I wish Spyderco would make...
DougC-3
Re: I wish Spyderco would make...
#181
Post by DougC-3 »
...a Manix 2 K390, on which I would install Cuscadi antique olive drab micarta "Dr Jones" scales.
Note to self: Less is more.
noddy
#182
Post by noddy »
I have wanted to see a modern sobuster from Spyderco for ages and ages. In G10 and VG10 to be exact. For a time I was a bore on the subject and then just gave up hoping. Doesn’t fit the general scope of the company I think
Anyway
Boker just made it ... The Slack. So I don’t have to hope no more :)
shaztec
#183
Post by shaztec »
Would love a k390 pattada.
Sharperthannewedges on instagram
tvenuto
#184
Post by tvenuto »
A sprint run of the hossom fixed blades.
And my oft-requested R sprint.
The PPT discussion also reminded me that I think they should really do the design justice in full Ti. As it is, the steel scales just make it so darn heavy. I’d like to see a Ti lock side with the sculpted CF overlay, and a fully sculpted Ti presentation side. I know it would have an eye-watering price tag, and would require more effort than the typical sprint, but it would be truly unique in the lineup.
SpyderEdgeForever
#185
Post by SpyderEdgeForever »
A sprint run of the Spyderco Navaja, with a blade of Lc200N stainless steel and G10 handle grips or the original grips.
Please, sal, please :) :) :)
SpyderEdgeForever
#186
noddy wrote:
Fri Apr 13, 2018 11:31 am
Anyway
YES! Same here! A Spyderco Sodbuster exactly as you describe it. 100 percent YES!
Bodog
#187
Post by Bodog »
Anyway
Can you define what a sodbuster is? For all practical purposes and in my mind spyderco makes a lot of them. Basically all of them, really. Unless you're talking about a cheap throwdown knife but then opinel has that covered quite well. And if you want a spyderco knife without a hole in it then good luck, i don't think it will happen
Darth_cholo
#188
Post by Darth_cholo »
Manix 2 lw in carbon fiber vs frcp. S110v s90v m4 maxamet
mjdragonfly
#189
Post by mjdragonfly »
Darth_cholo wrote:
Sun Apr 15, 2018 12:17 am
That's a really fine collection of Manix 2 LW blades congratulations. The Manix 2 backlock is a special member of the family that you might want to check out.
Calgary on the Bow
DougC-3
#190
Post by DougC-3 »
+1 on the R sprint, maybe smooth CF, thin G-10, or even Ti Damascus or some other blade steel.
FX sniper
#191
Post by FX sniper »
MichaelScott
#192
Post by MichaelScott »
I wish Spyderco would make a basic Bob Lum Chinese folder,not the big one, but the mid-sized one, with a decent steel like VG-10 or equivalent, and G10 scales. Why, because along with the PM2 it is my most sought after Spyderco and many of us could probably afford that model.
http://acehotel.blog
Team Innovation
Grendel
#193
Post by Grendel »
..Native 6:
- compression lock
- G10 scales w/ recessed and skeletonized liners, open back
- S35VN or better
I usually carry a Para 3 for its features, but I like the overall shape of the Native 5 more. :)
tvenuto
#194
Post by tvenuto »
Junction with contoured handles.
Sumdumguy
#195
Post by Sumdumguy »
FX sniper wrote:
Wed Apr 18, 2018 2:03 am
This^^
It's probably frowned upon to post just "This^^", so I figure I'll post this part to make up for it. :spyder:
-Thomas Jefferson
steelcity16
#196
Post by steelcity16 »
Murdered Out Dragonfly 2 Salts (PE, SE, and HB). Black FRN with black H1 blades and hardware. Should be easy enough! :)
RickC27
#197
Post by RickC27 »
Manix 2 G10 handle with PM2 blade and compression lock...the ParaManix.
T_MAC686
#198
Post by T_MAC686 »
Spyderco Air sprint with G10 and XHP
shaztec
#199
Post by shaztec »
I wish spyderco would make a lefty compression lock shaman...
ugaarguy
#200
Post by ugaarguy »
Since we're wishing:
Spydie chef with LC200N frame, internally or fully skeletonized to reduce weight; all LC200N hardware. If that's possible, that would prevent the galvanic corrosion issue, correct?
Also, Domino and Dice with washers instead of bearings, solid CF scale instead of G10/CF laminate, deep carry pocket clip from the factory, and LC200N, Elmax, or M390 blade.
The new Brouwer (if it has washers) in a sprint run with solid CF scale plus an even higher end steel than the base S30V would move that model from want to buy to must buy. A longer blade Brouwer which preserves the short blade height would also be awesome.
