Manix 2 g10
Enduraguy96
Manix 2 g10
Just ordered one of these, very excited, the only bad thing I've heard is the lock takes a while to get to a sweet spot.
Any reviews on the manix2 ?
para military 2
Fallkniven f1
Endura 4 ffg
manbug superblue
tenacious x 2
manix 2 g10
Fallkniven f1
Endura 4 ffg
manbug superblue
tenacious x 2
manix 2 g10
Re: Manix 2 g10
I have 2 right now, the Regular satin Manix 2 G-10 and the DLC (black coated) G-10. The Manix 2 is my favorite Spyderco by far. It fits my hand slightly better than the PM2 (blasphemy, I know) and fits better in the change pockets of my jeans better. The handle on the PM2 is just a little too long to fit without tilting it in my change pocket, making extraction a little harder. The lock was easy for me and I did notice that it "broke in" after some use. I have strong hands and fingers though, turning rusty bolts with 2 fingers on a regular basis will do that LOL. I pick the Manix 2 more than any other folder for EDC. I have have some of the most popular folders that Spyderco makes in the two Manix 2s, a PM2, Tenacious, Delica, Stretch, and Sage 3. I pick the Manix 2 four days a week or more for EDC, it just fits my hands, pocket, and use better than any of the others.
The Sage 3 is very close though, I just can't bring myself to get oil, gear lube. or road grime on it. I'll probably have to buy another so I don't just use it as a "Dress" folder, which that's what it does on Sundays. It reminds me of the Manix 2 but with a much easier to actuate lock. The ergos feel very close to the Manix 2. If you like the Manix 2 when you get it I suggest you check the Sage 3 out. It also needed "broken in" but for the opposite reason. It was too easy. After a week of play it started working perfect, could have been a slight burr on the lock or who knows what but it's perfect now. It's also the nicest finished Spydie I have, just gorgeous.
Here's some pics of them:
With the Sage 3 and Manix 2
[URL=http://s1130.photobucket.com/user/ ... .jpg[/img]
[/url]
[/url]
The 2 Manix 2s
[URL=http://s1130.photobucket.com/user/ ... .jpg[/img][/url]
I learned a long time ago that if I like something get 2, usually things get discontinued right after I find out I like it. The Manix 2 is just such a folder for me. The only other thing that people dislike is the 5 ounce weight. Me, I don't notice it. If a 6'1" 200 lb guy can't carry 5 ounces then maybe he needs to examine his physical fitness level because something is wrong. I bought the Manix 2 because it seemed to be the sturdiest folder Spyderco builds in that size. They even use the words "hard use" knife in the description. My next will be a Native 5 G-10, then I'll be able to compare those two and make a final decision on which I find better suited to my needs. The Manix 2 is going to be hard to beat for me though.
[/url]
[/url]
The 2 Manix 2s
Re: Manix 2 g10
Hey Mastiff after purchasing the grey Cruwear variant, Manix2 started to grow in me.It has skeletonized liners so it's lighter.After being a Para fan, Manix 2 gives me the feeling of a much more sturdy knife.I have a question: does it have a "pivot bushing"? I had a nasty experience with one of my Para's since it has side to side blade play.
Re: Manix 2 g10
I think it does, I remember watching a vid of a guy taking one apart and I remember the pivot bushing dropping out. It's pretty smooth so it could be.
Edit: Here's the vid I watched: https://youtu.be/7c_9vtjda3o" onclick="window.open(this.href);return false;
It looks like it does @ 4:00 minutes in. Mine hasn't had a problem and I sit and flick my folders when I'm bored.
Re: Manix 2 g10
I've got the cru-wear version, great knife. The lock took 3 days of playing to "break in", but the bigger part of it imo is YOU get used to the lock. Don't worry about it, your fingers will take a beating for a few days but it's worth it. Pick up some "O'Keeffe's Working Hands" and you'll be just fine.
- SpyderMan -
Re: Manix 2 g10
Not really a review, but I love my G-10 Manix 2. Probably as much as my PM2's, matter of fact.
Re: Manix 2 g10
I have 3 of them with G10 and also the S110V version with FRN scales.
The Manix 2 is a heavier, more solid feeling knife than the PM2. The grip shape does fit my hand better than the PM2 although I still like the PM2.
3 of my 4 have very smooth locks, no break-in required.
Re: Manix 2 g10
If the question is "Manix 2" the answer is "yes!"
The s110v lightweight is especially good. But at this point I own a lot of different flavors and I still come back to the s30v G-10 (my first) fairly often. And that's with the s110v lightweight, cru-wear, M4 and s90v all in my rotation. The only one that doesn't get a lot of pocket time is the BD-1 lightweight, partly because it's outclassed by the s110v and partly because one of my employees appropriated it and carries it almost constantly.
I prefer the Manix to the PM, mostly because I like the CBBL better than the Comp Lock. The only real competitor to the Manix is the Sage 3, which is basically filling the "mini-manix" role in my rotation.
Enduraguy96
Re: Manix 2 g10
:spyder: Turns out the manix 2 g10 is a darn fine knife!
para military 2
Fallkniven f1
Endura 4 ffg
manbug superblue
tenacious x 2
manix 2 g10
Fallkniven f1
Endura 4 ffg
manbug superblue
tenacious x 2
manix 2 g10
Re: Manix 2 g10
I've had a bunch of Manix2 and Manix XL variants. Never had a single one that had a lock that changed from the moment I first handled it. Maybe it's pure chance.
I just put some of Allen Putnam's toxic green scales on my Manix2, and cut a couple coils off the spring to lighten it up. I'm still not a big fan of the lock, and the knife is heavier than it should be (I'm a fan of FRN), but it's a great knife, I guess.
"We have more metal parts fail than plastic parts. Modern plastics are tough. 'Feeling cheap' may be a false perception and one might need more education. We rarely get a FRN knife back with handle problems and we have millions of them out in daily use. " --Sal Glesser
Re: Manix 2 g10
How do you like the Cruwear steel? There is currently one of those in my local shop and it looks intriguing. Does the grey/cream G10 get dirty easily?elena86 wrote:Hey Mastiff after purchasing the grey Cruwear variant, Manix2 started to grow in me.It has skeletonized liners so it's lighter.
I was never a fan of the old Saber ground non-skeletonised manix 2 but the newer one does. I have one of the lightweights which is a very nice knife so would like to check out the G10 version.
Bruno
Re: Manix 2 g10
Cruwear is a great allaround steel.People say the light grey G10 does get dirty quite easy but I wouldn't know since I do not carry mine every day.My cruwear Manix is destined for outdoors and long trips and I will take care not to use it with dirty hands.It's not a biggie for me anyway.I supose you could somehow clean the G10 handle.For edc I have the light S110V variant.But usually I carry my sage1 which is very close in shape to the Manix2.glbpro wrote:How do you like the Cruwear steel? There is currently one of those in my local shop and it looks intriguing. Does the grey/cream G10 get dirty easily?elena86 wrote:Hey Mastiff after purchasing the grey Cruwear variant, Manix2 started to grow in me.It has skeletonized liners so it's lighter.
Bruno
Re: Manix 2 g10
Manix2 (whatever the steel and scale) and buyer's remorse are two ideas about as diametrically opposed as can be.
- dreadpirate
Re: Manix 2 g10
Look at the Manix 2 with blue FRN handles and S110V, really nice. Also - the Sage 1 is a very, very smooth liner lock knife. The handle in the Sage 1 and 2 is slightly more narrow than the Sage 3, although the blade is the same on all three. Although carbon fiber and G10 handles feel better in the hand - the FRCP/FRN handles are probably more practical and have a superior grip for a work knife. The Manix 2 is a bit wide; I think the Native 5 is the sweet spot in terms of size (similar to the Sage, except the Sage has a thumb ramp). Just right in length and width. A good general purpose blade shape.
Re: Manix 2 g10
Bruno
My cru-wear's g10 definitely got dirty, and fast. However it did so very evenly with no splotchy stains or anything, (I was worried at first) it is now just a darker shade of grey. When I first got it I tried cleaning it as it got dirty, cleaned up well but in the end it was too much trouble. I decided if it started to look bad I would just buy custom scales but as it darkened evenly I really like it. The steel is quite good, holds an edge well and sharpens up without any trouble.
