Show your Sharpening Equipment!
DMT - Xcoarse, Coarse, Fine, Xfine
3 leather strops, diamond compound, diamond powder, and Tormek PA-70.
Not pictured: 10 inch block of basswood (one of my favorites), several vials of diamond powder, DMT Xfine sharpening rod, cheapo tungsten carbide pull-through sharpener (great for re-profiling machetes), 1 sharpmaker medium rod.
On my radar: Spyderco UltraFine bench stone, DMT XXfine stone or plate, coarse sharpening rod, more diamond powder, pocket mini-diamond rod sharpener for serrations, and more basswood.
Show us what you got! What's your favorite stuff?
Re: Show your Sharpening Equipment!
^ Some of my stuff. The rest is on/in my workbench in the garage. It's way too hot to work out there so I temporarily moved inside.
I'm old school sharpmaker set works for me is the one of most good or even best sharpeners out there
- Connor
Not pictured is a DIY modded Chicom edge pro, Diamond pastes and strops. However this is what I use the most as its fast for touchups and minor reprofiling:
-Ivan
Bloke, at this point I am always awaiting your post to any thread like this. Lol.
Bloke takes the cake as usual, but I will still participate
main touch-up tool:
others:
thee include Fallkniven DC3 and DC4, three Smiths White 1000 grit Arkansas Stones, two DMT Diafold in four grits, three different grit DMT Credit Card Sharpeners, a DMT EF Diamond pocket stone, a Extra Coarse DMT Keychain sharpening stone, three Lansky CrockStick Ceramic Sharpeners, a "very fine grit" White Ceramic Pocket Arkansas Stone, also two different unknown grit Silicon Carbide stones, very worn and old, and a Lansky Cold Steel Sharpening Rod
main touch-up tool:
others:
- Deadboxhero
- Liquid Cobra
@liquid_cobra
@liquid_cobra
This is a Wicked Edge Field and Sport with the new 2017 Gen 3 vise upgrade.
a
- Cambertree
A couple of my Naniwa Choseras and Atoma plates:
Most things I use to sharpen are in these pics.
Stones and diamond stones in various grits and some leather strops with green compound:
Diamond compounds and balsa strops:
resulting in this: :D
Nice! Which is the finest stone you use before strop? And what don ou recommend? I got the ceramic 1200/1600 before strop.
Instagram: Knives_Gear
This is a small portion:
I have a pretty extensive lighting setup for examining edges while working them; a 2x72 belt grinder; a Worksharp sharpener (hardly ever used at this point); and various hand tools ranging from angle protractors to calipers to a drill press with a 3-axis vise for clamping work perfectly.
The above photo only shows some of the WE hones and a PM2 in a Panavise - it doesn't show the Gen III Wicked Edge and all the clamps I have. I have many WE hones with diamond polish running from 400 Grit to 200,000 Grit. Likewise, I have an extensive selection of diamond lapping film so that I can pick the right abrasive for the job.
