Isn't the only "Native" with 440A steel the "BRK Native"?
This guy is selling "Natives" that are 440A steel, but have no "first generation" etc., markings on the blade.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0066936381
I'm not sure, so I thought I would ask. Maybe they sanded it off or something.
Described as: "This is a Spyderco Native Model. It has a handle of ballistic nylon. Blade is 440A, serrated except for the tip. Measures 3 7/8" long closed. Belt clip on reverse. Made in USA".
Native in 440A?
- bohica1998
Native in 440A?
18 's and counting so far...
Current Inventory: C14SBK Rescue SE - C14SBL Rescue SE - C14PBK Rescue FG PE - C14SBK Rescue FG SE - C10PSGRWBK Endura USN CE Emerson Opener/Black Blade - LBK3HB Ladybug Hawkbill SE - C12SGY Matriarch SE G10 modded - C78PSBK Native 3 SE - C78PBK Native 3 PE - C41SBK Native 4 SE - C41PBBK Native 4 Black Blade PE - C41PSBBK Native 4 Black Blade SE - C77PYL SpyderHawk H1 PE - C106PYL Tasman Salt PE - C122GP Tenacious SE - BY22SBK Meadowlark Hawkbill SE - LGRP3HB USN Ladybug Hawkbill PE - LGRS3HB USN Ladybug Hawkbill SE
All clues point to it being a naked BRK Native:
1) Finer spine jimping
2) Silver clip
3) No Boye Dent
4) Obverse side engraving of "GOLDEN, COLORADO - U.S.A." in all caps, and missing Earth as per Native I's
I didn't have a naked BRK Native but someone else here may have.
2) Silver clip
3) No Boye Dent
Cheers
- The Deacon
I found the "1st Generation BRK" marking fairly easy to remove with light sanding. Everything else (steel, tang stamps, jimping, chamfered Spyderhole, lack of Boye dent, bright hardware) about the knife in that auction seems correct for a BRK Native, so am guessing the seller, or a prior owner, removed the markings.
