Page 1 of 94
Show your Mule
Posted: Wed Jan 16, 2008 8:39 pm
by Brad S.
Well I figured since everyone is starting to get their Mules. Handles and cord wraps are getting done. Lets have a picture thread. :)
So post your Mule :D :D :D
I'll start of course with mine.
Natural G-10 With an Anso texture. It looks better in person, the picture didnt turn out as well as I woud have liked. And a very simple sheath. :)
Posted: Wed Jan 16, 2008 9:19 pm
by Spyderwings
Great looking Mule you got there! May I ask what you use to get that textured effect? Is it done with a file?
Looking forward to seeing more pics from other members as well.
Okay
Posted: Wed Jan 16, 2008 9:26 pm
by jaislandboy
nice job Brad I like it :cool:
Just got this a few hours ago :D
Posted: Wed Jan 16, 2008 10:04 pm
by Brad S.
The texture is done with a dremel and then a light beadblast to eat away at the resin but not at the glass.
Posted: Wed Jan 16, 2008 10:43 pm
by Spyderwings
Tricod wrote:The texture is done with a dremel and then a light beadblast to eat away at the resin but not at the glass.
Cool. Thanks for replying.
Posted: Wed Jan 16, 2008 10:52 pm
by yablanowitz
Okay, here's mine. Simple cordwrap and even more simple cardboard and duct tape sheath (made to fit in the ruler pocket of my carpenter jeans).
Posted: Wed Jan 16, 2008 11:51 pm
by jaislandboy
Posted: Thu Jan 17, 2008 7:03 am
by GMArthur
jaislandboy wrote:
Look through the spyderhole you must...hmmm
If a jedi you are to become.
Posted: Thu Jan 17, 2008 10:14 am
by clovisc
tricod -- the final effect is breathtaking! i was very curious what sort of scales you'd settle upon for your own mule... i can't imagine anything more tasteful!
Posted: Thu Jan 17, 2008 10:15 am
by clovisc
i'm contemplating getting some G10 and going nuts making my own mule scales, but i'm a little concerned about the whole pin issue. what are my alternatives (if any) to getting special, hard-to-find pins, or fabricating them? how would the G10 do simply epoxied to the handle?
Posted: Thu Jan 17, 2008 10:35 am
by Brad S.
Thanks for your comments everyone :)
clovisc wrote:i'm contemplating getting some G10 and going nuts making my own mule scales, but i'm a little concerned about the whole pin issue. what are my alternatives (if any) to getting special, hard-to-find pins, or fabricating them? how would the G10 do simply epoxied to the handle?
You could use G10 epoxyed to the scales however I would also reccommend at least getting some 1/8" barrel screws. Even without the space they are better than no hardware. If you drill the scales to fit the barrel screw and then epoxy the scales on the epoxy will fill up the gaps in the holes and create a solid joint. The problem is that your scales will slide all over the place while glueng becuase of the epoxy. Makeing them very difficult to line up.
Posted: Thu Jan 17, 2008 6:58 pm
by clovisc
my temporary solution is wrapping the mule with cloth, zambia village-style... :D combined this idea with peter atwood's technique for wrapping a knife... it's on there good and tight. the results are pretty sufficient as a temporary solution... i actually like the cloth wrap enough to consider keeping my mule just as it is now!
Posted: Fri Jan 18, 2008 2:48 pm
by araneae
Here's mine- temporarily cord wrapped until I figure out the fastener situation. I hope to work on a Kydex sheath tonight.
Brad, what did you use to seal the edges of your Kydex? I generally use eyelets.
Posted: Fri Jan 18, 2008 4:40 pm
by Brad S.
I would prefer eyelets. I however dont have the tools to crimp them. So I used a Acrylic Solvent Cement. It seems to work quite well. But I am no sheathmaker so... :o
I'm looking into getting a press so I can use rivots or eyelets and the use the Teklocks as well.
Anyword on the fastners?
Posted: Fri Jan 18, 2008 11:04 pm
by araneae
Tricod wrote:I would prefer eyelets. I however dont have the tools to crimp them. So I used a Acrylic Solvent Cement. It seems to work quite well. But I am no sheathmaker so... :o
Your sheath came out nice. You can find an inexpensive eyelet tool at most craft stores. I think they even have them at Wal Mart in the craft area. It's a small tool with a separate base that you tap with a hammer. It has worked for me so far.
As far as the fasteners go check your PM.
Posted: Sat Jan 19, 2008 1:31 pm
by jaislandboy
yablanowitz wrote:Okay, here's mine. Simple cordwrap and even more simple cardboard and duct tape sheath (made to fit in the ruler pocket of my carpenter jeans).
Hey Yab, mine is even more high-tech than yours
:D
Posted: Sun Jan 20, 2008 3:10 am
by jaislandboy
GMArthur wrote:Look through the spyderhole you must...hmmm
lol GMArthur :D
I forgot that I had another high carbon blade in the Douk-Douk but it has a pretty soft Rc @ 50-53 ... :)
Posted: Sun Jan 20, 2008 7:28 pm
by Brad S.
I love your guys cord wraps... Keep em coming
Got mine - no camera available (yet)
Posted: Mon Jan 21, 2008 5:32 am
by A-Knife
Hi guys,
I got mine today (could have been Friday, but we were not at home when UPS came). Unfortunately, my wife took the camera to work today, so no pictures yet. I'm looking for some inspiration on the forum what kind of handle to put on. I have two, so I'll probably leave one blank.
BTW, luckily the packaging was good. The point is so sharp that it almost pierced the Spyderco box. Some extra protective material would be good to save the box from being damaged.
For the rest, excellent quality and speedy delivery, glad to have them. :D
André
Still waitng for mine...
Posted: Mon Jan 21, 2008 10:11 am
by flipe8
Hopefully, it will be here any day now. Anyone from Canada order one? If yes, has it arrived yet?
