Hello all, new to the forums but not new to Spyderco (own just shy of a couple dozen) nor new to the fascination with steel. I posted this on another board but wanted to come hear to post as well as talk about Spydies!
Some years back I became very interested in knife steel, specifically in how the different elements within the steel determined how they functioned, as well as how steel is made from the extraction of the ore, to forging, to heat treating, etc. I dived in to this field and read manufacturer data sheets which then lead to me reading literature on the various testing methods like Izod and Charpy impact testing, corrosion testing and the solutions used, I read scientific papers on the various elements in the steel especially Nickel and Nitrogen and how those elements react to each other, I read all about carbide formation and the different types of carbides, etc etc.
After all this research and cross referencing I decided to develop formulas that would accurately determine how a steel should perform in four important areas that impact knife users; Edge Retention, Ease of Sharpening, Corrosion Resistance, and Toughness (Ductility). I did this for two reasons, one being that when looking at knife steel ratings from various people and websites they were all very subjective and contradictory. This was in-part because they were not looking at the steel alone, but individual representative knives (which comes with some serious caveats which I will get into later). The other reason I did this was because I had already consumed a lot of info and wanted to put that knowledge to the test.
Before I post the tables I want to get into why comparing knives themselves is problematic as opposed to the steel by itself, and why I had to remove important elements from the formulas I used.
1. Quality Control: Unfortunately there are naturally going to be differences in the quality of knives produced, starting all the way back from roughly the beginning with ore extraction, followed by forging, followed by heat treating, followed by the knife design, etc. The same exact steel can be wildly different in performance depending on the degree of quality control through even just one phase of development. A good example of this is found with 440C, a steel that was "high end" when it was released but is now considered "budget" and unfortunately treated as such by manufacturers. I have observed a wide range of quality with 440C from older examples being really good to more modern stuff being actual junk, and everything in-between.
2. The Metallurgy Process: Not all processes are the same and thus not all steels are the same even if the chemical composition is the same. As an example the difference in performance between 154CM and CPM 154 is maybe not night-and-day but is considerable, and this is simply due to the fact that CPM 154 uses Particle Metallurgy (PM) for the molding process as opposed to a more traditional method for 154CM. The process Crucible uses creates a much more uniform (homogenous) carbide structure. In more conventional methods the carbide structure will be more irregular and less uniform and this has an impact on how the steel will perform. Add to this the amount of different processes that can be used (particle, powder, spray form, magnetic, etc.) and we can start seeing real differences in the steel despite the same composition of elements.
3. Heat Treat: Even if the quality of the steel formation was exceptional, heat treat can make or break a knife. If the heat treat was poorly done you can have irregularities in the hardness of the blade with portions being harder or softer than they should be. Even if the treat was uniform it can be undone if the blade is under-hardened or over-hardened. CPM S110V should be an excellent wear resistant (edge retention) but largely non-ductile (toughness) steel under quality treating, but if it was treated to a HR of 45 its edge retention would be laughable and it would be more ductile (great if that was the purpose of the steel, but it is not).
4. Blade Construction: Not only are quality and evenness important but so to is the grind and blade geometries. Angle of the edge can make a large impact on edge retention, more then most would think.
5. A slew of other things: How was the blade sharpened? Was the edge taken to a mirror polish? Does it work better with a mirror polish? etc.
For my formulas I could not factor the above things into them, as there is simply no way to account for all the variables and any values I came up with would be arbitrary. I didn't even mention the natural purity of some ores versus others and a whole mess of other considerations. Given all this the formulas only use the elements (Carbon, Chromium, Tungsten, Nitrogen, etc.) in the steel to create a score for grading. Certain things get underrepresented (like CPM S110V on Corrosion Resistance) due to not accounting for their carbide uniformity or other factors (like hardness level the steel is heat treated to), but I feel the formula works exceptionally well for ball parking observed performance regardless.
One last note, the lower the number for the Grade the better that steel is, the higher the number the worse it is. If anyone is curios where a steel not represented here falls on these tables, just let me know the name of the steel and I will let you know. Thanks.
KNIFE STEEL: Comparative Tables
- Yomagn'tho
“That weapon will replace your tongue. You will learn to speak through it. And your poetry will now be written with blood”.......Nobody from "Dead Man"
Re: KNIFE STEEL: Comparative Tables
Thanks for sharing these very informative charts. I just wish CPM Rex45 was listed in this. That is the current steel I own in my Native Chief.
