Para 3 exclusive at River's Edge Cutlery
Bdubs808
Post by Bdubs808 »
Just happened upon this, anyone else hear about it yet?
https://riversedgecutlery.com/rec-exclusive-para-3
The Meat man
Re: Para 3 exclusive at River's Edge Cutlery
Post by The Meat man »
Not me. It has definitely piqued my interest though!
I wonder what blade steel it'll have?
- Connor
Liquid Cobra
Post by Liquid Cobra »
PVD eh? I’m intrigued.
@liquid_cobra
koenigsegg
Post by koenigsegg »
Think they would color the blade? PVD on certain lights i've seen lets them color things. Isn't this the process they use for DLC coating as well?
I guess this is how they are coating the back lock of the gold Delica and Endura as well
Spydersense
Post by Spydersense »
Had not heard about it before now. Definitely interested.
Time for another :spyder:!
-Matt
Deadboxhero
Post by Deadboxhero »
Physical Vapor despostion (PVD) is the process
DLC ( Diamond Like Carbon) "Black" is one of the many coatings that uses PVD.
We'll have to see what the choose, maybe a different color then black.
Big Brown Bear
Triple B Handmade Knives
Username827
Post by Username827 »
Been looking for an excuse to pick up a para 3. Maybe some micarta scales, hmmm. Oh boy
illacky
Post by illacky »
Intriguing! I wonder what the steel choice is.
This is probably part of the long line of dealer exclusives of the para 3 to come.
What do we have confirmed so far? the M390 bbs, BHQ M4, Rivers Edge, and ...?
-Ivan
interesting
Spydergirl88
3 Nats, 1 Chap, 1 Sham, 1 Urb
hackzogan
Post by hackzogan »
well... i'll have to get this one too I guess...
Pelagic
Post by Pelagic »
What does PVD stand for?
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
holeshot
Post by holeshot »
Yes, I emailed Brian Kent the general manager and got back to me saying he would add me to the list to be notified when they drop. He also the specs on the knife would be released soon. :)
WireEdge Roger
Post by WireEdge Roger »
Pretty cool! River’s Edge is one of the few shops I’ve actually visited. I’ll have to budget for this one, I’m sure it’ll be top notch.
attila
Post by attila »
Pelagic wrote:
Sun Jun 24, 2018 3:05 pm
Physical vapor deposition.
Normally it's a metal-ceramic coating on the order of some thousandths of an inch thick applied in a vacuum to a metallic surface. It's a process to increase the lifetime of drill bits and endmills, as well as other metal things that benefit from a very hard coating.
Another method of applying such coatings is chemical vapor deposition (CVD)
Want: SPY27, K490, Swick 5
Pelagic
Post by Pelagic »
attila wrote:
Sun Jun 24, 2018 4:26 pm
Does it bond (chemically) with the metal? And if so (I'm assuming it would bond with some much more well than with others), which ones does it bond with best?
If anyone knows.
attila
Post by attila »
Pelagic wrote:
Sun Jun 24, 2018 4:32 pm
If anyone knows.
That's a beyond my limited knowledge of the process. I don't know the precise bonding mechanism. Also, because there are countless combinations of materials that can be used as PVD coatings, and most metals can be coated, I can't answer which has the strongest bond. There's really no way to answer that.
As I understand it, however, the deposited material remains chemically distinct from the substrate (steel) that it's applied to.
A properly-applied PVD coating will stick to its substrate as if it were the same material and is not likely to be removed by any mechanism besides abrasive or adhesive wear. As wear occurs, the PVD coating will lighten and fade, until the substrate is exposed. That should take a long time in regular knife cutting applications, but I've not tested it, and I don't know what material they are applying via PVD. It also depends on what you're cutting.
ucfgrad93
Post by ucfgrad93 »
This looks very interesting.
TomAiello
Post by TomAiello »
I hope it's the glossy black PVD. That's an amazing look.
T_MAC686
Post by T_MAC686 »
I hope it's not S90V.. seems to be what a ton of exclusives are..
Pelagic
Post by Pelagic »
T_MAC686 wrote:
Sun Jun 24, 2018 6:00 pm
Yeah. Time for more variety.
