If you could combine any two models into one knife...
What would you make? I mean literally blend aspects of both knives..
Mine would probably still be a Yojimbo 2 handle paired with a Manix 2 blade, or perhaps just give the Yojimbo 2 a leaf shaped spine after the thumb-dip area and give it as much belly as the Manix 2 blade.
Junior with a Superhawk blade (heck, Junior handle with a lot of different style blades)
Delica with a Harpy handle
Endura with a Civilian handle
Re: If you could combine any two models into one knife...
Ladybug blade with a Szabo folder handle. :p
gad226
Post by gad226 »
A Delica shaped Chokwe.
Dodge
Post by Dodge »
Lum tanto folder handle with thicker catcherman blade.
Rescue 93mm handle with a jess horn blade
Flash Batch request: Flat Iron Salt (CE w/ yellow FRN)
New knife request: Police 4 Salt!!!
“Don’t be so open minded that your brain falls out”
Holland
Post by Holland »
I would combine a tenacious blade with a delica handle and convert to Ti handle and M4 blade :D
On a serious note, chaparral size and shape mixes with something to give it a comp lock instead of the back lock
farnorthdan
Post by farnorthdan »
Nilakka blade with Caly handle
Native5 LW with a Manix2 LW lock and clip...
Manix2 XS would complete the family :)
Post by The Deacon »
Stretch variant with a blade shaped like the Large Dyad's PE blade.
Another Stretch variant with a straight spined blade like the Military's.
And yet another Stretch variant with a blade the thickness of the Chaparral's.
Kiwi 4 with a bolster and scales handle like the original Kiwi's.
hoimin
Post by hoimin »
Gayle Bradley 2 build in Caly 3 length dimensions with real CF scales over proud titanium liners and black wire deep-carry clip
Holland wrote:I would combine a tenacious blade with a delica handle and convert to Ti handle and M4 blade :D
You're talking about the Mantra right?
Holland wrote:On a serious note, chaparral size and shape mixes with something to give it a comp lock instead of the back lock
I agree about the Chap. It would be nice to have some more similar options to that pocket perfection.
twinboysdad
Post by twinboysdad »
Superleaf blade shape and thickness in a PM2 handle
hoimin wrote:Gayle Bradley 2 build in Caly 3 length dimensions with real CF scales over proud titanium liners and black wire deep-carry clip
Some great ideas in this thread!
Agreed!
Military with the compression lock, large choil, 4 way clip, beefier screws and lanyard hole of the PM2
Surfingringo
Post by Surfingringo »
I would like the Spyderco Military blade and handle made in an frn lock back design with 4 way clip. They could also do a liner-less H1 salt version of this.
Joris Mo
Post by Joris Mo »
The main one has already been named, the Shaman.
Some other ones I will like to see eventually are the Minuteman and possibly the smaller version of the K2.
I would also like a blade with the handle of a Chinook, with a compression lock and a blade more like the K2 in M4. :)
Joris Mo
Post by Joris Mo »
Surfingringo wrote:I would like the Spyderco Military blade and handle made in an frn lock back design with 4 way clip. They could also do a liner-less H1 salt version of this.
Make it in SE as well! :D
Surfingringo
I thought that went without saying! :)
Military & Para 2.
I want a Paramilitary 2 the size and weight of the Military. That would be the perfect EDC knife for me.
If I could go one step further, I'd like a FFG H1 variant of this knife for the summer months. One can dream :D
SpyderNut
Post by SpyderNut »
I would like to see the SE "alligator" blade from the Dyad Jr. in the Bradley Air handle. Or a larger Dyad SE blade in a Catcherman handle. H1 would be sweet!
:spyder: -Michael
