Regrind - Manix S110V
_centurio_
Postby _centurio_ » Thu Jul 30, 2015 8:40 am
Hey folks,
I just finished my latest regrind. S110V is quite hard to finish, however it didn't took any longer than normal to abrade the material. I used new ceramic belts (60, 80, 120) and finished with a fleece belt.
Results are ok in my opinion, could be better...
The Spyderco Logo is still left a little tiny bit.
Thickness behind the edge is ~10 thousands of an inch.
Hope you like it.
BR Oliver :spyder:
Re: Regrind - Manix S110V
Postby Brock O Lee » Sat Aug 01, 2015 2:42 pm
Very nice Centurio !
I convexed mine by hand some time ago, it was way too thick behind the edge from the factory.
Favourites at the moment: Military 204P, Spydiechef, Sage 2, Pits, Heinnie UKPK, Native Cruwear, Chaparral Ti
HarleyXJGuy
Postby HarleyXJGuy » Sat Sep 19, 2015 10:38 am
Looks great.
Brock how did you convex yours?
Postby Brock O Lee » Mon Sep 21, 2015 11:43 am
HarleyXJGuy wrote: Brock how did you convex yours?
I ground away the shoulder of the edge bevel, and blended the edge and primary grind freehand on a bench stone (DMT XC and C). I finished with a 30 deg micro bevel with SM diamonds. DMT's are maybe not the ideal choice, but they worked well enough. It took about 40 mins.
The cutting ability has increased dramatically. It glides through hard apples for instance with noticeably less force, where previously it would have cracked them open. I have not seen any chipping on the thinner edge. The knife gets some light EDC use at home during the evenings and over the weekends: food, packages, cardboard etc. I would not abuse it like SBaker345 did to his here: :)
viewtopic.php?f=2&t=68484
Before:Image
After:
The most encouraging thing about this is that anyone who can sharpen a knife can do this at home. You do not need special skills, just a coarse flat stone and some common sense. Take your time and stay away from the apex until you switch to a fine stone at the end.
HarleyXJGuy
Postby HarleyXJGuy » Mon Sep 21, 2015 5:33 pm
Before:Image
After:
Ok then I will just send you mine to do?
Postby Brock O Lee » Mon Sep 21, 2015 11:34 pm
You can send it, but you might not get it back! :p
You see I am trying to get you to try this yourself... :)
Users browsing this forum: No registered users and 4 guests
