I'd have to say something with a longer blade, and I'd just start whacking and waving.
Bird-Defense Spyderco?
Re: Bird-Defense Spyderco?
Where do you come up with your questions, bro?
- best wishes, Jazz.
I'd rather have a tennis racquet, but of my spydies I'd go Rock Salt.
Easy, Whale Rescue Blade with the rounded tip ground to a point and double edged...on a stick
- SpyderEdgeForever
By the way that is something I wondered, too: Do you think out of all the persons who have purchased the Whale Rescue blades so far, at least one or more has ground a functional point on the end and used it for other purposes in the field than rescuing marine animals?Scroop wrote:Easy, Whale Rescue Blade with the rounded tip ground to a point and double edged...on a stick
- The Deacon
SpyderEdgeForever wrote:By the way that is something I wondered, too: Do you think out of all the persons who have purchased the Whale Rescue blades so far, at least one or more has ground a functional point on the end and used it for other purposes in the field than rescuing marine animals?Scroop wrote:Easy, Whale Rescue Blade with the rounded tip ground to a point and double edged...on a stick
Don't think I'd grind a point on it, but I've considered buying one of the Whale Rescue Blades and mounting it on a pole as one more weapon in my annual battle against the green monster.
Spyderco logo decal + machete = birdpocalypse survival.
- SpyderEdgeForever
Good one :)
Hmmmm...a Spyderco SicleThe Deacon wrote:SpyderEdgeForever wrote:By the way that is something I wondered, too: Do you think out of all the persons who have purchased the Whale Rescue blades so far, at least one or more has ground a functional point on the end and used it for other purposes in the field than rescuing marine animals?Scroop wrote:Easy, Whale Rescue Blade with the rounded tip ground to a point and double edged...on a stick
I was body-slammed by a 48-pound turkey, once upon a time. As he did not press the attack, no defense was needed. Unless I sold him, when he was ready for the oven, he got the axe, brand name now forgotten.
:eek: Hit the dirt and peck your a$$ goodbye.
