Postby JBE » Mon Mar 09, 2015 8:40 am
When removing or re-installing screws place the knife on top of a firm, foam pad that is on top of a hard surface, e.g. the foam insert that comes with the knife in the box, mouse pad, etc. Use straight up and down pressure. For a loose fitting T6, find a thin rubber band (or other thin piece of rubber, like off of a latex glove), place over the screw and insert the driver into the torx screw through the rubber (if that makes sense). It creates a tighter fit and helps keep the screws from stripping. Make sure it's a pretty thin piece of rubber/latex because those torx screws are small. Hope this helps.
