Dragonfly H1 Hawkbill for self defence
Country where i live (Europe) its not allowed to carry firearm for self defence, even pepper spray is under lisence. So i have choose knives for SD, even they are not allowed. I travel alot around the world and long time i have try to find some good SD tool what i can carry every place with good explanation.
Few weeks ago i received my dragonfly hawkbill H1 and i am verry satisfied and sunrised also how much i like it. I have own several Spyderco knives, even civilian, tasman salt , matriarch + about 20-50 other knives for self defence use. Now i finally after 20 year feel that i have found perfect self defence knife for my needs.
Why i think its best self defence knife for me:
1. Lightweight
2. Small size&slim (easy to hide)
3. Short Hawkbill edge is effective but dont cause so mutch deep wounds that they are immediately deadly. Also in under stress you cant cause stab wounds accidentally.
4. Enviroment friendly (Neutrall size and color, easy to explain if needed that its for fishing/sailing hoppy)
5. Good quality
6. Inexpensive ( in my country about 105 USD)
1. Lightweight
5. Good quality
- cabfrank
Re: Dragonfly H1 Hawkbill for self defence
I don't think of a Dragonfly as a SD knife, but then again, I don't consider any knife for that purpose.
I would imagine a hawkbill this small, or rather with a handle this small, would get snatched out of your hand if you slashed with it and it got hooked into clothes/meat/bone/etc. I think if I had to go with something as small as a Dragonfly I'd get the standard version, it has a fairly straight edge so it's almost as good as a wharncliffe.
- legOFwhat?
Welcome! Mine bit me on 1st close the day I got it. Just swung down and the se got my knuckles, so it seems they're blood thirsty.
-Larry
MNOSD #0049
MNOSD #0049
This is an interesting philosophy. Why are you stabbing someone if you don't want to injure them sufficient to incapacitate them? I mean, I'm not saying you're wrong, but it's a very different mindset than we usually see in the U.S. (e.g., if the situation is serious enough to require self defense that you should try to be as deadly as possible).
It wouldn't be my first choice, personally. But if you travel, with how restrictive some laws are, it's a much better choice than having nothing.
I believe that self defense starts when "run away" has already failed. It should go without saying the avoidance and run-fu are always the best option. I think incapacitating your attacker is the focus of most self defense "systems" because it's the best way to be sure you are safe and can escape, but as long as you can discourage someone from continuing an attack, or get them off of you so you can run, you don't "need" to incapacitate to defend yourself.zhyla wrote: ↑Mon Jul 23, 2018 2:51 pmThis is an interesting philosophy. Why are you stabbing someone if you don't want to injure them sufficient to incapacitate them? I mean, I'm not saying you're wrong, but it's a very different mindset than we usually see in the U.S. (e.g., if the situation is serious enough to require self defense that you should try to be as deadly as possible).
Don't think of it as a deadly weapon, think of it as a pain/compliance tool or force multiplier. You can use it as a pressure point tool, you can punch with it in reverse grip... No one likes getting cut, even superficially. Eyes/neck/groin are places no one wants to get hit even with an empty hand let alone a sharp little hook. If someone is on top of you, or holding onto you, a little hook poking them in the ribs/arm/thigh/hand might be enough for them to let go, move, or rethink their choice of victims. I'd rather have a yo2, civilian, matriarch, p'kal, karahawk, tasman, wharndelica, ect, the pivot on the Dfly is a little weak for SD, but it's way better than nothing.
In general, a Dragonfly is absolutely big enough to be lethal especially from slash wounds. I've seen the meat-man cut tests from (I think?) a Ladybug and it was terrifying what a small blade can do.
Yep, in my paper towel roll "tests" I can't slash down to the center of a roll like I can with a Delica, but a DFly cuts deeper than I'd want to get cut. My ZDP manbug does too.
the df hawkbill is similar in size to some small karambits on the market. in the reverse grip, i think it could be plenty effective for self defense. i sure hope i’d never have to rely on one to defend my life, but it might get the job done better than my bare hands.
Since a self-defense knife is essentially fantasy for 99.9999% of people, I'd say there is no wrong choice.
- Naperville
If you have studied martial arts, as I have, and 5 guys try to break every bone in your body, as they have, then a pocket knife knife works like magic.
Been there. Done that.
I must be in the 0.0001%.
Indeed.Naperville wrote: ↑Mon Jul 23, 2018 5:50 pmIf you have studied martial arts, as I have, and 5 guys try to break every bone in your body, as they have, then a pocket knife knife works like magic.
Probably a little bit of training and a crappy knife will trump zero training and buying the absolute best knife for the job.
There are some videos that I've seen where a half inch utility razor blade can cause some really deep (to the bone) cuts.
The Dragonfly might do well for you, but most self defense experts suggest plain edge to avoid getting caught on heavy clothing.
-Brian
A distinguished lurker.
After using the hawkfly, tasman, and matriarch a bit myself, and seeing pictures of what a matriarch can do to heavy clothing I worry a lot less about serrations snagging on clothes than I used to. Just got to keep em' sharp. If you let it get dull though, it could be an issue.
Hi Petersson,
Welcome to our forum.
I agree with others that a small hawkbill blade can be deadly effective against clothing and flesh,
it doesn't have to be big, just sharp, :eek:
but also I agree with those that say that it might not be a great defensive folding knife because of the grip (you don't really have much purchase, a secure grip, ample surface of contact with the hand, etc.) and lack of secure purchase in aggressive motions, sudden impacts, etc. :o
and also that I am not sure about the strength of the pivot and hardware for those kind of possibly stressful and abusive situations, I'd rather have a Tasman or Spyderhawk not only for the added blade length but also for the strength factor :cool:
- curlyhairedboy
Wouldn't immediately peg the dragonhawk as a SD blade, but it is tiny enough to be easily concealed in hand. I'd reckon it would have the same kind of uses as the matriarch/civilian do - multiplying gross swinging into something much more damaging.
What's most likely to happen in most situations where people try to use knives for self defense is your opponent takes it away from you, and now they have a knife. Without actual training and practice, no knife is going to help you in a fight. Your best weapon is a pair of good running shoes in nearly every case.
