The mantra is a frame lock and does not require a kick to stop the blade from closing too far. The Delica will keep the ricasso as long as it has a backlock.jstrange wrote:A Delica the same size and shape as the Mantra, but still an FRN lock-back, with the Native lock would be my ideal knife. Or simply put, stick the Mantra blade on the Delica handle, upgrade the lock, and call it a day.
sal wrote:Knife afi's are pretty far out, steel junky's more so, but "edge junky's" are just nuts.![]()
jstrange wrote:I like the general design of the Delica so I wouldn't want too much change. I would like to try incorporate the newer lock from the Native series into the Delica and I would push the blade to closer to 3" to give it just a little more edge and fill the handle a bit. If it were just a tad bigger it could be my one do-it-all knife. Oh, and I keep the nice thin stock, but I would give it a straight spine again all the way to the tip. I love a pointy tip.
The hump was added to the tip because of too many reports of broken tips. Fifteen minutes with some 100 grit sandpaper fixes that anyway.MichaelScott wrote:Yep, straight spine all the way to the tip. That little droop kind of bothers me. Why is it there? Any functional reason? I would make the clip a bit slimmer, more in keeping with the overall form of the knife. If I was to get more radical, I'd like to see a Delica in a classic Wharncliffe blade shape. VG10 is fine as it is a fine steel and keeps the costs down. My Sharpmaker will keep a fine edge on my VG10 steel and my CPM M4. Oh, and an OD scale color would be nice.
If I didn't have a Bradley 2 I'd probably have a Delica 4, Spyderco's best (function, size, weight, quality and cost) knife when you can only have one.
Okay, makes sense, but I still wish the blade was a little longer.bearfacedkiller wrote:The mantra is a frame lock and does not require a kick to stop the blade from closing too far. The Delica will keep the ricasso as long as it has a backlock.jstrange wrote:A Delica the same size and shape as the Mantra, but still an FRN lock-back, with the Native lock would be my ideal knife. Or simply put, stick the Mantra blade on the Delica handle, upgrade the lock, and call it a day.
+1 Nothing to change or fix as far as I'm concerned. The handle fits my hand perfectly, the blade is a good length and shape for my needs, and I find the bi-directional texturing on the FRN nice and grippy. If I want something different I'll reach for a different model as I often do. Like so many of the Spyderco models, I think the Delica is a well thought out individual and I like it just the way it is.tvenuto wrote:Nope. For what it is, and for me, the Delica is perfect as is.
Michael,MichaelScott wrote: I'd like to see a Delica in a classic Wharncliffe blade shape.
Previous Delica models had a straight spine with no droop and people complained about the tip being too fragile. As the saying goes, it's easier to remove a bit of metal on your own and make the tip pointier if you want it that way, than for someone else to make the tip stronger. Gotta remember that we only represent a tiny fraction of the Delica market, and most of the people buying them likely abuse their knives more than you or I.MichaelScott wrote:Yep, straight spine all the way to the tip. That little droop kind of bothers me. Why is it there? Any functional reason?
This is a good call. I have both and it's like the Mantra is the 3rd iteration after the Delica and the Caly3.tap78 wrote:I suggest a Mantra... this is in my oppinion a refined delica
Users browsing this forum: Granoo Fink, rhaug, standy99, Sumdumguy, tonijedi and 41 guests
