last week I received a Ti fluted Millie directly from Spyderco and I just wanted to share some Ti-pimp features with you. I really like the knife, it is built like a tank, slightly slimmer than the regular Millie and....blab blah features discussed a million times :rolleyes:
Here is what I did. I really like the seashell pattern but the 'silverish' appearance of the new knife doesn't show it that much around the pivot where the patternlines are finer and the milling shallower. It is there but not enough to my likings. So I sandblasted the scales with Aluminum-oxide and than sanded them lightly with 2000 grit sandpaper. That made the deeper milled parts coarse and darker while the higher 'ribs' of the pattern came out shiny. It contrasts very nicely, even in finer parts of the pattern around the pivot. I emphasize 'lightly'; putting to much pressure on the sandpaper and the deeper milled parts will be shiny as well and than the entire effect is gone.
You can also see some other lines from the milling process in the scales, but that is fine. This 'highlighting'-technique also gives the knife a worn and aged appearance.
I hope the pictures show my story a bit, I am not much of an photographer....sorry :o
Finally I replaced the screws and clip by Ti and added a Ti-spacer, I hate it when keys or coins ruin my edge when carrying in an open construction.
Screw together, loctite, breakfree and done... :) Ti is a really wonderful material to work with.
cheers,
Tom
