Yojimbo 2 lock is sticking.
My Yojimbo 2 blade was tight to open so I sprayed some oil and loosened the pivot screw. Now when I close it the lock sticks, it never stuck like that before moving the pivot screw. So did I make the compression lock bar slide further into the knife by loosening the blade and adding oil?
ii_pennies
Re: Yojimbo 2 lock is sticking.
Make sure there is no oil in the lock area and on the lockbar
- farnorthdan
You could also try loosening the stop pin and rotating it a wee bit.
- farnorthdan
Hey welcome to the forum. :)ii_pennies wrote:Make sure there is no oil in the lock area and on the lockbar
ii_pennies
Thank you very much. Im done lurkingfarnorthdan wrote:Hey welcome to the forum. :)ii_pennies wrote:Make sure there is no oil in the lock area and on the lockbar
Welcome to the forums!ii_pennies wrote:Make sure there is no oil in the lock area and on the lockbar
I took the whole knife apart cleaned everything a spun the stop spin, and it's still sticking. I think the detent is too strong so Im thinking that I need to bend it back some.
