Why not make lockbacks with wooden handles?
Mikael Andersson
Post by Mikael Andersson »
There is something missing in Spyderco's lineup... knives with wooden handles.
There could be cocobolo, rosewood, american oak, snakewood and many many more.
And the blade steel could be the improved razor blade steel 14C28N which is both sharp and highly rust resistant.
jdw
Re: Why not make lockbacks with wooden handles?
Post by jdw »
nm
--Wovoka
Donut
Post by Donut »
You mean like the Sage 4? http://www.spyderco.com/catalog/details/C123WD/716
There was a wooden handled fixed blade, the first bushcraft? With Golden being in Colorado, the wood handles didn't respond well to the changes in air pressure.
-Brian
A distinguished lurker.
EDC Honeybee
Post by EDC Honeybee »
Having done some of this stuff, there are a few problems.
Using exotic woods can be really hard with manufacturing processes. G10 and micarta annd steel and aluminum and FRN are all really predictable. If spyderco used wood, they might expect to waste more parts due to natural variations, warp, etc.
Next, wood isnt as durable. The spring in lockbacks is held in a pocket in the handle which may be a common point of failure if made from wood, since wood will likely crack as it goes under moisture, drying, cold, hot, all under spring pressure. Spyderco could just make the scales from wood to prevent this problem, but then there is the problem of compression, expansion, etc. Most of spyderco's knives are made to close enough tolerances that these factors could be a problem.
Next, wood takes more time and $ to finish. peel-ply g10 has the finish built in. There are lots of established processes for finishing steel. FRN has the finish mostly built in. Wood usually takes some sort of finishing process and can add cost.
Ideally, wood scales should be from a consistent wood, and should be a part of the knife that isnt structural. I think the Boker Urban trapper cocobolo is a perfect example. Some might mention the Sage (what number is it?) with the (ironwood?). I saw a few at the seconds sale, all with broken scales where the wood cracked along the grain due to the screw tension.
Anyways, its not impossible, not impractical, but has many challenges that aren't necessarily in Spyderco's current wheelhouse. Maybe go support a maker who makes wooden scales that you like? I know that myself, Boomer, Knockwood Blades, and many others make scales for spyderco knives, some from wood. To me part of the draw of wood is the warmth that comes from the item being completely unique. Factory-made wood takes away some of that "warmth" to me.
Mikael Andersson
EDC Honeybee wrote:Having done some of this stuff, there are a few problems.
You are mad as a hatter. :p
VashHash
Post by VashHash »
I'd prefer stag handles
Mikael Andersson
VashHash wrote:I'd prefer stag handles
You want to slaughter innocent wild and free animals just to get your **** side scales?!
Heh, just kiddin'. ;)
VashHash
Post by VashHash »
If that's what it takes.
On a side note. Antlers drop every year. Trees don't just drop branches. We're slaughtering millions of trees for handle scales already. I think wood scales are unethical..... But snakewood sure does look good.
Mikael Andersson
Ah, yes they do drop each year... it's just the small matter of finding them out in the woods.
bearfacedkiller
Post by bearfacedkiller »
I don't know about Louisiana but here in the north east we spend a bit of time each spring picking up branches. Maybe it is our windy fall days or our New England winters but our trees drop branches and lots of them.
I assume that unlike 50 years ago when stag came through the same supply channels as furs that today most of it comes from farm raised animals. Elk and deer are both being farmed in large numbers these days.
Anyhow, I like the idea of more wood and started a thread just a little while ago about it.
//forum.spyderco.com/viewto ... =2&t=72595
Donut
Post by Donut »
I have enough traditionals with wood scales. I even have a Japanese swiss army knife style knife with wood scales. I think wood was one of the cheapest scale materials on those.
For the "tactical"/easy use/tool knives, I'm alright with G-10, Carbon Fiber, Glass fiber < one of my faves, and Titanium.
-Brian
Donut
Post by Donut »
I was just thinking about all of the wooden scaled Spyderco's I've seen on here.
I assume that you know that you can pay a custom modder about $100 to create almost every suggestion I've seen you suggest on here. As long as it is a different scale or the blade is shorter, it's all just a mod away.
If you wanted something with a longer than production blade, you could probably put $500-$1,000 into having a Spyderco licensed knife maker create one for you.
-Brian
SpyderEdgeForever
Post by SpyderEdgeForever »
A compromise would be wood-LIKE scales. Say, synthetic materials that mimic wood but which are far more durable and resistant to the elements, and also stabilized woods like pakkawood and diamondwood (anyone here remember that? Wood with plastic permeating the layers). I like the idea of the Sandvik stainless alloys, those are very good. How about an Endura 4 with VG10 steel and some form of stabilized wood and standard backlock? Would people be up for that if it was offered? Or a Delica of the same materials.
jalcon
Post by jalcon »
Synthetic wood? Vomit!
SpyderEdgeForever
jalcon wrote:Synthetic wood? Vomit!
What is wrong with it? It can have the same look of wood with greater durability and no splintering or rotting.
Great for a new line of Spyderco Knife handles. sal can call them the "Woodlands" and they can feature similar blade shapes to what exists but with a range of synthetic wood handle colors and textures. How about polymer wood with Volcano grip texturing?
Bill1170
Post by Bill1170 »
Stabilized wood isn't "synthetic" any more than clear finished wood is. Main difference is that the finish penetrates all the way through the wood for better protection.
bearfacedkiller
I have seen quite a few stabilized woods crack with the grain. The stabilizing does not make them the same as g10. It depends a lot on the type of wood and the grain. This is even more likely to happen if the wood is an end cut. People like the grain of the end cut and think that the stabilizing makes the wood bombproof but that isn't true. Stabilized woods can also weigh as much as twice what they did before stabilizing but that too depends on the type of wood. I still like stabilized wood and would like to see more of it but for the reasons listed above I am also in favor of other wood like options including laminated wood like we see on guns and composite woods made from sawdust if they are done right.
bearfacedkiller wrote:I have seen quite a few stabilized woods crack with the grain. The stabilizing does not make them the same as g10. It depends a lot on the type of wood and the grain. This is even more likely to happen if the wood is an end cut. People like the grain of the end cut and think that the stabilizing makes the wood bombproof but that isn't true. Stabilized woods can also weigh as much as twice what they did before stabilizing but that too depends on the type of wood. I still like stabilized wood and would like to see more of it but for the reasons listed above I am also in favor of other wood like options including laminated wood like we see on guns and composite woods made from sawdust if they are done right.
I wonder if wood can be shaved/sliced thin enough to layer it and make a wood micarta?
bearfacedkiller
yeah, it is laminated wood. It is heavier than wood just like stabilized wood but it has the alternating grain layers that plywood has so it is much stronger than stabilized wood. It is often used on rifle stocks. It would be more of a ply wood than a micarta.
bearfacedkiller
from wikipedia;
"Laminated wood consists of two or more layers of wood, impregnated with glue and attached permanently to each other. The combination of the two pieces of wood, if laid out correctly, results in the separate pieces moderating the effects of changes in temperature and humidity. Modern laminates consist of 1/16 inch (1.6 mm) thick sheets of wood, usually birch, which are impregnated with epoxy, laid with alternating grain directions, and cured at high temperatures and pressures. The resulting composite material is far stronger than the original wood, free from internal defects, and nearly immune to warping from heat or moisture. Typically, each layer of the laminate is dyed before laminating, often with alternating colors, which provides a pattern similar to wood grain when cut into shape, and with bright, contrasting colors, the results can be very striking. The disadvantage of laminate stocks is density, with laminates weighing about 4 to 5 ounces (110 to 140 g) more than walnut for a typical stock.[16]
While wood laminates have been available for many years on the custom market (and, in subdued form, in some military rifles), in 1987 Rutland Plywood, a maker of wood laminates, convinced Sturm, Ruger, Savage Arms, and U.S. Repeating Arms Company (Winchester) to display some laminate stocks on their rifles in a green, brown and black pattern (often called camo). The response was overwhelming, and that marked the beginning of laminated stocks on production rifles."
