This is what I've been waiting for: Ankerson Bowie
TomAiello
Post by TomAiello »
Pre orders are up. :)
https://www.knifecenter.com/item/SPFB45 ... her-sheath
This is my highest priority for 2018. Can't wait....
Anyone else as excited as I am for this?
mb1
Re: This is what I've been waiting for: Ankerson Bowie
Post by mb1 »
Hopefully will get one in hand tomorrow to decide. Love the blade shape, can’t tell what that handle will feel like from the pic.
- Mark
blendergasket
Post by blendergasket »
Is the sheath ambidextrous? Bladehq says the knife is left hand/right hand, but I don't know if that means that its the knife or also the sheath that's ambidextrous.
Tdog
Post by Tdog »
Also looking forward to this one. Don't have any 4v, wonder if the finish will help with rust resistance? Glad to see the scales are removeable. Between this, the Waterway, and the Bow River, looks like some of the folders might be taking a back seat.
PaleMoon
Post by PaleMoon »
I really, really love this design, except for the removable handles. I had issues with significant surface rust under the halpern scales of my 4V Mule following only light indoor use. This being an outdoors knife, I would expect the problem to be far worse, unless the scales offer a much better seal against moisture.
At this price point, I'll probably wait for field reviews before jumping in. Still, one of the coolest fixed blades Spyderco has done in recent memory.
The problem of a coherent civilization is the problem of living with ignorance and not being frustrated by it.
Ankerson
Post by Ankerson »
PaleMoon wrote:
Thu May 31, 2018 11:21 pm
Actually you can remove the scales and put wax on it, that will prevent the rust.
bearfacedkiller
Post by bearfacedkiller »
You could also epoxy them on yourself if you wanted. It would be easy enough. I covered the handle of my 4V Mule with Vaseline before putting the Halperns on and it is working well for me.
Deadboxhero
Post by Deadboxhero »
TomAiello wrote:
Thu May 31, 2018 2:27 pm
Dilly Dilly!
Big Brown Bear
Triple B Handmade Knives
PaleMoon
Post by PaleMoon »
Ankerson wrote:
Thu May 31, 2018 11:24 pm
I remember trying to put a thick coat of frog lube in there and it didn't help at all. But I found out later on that frog lube wasn't really that good to begin with (for my uses, at least).
I was thinking, if I bought this knife and rust showed up, I could just epoxy the handle on. Spyderco handles are always first rate anyway, so I doubt I'd ever start looking for replacements.
Edit: you beat me to it bearfaced :o
Ankerson
Post by Ankerson »
PaleMoon wrote:
Thu May 31, 2018 11:38 pm
You could do that for sure. :)
Pelagic
Post by Pelagic »
Imageupload gambar
^^^ That's a pretty good one, just saying.
I REALLY like this knife. I just don't have a huge need for it currently. The price (while being completely reasonable) makes me hesitant as well. I've been dying to try 4v and it's an excellent design.
How many of these are being made? Will there be another run if sales are good?
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
TomAiello
Post by TomAiello »
bearfacedkiller wrote:
Thu May 31, 2018 11:35 pm
I used tuf glide before I put them on, and check every now and then for more rust. Some minor rust, but no huge issues for me. I do live in the desert, though.
dj moonbat
Post by dj moonbat »
It's one of those knives that makes me wish I had a different, outdoorsier life, so that I had regular use for it.
Bloke
Post by Bloke »
If rust is a concern Eezox is your friend. ;)
Ankerson
Post by Ankerson »
dj moonbat wrote:
Fri Jun 01, 2018 7:49 am
Don't they have some excellent camping sites in Northern Cal?
Much less sand up there. :D
Bdubs808
Post by Bdubs808 »
Bloke wrote:
Fri Jun 01, 2018 8:11 am
I'll second that.
Calicoast
Post by Calicoast »
Corrosion X in the spray bottle works great.
I usually coat my mules in this before putting on the scales. No rust yet.
Ankerson Bowie and the Waterway are on my radar.
-C
