AFI Performance Flash Batch
AFI Performance Flash Batch Yes or No?
Yes
164
92%
No
15
8%
Total votes: 179
Chris_P_Bacon
Re: AFI Performance Flash Batch
#121
Post by Chris_P_Bacon »
Calicoast wrote:
Thu May 31, 2018 8:51 pm
I like to go on hikes, fishing, etc. When I get the time to go out, I will bring my four dogs titanium biomass stick stove with me to boil water
I get that your dogs have really cool names, but, how did you train them to boil water?
Currently have 163 :spyder: 's & 41 different steels.
Bench Stones Atoma Diamond Plate 140,400,600,1200. Naniwa Chosera 400,800,1000,3000,5000.
Shapton Glass 1000,6000. Suehiro Rika 5000. Shapton Pro 320,1000,2000,5000,8000.
Naniwa Bonded Diamond 400,600,800,1000,3000,6000. Venev Gen2 OCB Combo Diamond 800/1200.
Spyderco 306UF, 306CBN. Doublestuff2 303FCBN2, & 204MF Sharpmaker w/204CBN for Spidie Edges.
Want List Steels 15V, S125V, K490, M398, Magnacut, S390, SRS-15, Vanadis 8, Vanax SC, Vancron SC,
The Meat man
#122
Post by The Meat man »
Lol! :D
- Connor
wrdwrght
#123
Post by wrdwrght »
I’d like to try some thinned-out H1 (FFG, PE, 7 DPS) in something lengthy, say an Endura, for a fillet option.
Enactive
#124
Post by Enactive »
Necro alert!
Edit: reading other thread now.
ZrowsN1s
#125
Post by ZrowsN1s »
Enactive wrote:
Sat Jun 01, 2019 12:23 pm
Necro alert!
It's an oldie but goodie ;)
Enactive
#126
Post by Enactive »
ZrowsN1s wrote:
Sat Jun 01, 2019 12:37 pm
Necro alert!
Totally! What happened to Some1? :rolleyes: :cool:
Enactive
#127
Post by Enactive »
Evil D wrote:
Thu May 31, 2018 4:13 pm
Vivi I forget about that D2 Military. That thing is BA.
Yeah, man! BA indeed!
steelcity16
#128
Post by steelcity16 »
A super duper thin Delica slicer would be interesting. How about an LC200N Delica Salt with the Delica tip rather than the Salt 2 tip? Ground as thin as possible.
Or an LC200N Chap LW Salt ground even thinner than the XHP blade??
These would be awesome little portable paring/steak knives.
ZrowsN1s
#129
Post by ZrowsN1s »
They should do REX45 but in a different color besides orange to indicate that it's a performance flash batch :D
p_atrick
#130
Post by p_atrick »
steelcity16 wrote:
Sat Jun 01, 2019 12:51 pm
Wouldn't this be better if Spyderco used a steel that they can crank up the HRC? That way there is some strength behind the thin edge (it won't be deforming as often). I'm not a knife maker, so maybe LC200N would work just fine. I do know that 60 HRC is about the limit of that steel. BD1N can go up to 63. Of course, the PM tool steels can go even higher. Perhaps somebody with some more knowledge could chime in here. I'm interested in this idea, but I'm not sure of which steels would be best suited for such a grind.
#131
This is an addition to the discussion on the "plea" thread. Probably better off with the this one as it has more suggestions. I would suggest a non stainless steel to hold a really thin edge. We've tried zero grinds and ended up with edge deformation and breakout, so this has to be thought out more carefully. Maybe a Delica in Super Blue with an edge thickness of .010?
glutofknives
#132
Post by glutofknives »
Superblue sounds perfect. +1
steelcity16
#133
sal wrote:
Sat Jun 01, 2019 9:56 pm
I like the idea of a Super Blue Delica.
I assume at that thinness we are talking an unclad blade like the Super Blue on the Caly Jr?
If unclad, what about TiCN coating the blade to reduce help reduce corrosion and also reduce friction on slicey cuts??
tbdoc4kids
#134
Post by tbdoc4kids »
Would the coating actually reduce friction significantly at this thickness (thinness?)? Definitely would help with corrosion, though.
rabbitanarchy14
#135
Post by rabbitanarchy14 »
as long as it is not a backlock, and i actually get the chance to buy one. maybe a thinner para 3 lw in super blue would be another dream. well seems like all the talk is for a delica, so i am sorry but have to vote no.
Last edited by rabbitanarchy14 on Sun Jun 02, 2019 12:00 am, edited 1 time in total.
192.168.0.1 -Para 3 G10 M390 Red, Dice XHP, Lil Native Rex 45 comp, Manix 2 M390 G10 BR, PM2 M390 DLC BL, PM2 k390 RGreen, Cat BD1N, Dragonfly 2 k390
Saving for - Lil Native K390, D'allara 3, UTX-70
Instruments- Kimber EVO, SA Hellcat, SW Shield Plus 9
Baron Mind
#136
Post by Baron Mind »
Superblue delica at 10 thou bte would be excellent!!
#137
This is probably asking for too much but how about a 52100 Nilakka?
The Meat man
#138
This would be great!
- Connor
Nate
#139
Post by Nate »
I wouldn't say no to 52100 or more Super Blue, but as Larrin and others have noted, wouldn't AEB-L be an ideal stainless steel for this sort of performance grind?
Hope the upcoming Urban sprint comes ground pretty thin, but I'll adjust it myself if needed.
:spyder:
#140
I'd be all for AEB-L or 52100 or even HAP40 or Super Blue, but ultimately for me it'll come down to what model it comes in. Like Nate said I can regrind or have it done so it's almost more important to me that I get the right steel in the right model. Having Spyderco produce it just makes it cheaper, and I'd like to see how the factory does it vs custom done.
