Show your mods!
JAfromMN
Postby JAfromMN » Mon Jul 02, 2012 7:17 pm
Your contact's are good Donut
I let it tumble for a hour but I used smaller rock and more oil and metal polish mix than normal
I like the effect but I can't take a pick of it'
It's got a light stone gloss finish it's different.
It came out very even.
I like it :)
My favorite Spyderco is the one I'm carrying now :p
I got a thing for stainless steel and frn ....
It may becoming a issue :p
3-1-1
Postby 3-1-1 » Thu Jul 05, 2012 7:50 am
Shared these in the Wood Scale Mods thread too, but thought I solicit thoughts from here also.
Decided to "striderize" my Persistence with more of a gunstock shaped butt end a straighter top line using some yellowheart wood.
Not quite as shiny and poliched as it will be once I am finished, but its rounding into form.
haarspalter
Postby haarspalter » Fri Jul 06, 2012 12:37 am
i really like this mod. looks awesome, what didi you use?
is the wood stabilized or treated in any way?
nice job! love wooden handles!
greetings
:spyder: Mule k390-S110v-Cruwear, Gayle Bradley, Cruwear Military Collectors #13V, CPM-M4-Ti Military CF Scales, Para2 20cp
3-1-1
Postby 3-1-1 » Fri Jul 06, 2012 8:28 am
Thanks.
Its a wood called Texas yellowheart. I think it is also sometimes called "Bois D'Arc" Great stuff to work with. It was not stabilized, but I am planning to put a few coats of gunstock refinishing oil on it which will accomplish pretty much the same thing. Once thats done, I'll put it on the buffing wheel with some polishing compound to give it a real shine. Maybe I'll post another pic or two upon completion.
JAfromMN
Postby JAfromMN » Fri Jul 06, 2012 8:41 pm
Dyed my blue Endura a much darker blue.
wquiles
Postby wquiles » Fri Jul 06, 2012 9:16 pm
I have been wanting to try Moly Resin to protect the steel on my Cruware mule (prevent long term corrosion), but I was a little worried about the 300F curing time for Moly Resin (same for Cerakote) as 300F is awfully close to the temperature for tempering many steels. However, I found that Cruware's tempering temp is around 1000F, so 300F was not even close to affect its hardness, so I gave it a try.
After sandblasting the finish, I applied and cured the semi-gloss black Moly Resin (M390 mule shown for comparison):
Lets see how it holds up :D
Will
Wanted: Superhawk - Found!
Polar L
Postby Polar L » Sun Jul 15, 2012 5:58 pm
Deep carry Ti clip for GB
Polar L
Postby Polar L » Sat Jul 21, 2012 2:19 pm
Another Ti clip. Stonewashed and anodized.
Fred Sanford
Postby Fred Sanford » Sat Jul 21, 2012 11:05 pm
Polar,
I really like those clips. Very nice work.
:cool:
“I'm callin' you ugly. I could stick yo face in some dough and make some gorilla cookies.” - Fred Sanford
Tyv&
Postby Tyv& » Sun Jul 22, 2012 9:20 am
Well I decided to try and stone wash my green tenacious sprint and this is the results. I did a practice run on a ukpk that came out more subdued that I might re-do.
The set up was far from sophisticated just a plastic bottle some rocks from a stream down the road and wd40. I had a particularly large rock that I think should have been left out as it made deeper indentations and a few gouges. Overall through I am happy with the out come and I think it works well with the green sprint color of this knife.
Next up I would like to try and wharncliffe a knife (probably the ukpk) any tips or knowledge would be appreciated as I have no clue how to proceed. I have a dremel tool that I was thinking could work.
Jazz
Postby Jazz » Mon Jul 23, 2012 8:13 am
Tyv& wrote:Well I decided to try and stone wash my green tenacious sprint and this is the results. I did a practice run on a ukpk that came out more subdued that I might re-do.
Looks great!
I "wharnied" a Caly a while back. Just took a ruler and drew with a marker a straight line from the tip to the back of the blade. Then I ground it down (dip in water so it stays cool) with my Dremel and diamond bits and a diamond disk to make sure it was straight. Next, just sharpen the new edge. I'm sure the pic is at the start of this thread. It's a really easy mod. Good luck, and show us when you're done. :)
- best wishes, Jazz.
Must_Seagate
Postby Must_Seagate » Sat Aug 04, 2012 10:12 pm
Just simple mod on my PPT handle . . . .
From the black handle . . .
Into the GITD handle . ., include the lanyard . .
Sorry for the poor quality picture :(
razorsharp
Postby razorsharp » Sun Aug 05, 2012 1:33 am
thats SICK!
jabba359
Postby jabba359 » Sun Aug 05, 2012 7:38 pm
Must_Seagate wrote:Just simple mod on my PPT handle . . . .
Looks great! What material did you use for the handle and where did you get it?
-Kyle
:spyder:
Latest arrivals: DLC M4 Shaman, Opus, Q Ball
http://www.spydiewiki.com
Polar L
Postby Polar L » Thu Aug 09, 2012 5:21 pm
Yet another Ti clip. 6Al4V, 1.6mm thick.
DCDesigns
Postby DCDesigns » Thu Aug 09, 2012 5:26 pm
Lionspy Bowie Regrind
Heat anodized side
Jazz
Postby Jazz » Thu Aug 09, 2012 5:40 pm
That's awesome, DC! Exactly what that knife needed. I love a good clip point. Thanks for sharing. The stonewash and anodizing is nice, too - you're making me want that knife to do the same blade mod. Is it real heavy?
Donut
Postby Donut » Thu Aug 09, 2012 8:02 pm
It isn't as heavy as I thought it was going to be. It is very comfortable to carry with jeans. I also carried it with khaki shorts and it didn't feel to heavy, but I don't think the clip is in the perfect position for angled pockets
-Brian
A distinguished lurker.
Waiting on a Squeak, Pingo, and Cliptools with a Split Spring!
Jazz
Postby Jazz » Fri Aug 10, 2012 7:35 am
Thanks, Donut. One thing I don't like about some collaborations is the clips. I like the usual Spyderco ones. I don't like wire clips on titanium, though - just don't go together. That's the only thing I don't like about my Sage 2. I know, why am I rambling in the pic gallery? :rolleyes:
Must_Seagate
Postby Must_Seagate » Fri Aug 10, 2012 9:40 pm
jabba359 wrote:Looks great! What material did you use for the handle and where did you get it?
It;s a DIY material handle from epoxy resin, so I can put more GITD powder on there... :)
Users browsing this forum: No registered users and 3 guests
