With my new CBN rods that I received for Xmas, I successfully re-profiled my Dad's ultra-dull Byrd Tern and then decided with one knife under my belt, I'd attack my most carried knife, thus most sharpened, the Chappie. Now, I knew going into this, that 8Cr13MoV on the Tern was going to be a quicker process than the XHP, but I've been making progress on the SM with the CBN on one side but the process is even more slow than I anticipated due to what is obviously quite the obtuse factory bevel. I've had to remove lots of steel from the shoulder and after 2 separate sessions, I've hit the apex on one side. (I actually find the process soothing and therapeutic, so in no rush).
So my question is... Is the factory bevel obtuse on all the Chappies by design or does it just ends up being what it is based on the "factory grind guy?" If they're all obtuse, is there a benefit to this? I was thinking that due to the blades thinness, maybe a more obtuse bevel is ideal for added strength. I'm at the point that I'd ideally like to make all my knives have a 30º inclusive back bevel and 40º inclusive micro-bevel so I can easily work with the SM for my needs. It's slow for this type of work, but I don't mind... yet.
Thanks.
My Knives: Paramilitary 2 - Chaparral - Delica FFG - Dragonfly 2 (HAP40) - Tenacious - Crow 2
