Sal - Is the Military 2 still happening?
- bearfacedkiller
Re: Sal - Is the Military 2 still happening?
If I could convert all of my liner locks to backlocks I would.
The only Spydie I have owned with a bad lock was a liner lock (W&R fixed it right up though and it is solid now) and I have had bad liner locks from other makers as well. I trust liner/frame locks less than other locks.
- Scottie3000
You're technically correct. The cheapest knives all seem to have liner lock, but there is a huge difference in quality between a $4 knife-like-object and a well engineered and made liner lock. I have no qualms about the Military lock. It might not have the outright strength of some other designs, but for me, it's one of the easiest locks to use.archangel wrote:I do not own a millie yet because of the liner lock. It is so ordinary, you find it on $5 China knives.Plus I never understood why people favour a locking mechanism that puts the unlocking finger into the way of the blade's sharp edge.
I just want to test out the stop lock.
Which factory is the least busy? Schedule a stop lock model with them. :)
Unfortunately with that idea, I think an international maker with a new lock could slow things and QC down. Maybe give Sal a 2 week vacation in Italy. Is it too much to ask for K390? :)
-Brian
A distinguished lurker.
I often use a knife in conditions where I only have one hand to draw/unfold/cut/unlock/fold/put away, and if dropped, will be gone forever.Jazz wrote:You sir, are insane.jpm2 wrote:If I could convert all my folders to liner locks, I would.My least favorite, least trusting lock, so I had to say it.
I maintain the most secure grip during the unlocking and folding operation with a liner lock, than any other type. I have dropped, and sometimes lost other knives due to lack of a secure grip during this operation, but never a liner lock.
So that's my main reason.
The only bad liner locks I've encountered are the crappy gas station types, ones either given to me or someone else owned. If that's all you've experienced, I can understand the lack of trust.
I guess any lock can come defective or badly designed. I've had most problems with back locks, excluding spyderco. Also see the above reply.bearfacedkiller wrote:If I could convert all of my liner locks to backlocks I would.
- bearfacedkiller
There is no right and wrong answer here, just preferences.
I carry plenty of liner locks even if they aren't my preference. I carry a Military more than any other knife at the moment and the one Spydie I had with a bad lock was a Military.
Since, you mentioned dropping knives I will add my feeling on that one. I sometimes have butter fingers and have been known to drop a knife on more than one occasion. When I drop a liner/frame/compression lock they usually open on impact. I dropped my K2 this morning on tile and it came open. Luckily there was no damage. I have dropped a Para2 on asphalt and it did come open and it bounced and I lost the tip. The other day I dropped my Police4 in my kitchen and as it was happening I was thinking thank goodness it is a back lock. They never come open when dropped. I know that has nothing to do with dropping them and losing them but the strong bias towards closing is nice when they fall on hard surfaces.
Very good point.
Michael
- Surfingringo
Hey jpm2 I probably like backlocks the best for the same reason you like liner locks. I'm opening and closing on a kayak in 100+ feet of water so dropping a folder is expensive. I am able to close my back locks very securely with one hand. I would agree that a linerlock is prettt secure in this regard too.
The only knife I've ever dropped while closing is a compression lock pm2. Doesn't mean I don't like the compression lock, I just think it is slightly more prone to "grip slip" while closing...at least for me. And like Darby said, both times I dropped the pm2 it'll the blade flew open on impact (tile floor both times of course :rolleyes: ).
For the record though, spyderco doesn't make a lock that I don't like. Some I prefer more than others for specific tasks but there's no spyderco that I wouldn't buy and enjoy using because of the lock.
Wouldn't you agree that any knife you can wrist flick open can open on impact. I dropped my Native 5 and had it partiallly open once; 90 deg.
Peter
You might want to consider using a lanyard and put the lanyard around your wrist. They have some devices that you can put on a lanyard to make sure they stay around your wrist.jpm2 wrote: I often use a knife in conditions where I only have one hand to draw/unfold/cut/unlock/fold/put away, and if dropped, will be gone forever.
I once went on a boat with a VG-10 Dragonfly, I used a lanyard because I didn't want to drop it in the ocean.
-Brian
No doubt lock type is personal preference, mostly.
Anyone who handles one everyday will drop it. Knives with the least detent, like liner
locks, are for sure more likely to open on impact.
For me personally, liner locks require the least amount of hand movement to unlock and close the blade. If the back lock isn't too far from the pivot, like dragonfly, native, earlier delicas and enduras, they are ok too.
The military is one of the very few 4" folders I can securely manipulate, hope they don't do away with its linerlock.
Lanyards are ok when extended use is needed. More often than not tho, I need to draw the knife, position it where it's needed, open it, make a quick cut, unlock and fold it up still in position of the cut, and then pocket it, freeing up that hand. I work from ladders, manlifts, scafolding, above grating, water, sumps, pits, in confined spaces, sometimes in very awkward positions laying on my belly/back/side, straddling pipe or standing on I-beams with harness and lanyards all over me.
Having a knife dangling from my wrist when using that hand for other tasks just wouldn't work in my situation, which I realize is uncommon.
I welcome a 4 way carry stop lock Military.
Exactlyarchangel wrote:I never understood why people favour a locking mechanism that puts the unlocking finger into the way of the blade's sharp edge...
If it weren't for the liner lock, I'd have a few millies. Instead, I have none
Ryan
“Every created being is so constituted as to be capable of vice and virtue. For he can do nothing praiseworthy, if he had not the power of turning either way.” - Justin Martyr
Oh well, I tried to explain it.Ryno wrote:Exactlyarchangel wrote:I never understood why people favour a locking mechanism that puts the unlocking finger into the way of the blade's sharp edge...
Never a cut unlocking and folding them.
I also unlock backlocks with thumb in the path, if they are one hand friendly. Never a cut with them either.
It's possible to close compression locks in the grips you're describing. I'd imagine you'd take some distaste to the stop lock.Surfingringo wrote:Hey jpm2 I probably like backlocks the best for the same reason you like liner locks. I'm opening and closing on a kayak in 100+ feet of water so dropping a folder is expensive. I am able to close my back locks very securely with one hand. I would agree that a linerlock is prettt secure in this regard too.
- Surfingringo
You know, I realized that a number of years ago and yet I still never close them that way. Might be that it's just too much fun free dropping the blade on a compression lock. So, clearly, if I drop one on the tile floor again I have no one to blame but myself. :DWanimator wrote:It's possible to close compression locks in the grips you're describing. I'd imagine you'd take some distaste to the stop lock.Surfingringo wrote:Hey jpm2 I probably like backlocks the best for the same reason you like liner locks. I'm opening and closing on a kayak in 100+ feet of water so dropping a folder is expensive. I am able to close my back locks very securely with one hand. I would agree that a linerlock is prettt secure in this regard too.
I've had the Para 2 open in pocket once, stuck my hand in and God must've protected it because I didn't realize it was open until I looked again later.
RanCoWeAla
Please make a Military with tip up pocket clip. The liner lock is fine
I would say that any folding knife can open on impact. I've got a ZT0452CF, and that knife has a very strong detent. It exclusively opens by flipper (no hole, no thumbstud, no wave) and it's a long heavy blade, so it needs a particularly strong detent. It's strong enough that when I let my girlfriend borrow it, she tried to open it and went "This doesn't work, am I doing something wrong?" It's a stronger detent than I've ever seen on a Spyderco. But I've seen it open on impact half a dozen times.anycal wrote:Wouldn't you agree that any knife you can wrist flick open can open on impact. I dropped my Native 5 and had it partiallly open once; 90 deg.
Increasing detent to the point where it can't open on impact is a fool's errand which would have negative effects on usability.
Ditto. I would add a stop pin, though. Back lock is the better lock.bearfacedkiller wrote:If I could convert all of my liner locks to backlocks I would.
This is one reason, among several, why I do not like nor trust liner/frame locks.h8speech wrote:I would say that any folding knife can open on impact. I've got a ZT0452CF, and that knife has a very strong detent. It exclusively opens by flipper (no hole, no thumbstud, no wave) and it's a long heavy blade, so it needs a particularly strong detent. It's strong enough that when I let my girlfriend borrow it, she tried to open it and went "This doesn't work, am I doing something wrong?" It's a stronger detent than I've ever seen on a Spyderco. But I've seen it open on impact half a dozen times.anycal wrote:Wouldn't you agree that any knife you can wrist flick open can open on impact. I dropped my Native 5 and had it partiallly open once; 90 deg.
