Show those Edges !!!!!
H1
VG-10
SR101
N690 Bohler
D2
S30V
VG-10
SR101
N690 Bohler
D2
S30V
- razorsharp
- razorback1595
- razorsharp
razorback1595 wrote:hey razorsharp, what do you use for those edges?? really love that super blue :p
mine's nowere near an edge like that but it's really my favourite edc knife :p
This :D . Took me a day to make. Few things getting tweaked here and there since I made it. I might make another, more tidy one :D
- ValueKnifeLover
Razorsharp that is amazing! I just ordered the Lansky 5 stone for cheap but I never thought of making my own similiar contraption! i love the angle options... This intrigues me... Maybe I will attempt something now :)
"Laws that forbid the carrying of arms..disarm only those who are neither inclined nor determined to commit crimes. Such laws make things worse for the assaulted and better for the assailants; they serve rather to encourage than prevent homicides, for an unarmed man may be attacked with greater confidence than an armed one." - Thomas Jefferson quoting Cesare Beccaria
I'm not sure how you're holding the paper on, but you could wrap it around your aluminum block and use a wooden dowel or something to wedge down in the channel, that would hold the paper on nicely.razorsharp wrote:
- razorsharp
- razorsharp
Yea it's freehand. Polishing the bevel makes it look better than it really is. :D I'm still having trouble right where the straight portion of the blade transitions up towards the tip on allot of blades. You can see from the pic that the bevel is wider at that point and slimmer at the tip. I'm also having to take great care to get sharp tips. I've gotten pretty good at stropping though with all the time it takes to polish the edge.
- razorsharp
outstanding results man, im sure they can split hairs :Dprime77 wrote:Yea it's freehand. Polishing the bevel makes it look better than it really is. :D I'm still having trouble right where the straight portion of the blade transitions up towards the tip on allot of blades. You can see from the pic that the bevel is wider at that point and slimmer at the tip. I'm also having to take great care to get sharp tips. I've gotten pretty good at stropping though with all the time it takes to polish the edge.
- chuck_roxas45
Prime77 gets one of the sharpest edges in BF so I guess those edges are sharper than 99 percent of the world's edges. :Drazorsharp wrote:outstanding results man, im sure they can split hairs :D
Prime, check out So-Lo's sharpening videos:prime77 wrote:Yea it's freehand. Polishing the bevel makes it look better than it really is. :D I'm still having trouble right where the straight portion of the blade transitions up towards the tip on allot of blades. You can see from the pic that the bevel is wider at that point and slimmer at the tip. I'm also having to take great care to get sharp tips. I've gotten pretty good at stropping though with all the time it takes to polish the edge.
http://www.spyderco.com/forums/showthread.php?t=45595
He shows a method that I try to use, the key is to keep hold at the same angle and basically rotate the knife around a pivot near the end of the handle.
I do this for my reprofiling with DMT coarse and Spyderco medium stone, then I try to apply some pressure near the edge with the finer grits... think trying to flatten part of a basketball by pressing it against the pavement. Only a lot less pressure. In my head, that will help give you a flat edge/bevel.
-Brian
A distinguished lurker.
So-Los sharpening vids series is the best out there and I learned allot from them. The mental image of the basketball is great and makes perfect sense to me.Donut wrote:Prime, check out So-Lo's sharpening videos:
Thanks. :spyder:OMG Prime77, freaking love the stone wash! I might have to do that on some of mine, stunning on the Para 2!
- chuck_roxas45
You can't really take credit for that, can you?
