Oil the joints
Oil the joints
I have four Spyderco folders but aquired my first one only four weeks ago so bear with me if this is a silly question...
Does the pivot need oiling?
Most of my other folding knife have "oil the joints" printed on the handle or the blades.
Subject of England, The UK, Earth.
Re: Oil the joints
Hey, Luddite:
Yes, it does. Here's some great information from an older issue of our newsletter, The Spyderco byte. Just scroll down to the second section.
Kristi
Kristi
Re: Oil the joints
It doesn't hurt. Definitely prolongs the knife and makes it smoother
Re: Oil the joints
You can use practically anything to lube a knife, from mineral oil to a drop of engine oil. It really doesn't take much or anything super fancy.
Re: Oil the joints
Look to something food safe if you cut food
Re: Oil the joints
The lubricating oil most frequently used by Luddites? Spindle oil...(with their textile work). The oil used in greatest quantity by Luddites was not for lubrication, of course. (just a little historically accurate dry n' droll humor.)
As for pivot lubrication and The Byte:
https://www.spyderco.com/byte/2013_10_o ... index.html
Small excerpt:
".....In addition to cleaning your knife, you should also lubricate the blade pivot with a high-quality gun oil, silicone lubricant, or Teflon-based lubricant. Do not use WD-40, as it is not a true lubricant. Whatever lube you choose, use it sparingly. Oil attracts dust and dirt and excessive lubrication can actually cause your knife to become dirty......"
I've never seen a knife nor blade with such markings. Which of your knives are so marked? Thanks for a pic if you can post such.
Re: Oil the joints
nicked.onaut wrote: ↑Sun Sep 30, 2018 10:00 pm
Sheepish am I. I have at least one knife with those markings, just seen; an old slipjoint probably from the '50s. And no doubt some others stashed in the oldies crypts. Either I never noticed those blade markings (small) in the old days, or I just plain forgot them in my dotage.
- Tucson Tom
Re: Oil the joints
Good reminder. Any oil is better than nothing. I'll probably use CLP.
Re: Oil the joints
Hi nick, I have a couple of WW2 pocket knives, non locking, which have this marking.nicked.onaut wrote: ↑Sun Sep 30, 2018 10:00 pmThe lubricating oil most frequently used by Luddites? Spindle oil...(with their textile work). The oil used in greatest quantity by Luddites was not for lubrication, of course. (just a little historically accurate dry n' droll humor.)
Small excerpt:
I also have a few 1960s pocket knives have have it too.
I asked because Spydies are so slick to open one handed I though they might have special bearings that need no oil.
I have a Victorinox Soldier which has a pseudo Spydie hole which is impossible to open one handed even though it is well made.
Re: Oil the joints
They're oiled and we'll finished which is why they're so easy haha.
Re: Oil the joints
I use silicone oil, lubricates relatively well and is not aggressive with the materials
Re: Oil the joints
My favorites are Weapon Shield, Royal Purple Synfilm and, Archoil AR-4400 WS2.
- Larry_Mott
Re: Oil the joints
Every time i oil a joint it taste like crap and smokes like a two stroke engine :D
Re: Oil the joints
You keep using that word. I do not think it means what you think it means. You've been mostly-dead all day.Larry_Mott wrote: ↑Wed Oct 03, 2018 2:07 amEvery time i oil a joint it taste like crap and smokes like a two stroke engine :D
Re: Oil the joints
Ahahahahaha... good one.Larry_Mott wrote: ↑Wed Oct 03, 2018 2:07 amEvery time i oil a joint it taste like crap and smokes like a two stroke engine :D
For pivot lube on my knives I've been using Ballistol for very many years now, and have found it to work exceptionally well. A little goes a long way. Some don't care for it's particular odor, but I kinda like it. (works well on firearms too).
u.w.
