle.
A traditional back lock transfers force from the blade tang, into the lock bar, to the lockbar's pivot, into the handle.
A stop pin mounted on the blade itself (Chaparral) can't act as a means to transfer the force of closing from the blade to the handle as a means of locking. In no way does this infringe upon the Triad lock - that's why it exists on the Chaparral already with no legal issues. I believe Vivi is just asking here for the edge grind to go further down the blade, losing the finger choil.
kvdo
Postby kvdo » Wed Oct 31, 2018 8:48 am
For further clarification: See the Compression Lock. Mechanically, it's very similar to the Triad Lock in how lock up is achieved. The "lock bar" of a Triad lock and the spring liner of the Compression lock are both serving as a means to transfer force from the blade tang to a static stop pin set in the handle of the knife.
The lock bar on a typical back lock is the only element keeping the knife locked open.
ugaarguy
Postby ugaarguy » Wed Oct 31, 2018 11:34 am
Vivi,
I'm aware of the difference. The post I quoted referred to a Cold Steel folder with the Tri-Ad lock, and suggested using that stop pin format, not using the Chaparral style stop pin. Perhaps you should read things in their context rather than getting defensive and telling me I'm wrong.
tvenuto
Postby tvenuto » Wed Oct 31, 2018 1:22 pm
Perhaps you should calm down, he didn’t get defensive, merely explained things for those that might not know.
Pelagic
Postby Pelagic » Wed Oct 31, 2018 4:40 pm
I dream of a Glesser/Demko collab featuring largely Demko ergonomics (with a Glesser touch), Glesser blade shape/geometry, spyderco quality fit/finish/tolerances/action, Demko durability/pivot construction, and the Tr-Ad lock.
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
navin johnson
Postby navin johnson » Wed Oct 31, 2018 11:50 pm
Why?
Pelagic
Postby Pelagic » Wed Oct 31, 2018 11:54 pm
Why?
Why are you asking why?
Do you not see any potential usefulness in the suggestion? You wouldn't be at all interested in what designs such a collaboration could yield?
I'm almost positive it would never happen, for obvious reasons. But that's why I called it a dream.
Postby Doc Dan » Thu Nov 01, 2018 3:09 am
A Glesser-Demko collaboration would be pretty sweet.
https://www.facebook.com/fallplanet Author page
Postby sal » Thu Nov 01, 2018 6:33 am
Hi Navin,
Welcome to our forum.
Users browsing this forum: elena86, gfc55, Google [Bot], Haunted House, Joshcrutchley1, Majestic-12 [Bot], Mzen, poolhustler, Skidoosh, Skywalker, TechnoSage, TkoK83Spy, Wartstein and 50 guests
