I have a project wherein I tape a piece of wood and then dremel (engrave?) small numbers into the wood through the tape. Afterwards, I spray with black enamel, then remove the tape. The idea is that the engraving is painted and I don't have to clean paint off the wood yadda.
Unfortunately, the dremel tool (using a 1/16" or 3/32" ball bit) leaves the tape's edges fuzzy, or pulls the tape out of places like the inside of an 8's loop.
Any ideas on improvements to technique or materials? I don't want to hand-paint the numbers; there will be something like 400 of them by the time I am done.
Pictured is a prototype as I try different things. You can tell on a different edge, I tryed using Dykem. Easy to apply but the wood soaked it up and it did what it do. The workpiece is 3/4" x 3/4" x 7 1/2"
dremel and masking
Re: dremel and masking
Dear Tony Delica:
Stay safe,
Mike
Stay safe,
Mike
Try using an exacto knife to cut the outline in the tape.
I can't see the picture, but what about just sanding the face afterwards?
^^^What Bob said.
I've done it plenty of times on metal that's been stamped, etched, cast, etc. The only unknown is if the paint will soak into the high-points of the wood, where you don't want it. It might be necessary to put some kind of finsh on the wood before engraving.
- kennethsime
Some folks use nail polish as a mask. I wonder if that might be a more precise version of masking tape? Easily removed with nail polish remover afterwards.RustyIron wrote: ↑Mon May 02, 2022 12:15 pm
^^^What Bob said.
Interesting idea. As long as the paint doesn't get attacked by acetone,...kennethsime wrote: ↑Fri May 06, 2022 9:59 pmSome folks use nail polish as a mask. I wonder if that might be a more precise version of masking tape? Easily removed with nail polish remover afterwards.
I did have a test with floor wax and spray paint. The paint came off remarkably easily.
