Could someone who owns a pakkawood Endela post a picture of the inside of the knife with the blade open? This would be with the knife completely assembled with the blade open so one can see the inside side of the lock bar and the spring. If you could put a FRN Endela right next to it in the same state that would be great.
I'm wanting to see if the lock bar and spring length both appear to be the same as a FRN model. This would tell me if it would work as an easy-ish blade and lockbar swap or not.
Thanks in advance,
Christian
pakkawood Endela inside?
Re: pakkawood Endela inside?
I was going to try and swap the blades but haven't got to it yet.
