Your Two Favorite Locks
Favorite Lock Types
Slip Joint
7
5%
Ball Bearing Lock
3
2%
Caged Ball Bearing Lock
12
9%
Compression Lock
43
30%
Liner Lock
16
11%
Mid-Back Lock
38
27%
Reeves Integral Lock (frame)
16
11%
Other
6
4%
Total votes: 141
Eli Chaps
Post by Eli Chaps »
What are you two favorite lock types and why?
dogrunner
Re: Your Two Favorite Locks
Post by dogrunner »
compression lock for bullet-proof reliability
liner lock (a well-made one, of course) with a well-designed access, such as the Military, for ease of use with heavy gloves on.
If I had to pick a 3rd, it would be back-lock. Main concern there is gunk buildup, possibly impairing lock up.
dogrunner
Post by dogrunner »
more market research for Sal? ;)
Compression and liner. 2 fun locks and strong enough for my uses
Spydergirl88
3 Nats, 1 Chap, 1 Sham, 1 Urb
markg
Post by markg »
Across the industry I would say Compression, Axis, Tri-Ad...
Spyderco specific I would say Compression and RIL.
tvenuto
Post by tvenuto »
Backlock: as I’ve said before, if you don’t need flow through construction, there’s not much to complain about (I’ve never experienced significant play). Love the self close, the only lock I’ll carry IWB.
Other: Bolt Action Lock. Smooth as all get out, one of the most underrated designs out there.
Frozenspyder
Post by Frozenspyder »
Backlock- It's been around forever for a reason. It's a solid lock design. Nothing really exciting about it, but it reliably does what it's supposed to.
Ball Bearing Lock- I just really like it. I don't see a lot of advantages over the cbbl or even the comp lock. They're all great. I just prefer the ball bearing lock.
The Meat man
Post by The Meat man »
I prefer either the linerlock or the backlock. The linerlock works well and is easy and intuitive for me to operate. The backlock is nice for its simplicity and security, and especially for its self-close bias.
Of course, my votes are probably not worth much since those are the only lock types I own. I'd like to try a CBBL sometime, or a compression lock. If I ever do, my opinions might change.
- Connor
Compression lock, CBBL. Liner lock gets a runner up but mostly just for the Military.
Bloke
Post by Bloke »
Spydergirl88 wrote:
Sun Jul 15, 2018 7:45 pm
Well said 88! :cool:
ugaarguy
Post by ugaarguy »
Listed - RIL/ Frame Lock
Other - Compression lock if integral and not using a liner, because I've had too many Spyderco liners rust. Also much prefer the Axis lock over the BBL / CBBL for the flow through construction.
knivesandbooks
Post by knivesandbooks »
Backlock and slip joint.
Backlock becuase it's as old as the hills, is plenty strong, is ambidextrous (and so am I), allows for a thinner and symmetrical knife, and is the most ergonomic for me.
Slip joint because I've an old soul, love traditionals, don't usually need an actual lock for 90% of my uses, and I like the walk and talk.
steelcity16
Post by steelcity16 »
Liner and Back-lock.
Featherblade
Post by Featherblade »
Liner and Compression.
Liner lock: fun to use, amazing sound; reliable and strong enough; I have not any security problems with this lock, especially accidental disengaging.
Compression lock: strong; easy to use; fun factor - less than liner lock.
sn0wman72
Post by sn0wman72 »
Compression and Back lock
Compression is an easy one handed lock, Back locker is traditional and I like that
holeshot
Post by holeshot »
Bolt lock. :)
The Meat man
By the way, I also own a RIL knife (Advocate), but I consider the RIL and the linerlock essentially the same.
- Connor
Easy. Backlock and tri-ad lock. If we're talking Spyderco only, replace the tri-ad with CBBL.
Those are the only locks I use. I'll likely end up with a power lock knife at some point too.
I no longer buy liner locks, compression locks, frame locks and other detent based locks.
I chose the locks I do because they are the only ones I find do a good enough job keeping the knife securely closed, while the others only do a good job at keeping the knife locked open in my experience.
:unicorn
npad69
Post by npad69 »
compression and liner lock: facilitates easy cleaning/maintenance for openly constructed models
MichaelScott
Post by MichaelScott »
#1 Spyderco back lock
#2 WLL on smaller knives (if they don’t have a back lock); Compression on larger knives (if they don’t have a back lock)
http://acehotel.blog
Team Innovation
