I had some weird movement in the pivot of my Dragonfly, so I took it down and put it back together. Action is great now and wobbly click is gone, BUT, now when the knife is open the lock bar is sticking up a bit. It's completely flush when the knife is closed. Did I do something wrong or can I adjust it so this doesn't happen??
image by Six Pound Cat, on Flickr
Lock Bar Help
Re: Lock Bar Help
It should not stick up like that. I once had a Case that did that. I gave it a tap and it went into place. After a few times of that, it settled in nicely. However, it is probable that you have something installed wrong.
Re: Lock Bar Help
I couldn't be certain because I've never taken a DF apart but from memory I think the spring bar in my Stretch could go in back to front. I put it back the way it came out and didn't have an issue but perhaps yours went in back to front.
Re: Lock Bar Help
Yea the spring is the only thing that can be installed incorrectly as far as I can tell. I'll flip it and see but I think it's in the correct way. Hmmmmm
Bloke wrote:I couldn't be certain because I've never taken a DF apart but from memory I think the spring bar in my Stretch could go in back to front. I put it back the way it came out and didn't have an issue but perhaps yours went in back to front.
Re: Lock Bar Help
Also my first thougt! Is the tang all clean? No bits or pieces between it and the lockbar?Bloke wrote:I couldn't be certain because I've never taken a DF apart but from memory I think the spring bar in my Stretch could go in back to front. I put it back the way it came out and didn't have an issue but perhaps yours went in back to front.
Re: Lock Bar Help
Make sure the screw in the lock bar isn't too tight.
Re: Lock Bar Help
That's exactly what it was. Started messing with it last night and realized I had it cranked down really tight. Thanks Evil!
Evil D wrote:Make sure the screw in the lock bar isn't too tight.
Re: Lock Bar Help
Ah, hahaha! :rolleyes:Evil D wrote:Make sure the screw in the lock bar isn't too tight.
