Microtech Question?
jdw
Microtech Question?
Post by jdw »
I have found myself owning a couple of Exocets that are slowly replacing my D-fly options in my back pocket and both are some kind of treated M390. These are definitely not for hard use, they are for fun. Question is.....How do I care for them? I don't really trust other boards but please help me out here.
--Wovoka
troutinCO
Re: Microtech Question?
Post by troutinCO »
I keep my couple of microtechs blown out with compressed air. Just blow it straight down the blade hole typically. A couple of drops of oil at the choil(?), each side, run the blade in and out a few times and done typically.
VashHash
Post by VashHash »
I follow the microtech recommendation. Remoil for lube. Usually blow them out with compressed air every so often. Don't over lube them though. That will cause issues. Just a drop on each side of the blade. So 4 drops. Then cycle and wipe off any excess. Of it has a window breaker I will unscrew it to also blow air through that and out of the opening. If you ever want to clean it really good use naphtha /lighter fluid. Pour it in and shake it a bit. Then turn it upside down to drain out. Relube with rem oil. Some people also swear by running them dry with no lube.
TomAiello
Post by TomAiello »
Does Microtech have a maintenance service? I own 4 Microtechs but I rarely carry them. Super nice knives, but I find them less ergonomic for EDC than my Spydercos.
VashHash
Post by VashHash »
TomAiello wrote:
Mon Oct 25, 2021 7:58 am
I'm sure they would do maintenance. According to the website if you send in for warranty they will clean, lube, and sharpen the knife for free. I would suggest calling them.
BLUETYPEII
Post by BLUETYPEII »
I use the recommended REM oil and it’s worked fine. Microtech has a video on YouTube, you should check it out.
I had issues with a UTX-85 and had to send it in… really good customer service, very friendly people. Top notch company. IMO
1 Byrd and 30 “others”
murphjd25
Post by murphjd25 »
All of my Microtechs I use to have would occasionally get cleaned out with WD40, then compressed air to dry it all out, then a little drop of remoil inside and under the slide. I finally got another Microtech on the way again too, they finally made one without s ridiculous window breaker on the end! The Hera looks beautiful and right up my alley for a OTF.
Josh
brj
Post by brj »
I've been running my OTFs bone dry, no issues so far. Yes, there is more metal-on-metal friction and I guess at some point they will wear out but I strongly suspect this won't happen during my lifetime. Compressed air from time to time to blow out lint and that's pretty much all the maintenance they've seen so far.
I love the Exocet, it's quite pocketable and an irresistible combination of thin blade with awesome slicing abilities (I have the tanto) and an actually hand-filling handle.
jdw
Post by jdw »
murphjd25 wrote:
Wed Oct 27, 2021 4:51 pm
The Hera has really been speaking to me as well and I have almost grabbed the SE version a couple of times. I have really enjoyed carrying the Exocets and they have proven to be more durable than I originally guessed. As brj noted they have a handful of grip and nice slicing ability. Have you had a chance to use the Hera yet? Microtech lauds it as an EDC option and I wonder what your experience has been? I also am completely with you on getting rid of the stupid window breaker. Thank you and I appreciate everybody's feedback!
--Wovoka
murphjd25
Post by murphjd25 »
jdw wrote:
Thu Nov 11, 2021 5:57 pm
I carry it a few times a week, and have used it. It’s a great edc, I think Microtech finally hit a home run with a knife that splits right down the middle of their lineup. And the clip is just amazing!
Josh
