Reveal 6 - blacked out Autonomy 2’s (3).
Discussion of Restricted Models by Spyderco.
Burton Knut
Re: Reveal 6 - blacked out Autonomy 2’s (3).
Post by Burton Knut »
Couldn’t resist any longer and got one coming from KSF! This will rotate with my SE Caribbean Leaf as a compliment to my fixed blades when not at work.
Burton Knut
It’s here! It’s awesome! It’s going to get used!
Rinzler
Post by Rinzler »
I just bought one, in protest, because I found a killer price that I couldn’t pass up.
Burton Knut
Rinzler wrote:
Fri Jun 11, 2021 10:02 am
Share?
Rinzler
Post by Rinzler »
Seller on Reddit. PM me for details
Rinzler
Post by Rinzler »
I got the full serrated autonomy 2 today. This is my fourth autonomy and the action is the most disappointing of them all. My grandmother could open a para 2 faster than this blade opens. I’m going to disassemble, clean, oil, and maybe swap out the spring. Autonomies typically launch like a **** rocket but this particular model is soooo slow. I’m not feeling any resistance so it’s likely a weak spring. I’m sort of dissatisfied but luckily I’m able and capable to fix it on my own.
Burton Knut
That stinks. I had to check my backup just to make sure, but both of mine fire as expected.
Superflex
Post by Superflex »
I ordered the SE Autonomy 2 yesterday from KSF.
My first fully serrated blade
Hoping the problems Rinzler had with a weak spring and metal shavings dont appear in mine or were a function of the previous reddit owner
Demon85z
Post by Demon85z »
Superflex wrote:
Fri Jul 09, 2021 12:00 pm
Did yours come in yet?How is the action? I just ordered one from knifeworks. Its my first autonomy and first SE in lc200.
:bug-red-white I collect them all, and use them all! I use the excuse, "I'm trying to find the perfect one", but in reality, they are all perfect in their own way!
Mule Team Fan
Post by Mule Team Fan »
I have had a C165GPBBK2 on back order since last October with Blade HQ plain blade LC200N. I have called in twice to check status and they state not yet released. They say they will sell in the order you placed your pre-order, so does anyone have some insight on this matter? 😁
Rinzler
Post by Rinzler »
I should clarify that the blacked out serrated version I bought was an absolutely new knife from a dealer who sells on Reddit. Not a used knife.
I’ve opened it about 50 times and the button lock feels like it’s really gritty. I might pull it apart, take a picture, then reassemble to gauge observed wear on the part.
Demon85z
#32
Post by Demon85z »
Got mine in today from knifeworks. Full SE. First 5 or 6 fires it was having trouble firing hard enough to lock the blade out. I manually worked the blade in and out a few times, could feel it loosen up. Snaps right into place now no issues. I didn't have any grit or shavings in mine. I will say that the way the button pushes through the frame and scales on the opposite side of the button could be the issue some are having. If that thing is even slightly misaligned it could easy rub. Not a lot of clearance there, but by design that's the point and what makes it lock up solid. Overall very happy with it. Ive wanted one for a long time now and finally got my hands on one.
Buddafucco
#33
Post by Buddafucco »
Mule Team Fan wrote:
Sun Jul 25, 2021 12:22 pm
Hey Mule, welcome to the forum! :bug-red
The Blacked out plain edge Autonomy 2 did release. Looks like the first batch is sold out everywhere now though. I PM'd you a good lead if you don't want to wait for BladeHQ.
•• Beau
Superflex
#34
Post by Superflex »
Mine arrived almost 2 weeks ago.
I was really surprised how strong the spring is on this model.
Really snaps open with authority. No grittyness on open or close.
Touched it up on the brown rods just to give the spydie edge a bit more pop.
Not disappointed one bit with this model.
Mule Team Fan
#35
Thank you!
#36
Superflex wrote:
Fri Jul 30, 2021 9:54 am
Probably has to do with the blade being shorter and probably a little lighter weight. The same spring strength would open a lighter blade much faster.
Also, I'm in Erlanger and another member lives right up the road from me. :cheap-sunglasses
Superflex
#37
Post by Superflex »
Evil D wrote:
Tue Aug 03, 2021 8:10 am
Milford OH here but I work in Dayton KY.
Was working in Erlanger at the Duke gas plant on Crescent Springs Pike for the past 3 weeks repairing a leaking gas main.
#38
I'm trying to think of reasons this shouldn't be my next Spyderco, and I'm drawing a blank.
:unicorn
Rinzler
#39
Post by Rinzler »
Thu Sep 02, 2021 6:56 am
Even though I have some very nitpicky issues with it, it’s a great knife. Do it.
Buddafucco
#40
•• Beau
