Kydex Sheaths
v34
Kydex Sheaths
Post by v34 »
Are there any kydex neck sheaths available for the Yojimbo that don't need me to send the actual blade to the maker? I'm loathe to send an expensive blade in the mail.
rycen
Post by rycen »
Ask here if they have one for the Yojimbo.
info@rivercitysheaths.com
loki88
Post by loki88 »
or use this maker, perfect quality http://www.survivalsheath.com
v34
Post by v34 »
Thanks guys I'm awaiting replies from the 2 site you recommend.
Jon_USA
Post by Jon_USA »
Most of the makers I have had kydex sheaths from required the knife.
This is so the fit matches that knife and is perfect. There are slight differences in the sheaths at times that make individual fitting a must.
Although with a tension screw this is less of an issue, but if it is press fit kydex that fit must be dead on for the retention to be right. I would go with the tension screw myself on kydex as it allows for wear, you can then always have similar realease and hold.
The two makers listed are the best in the game of kydex IMO.
I have sheaths from both makers listed and they are great.
